* | Add rtems_bsd_set_if_input() | Sebastian Huber | 2017-10-23 | 1 | -0/+1 |
* | Linux update to 4.11-rc5 | Sebastian Huber | 2017-10-23 | 1 | -8/+24 |
| | | | | Linux baseline a71c9a1c779f2499fb2afc0553e543f18aff6edf (4.11-rc5). | ||||
* | Import DPAA driver snapshot | Sebastian Huber | 2017-10-23 | 1 | -0/+44 |
| | | | | | | | | | | Imported from Freescale Linux repository git://git.freescale.com/ppc/upstream/linux.git commit 2774c204cd8bfc56a200ff4dcdfc9cdf5b6fc161. Linux compatibility layer is partly from FreeBSD. | ||||
* | Import CRC32 support from FreeBSD | Sebastian Huber | 2017-10-20 | 1 | -0/+1 |
* | blist: Import from FreeBSD | Sebastian Huber | 2017-10-20 | 1 | -0/+2 |
* | scripts: Generalize names | Sebastian Huber | 2017-10-20 | 1 | -8/+8 |
* | tcpdump: Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-10-11 | 1 | -48/+40 |
| | | | | | | Update tcpdump from Git mirror commit 99a648a912e81e29d9c4c159cbbe263462f2d719 to 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | Update libpcap to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-10-09 | 1 | -0/+7 |
| | | | | | | Update libpcap from Git mirror commit 99a648a912e81e29d9c4c159cbbe263462f2d719 to 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | ffec: Port to RTEMS | Sebastian Huber | 2017-09-27 | 1 | -0/+2 |
* | if_atsam: Allow fixed MII settings. | Christian Mauderer | 2017-09-22 | 1 | -0/+1 |
* | if-atsam: Port to rtems-libbsd. | Christian Mauderer | 2017-09-22 | 1 | -0/+1 |
* | Remove strtoimax() and strtoumax() | Sebastian Huber | 2017-08-22 | 1 | -2/+0 |
| | | | | This is now provided by Newlib. | ||||
* | Port openssl to RTEMS. | Sichen Zhao | 2017-08-20 | 1 | -0/+952 |
* | Port rtl8188eu driver to RTEMS. | Sichen Zhao | 2017-08-02 | 1 | -0/+1 |
| | | | | | Now USB dongle rtl8188eu can work as wlan client device. It can scan wifi, connect unencrypted wifi. | ||||
* | dev/rtwn: Import new files from FreeBSD. | Christian Mauderer | 2017-07-17 | 1 | -5/+23 |
* | Port am335x usb driver to RTEMS. | Sichen Zhao | 2017-07-13 | 1 | -0/+34 |
| | | | | | | Add FDT and umass support for am335x USB driver. Now RTEMS can mount and open USB disk. | ||||
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 1 | -12/+0 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Update scripts to include support for input devices - USB Keyboard, USB ↵ | Kevin Kirspel | 2017-05-19 | 1 | -21/+58 |
| | | | | mouse, touch, and EVDEV | ||||
* | Updating scripts for USB Serial Drivers | Kevin Kirspel | 2017-05-12 | 1 | -1/+5 |
* | Updating scripts for FREEBSD TTY support | Kevin Kirspel | 2017-05-11 | 1 | -11/+66 |
* | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-04-04 | 1 | -10/+20 |
| | | | | Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | if_tsec: Enable FDT support | Sebastian Huber | 2017-03-08 | 1 | -0/+1 |
* | FDT(4): Port to RTEMS | Sebastian Huber | 2017-03-08 | 1 | -0/+41 |
* | Add poll() and select() support for Termios | Sebastian Huber | 2017-02-28 | 1 | -1/+2 |
* | Port LPC32XX Ethernet and USB OHCI to RTEMS | Kevin Kirspel | 2017-02-14 | 1 | -0/+6 |
* | freebsd/wlanstats: Port to FreeBSD. | Christian Mauderer | 2017-01-17 | 1 | -0/+23 |
* | wlan/run: Add firmware. | Christian Mauderer | 2017-01-17 | 1 | -0/+6 |
* | rtwn: Port to RTEMS | Christian Mauderer | 2017-01-17 | 1 | -0/+172 |
* | lib80211/regdomain: Port to RTEMS. | Christian Mauderer | 2017-01-17 | 1 | -0/+11 |
* | ifconfig/wlan, expat, lib80211: Port to RTEMS. | Christian Mauderer | 2017-01-17 | 1 | -0/+45 |
* | Port USB and USB WLAN. | Christian Mauderer | 2017-01-17 | 1 | -4/+35 |
* | firmware: Port to RTEMS. | Christian Mauderer | 2017-01-17 | 1 | -0/+2 |
* | Port IEEE 802.11. | Christian Mauderer | 2017-01-17 | 1 | -2/+5 |
* | Use thread name support | Sebastian Huber | 2017-01-13 | 1 | -1/+0 |
| | | | | Update #2858. | ||||
* | ARP(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 1 | -0/+2 |
* | Update to FreeBSD head 2017-01-09 | Sebastian Huber | 2017-01-10 | 1 | -0/+1 |
| | | | | Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab. | ||||
* | VMSTAT(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 1 | -0/+2 |
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 1 | -116/+203 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | PIPE(2): Port to RTEMS | Kevin Kirspel | 2016-12-23 | 1 | -0/+2 |
* | Add a RTEMS Debugger TCP remote transport. | Chris Johns | 2016-11-29 | 1 | -0/+8 |
| | | | | | | | The patch also adds support to libbsd's build system making source conditional on a configure check. The debugger support is not available on all architectures and this feature lets us test if is avaliable. | ||||
* | SDHCI(4): Delete | Sebastian Huber | 2016-11-09 | 1 | -2/+0 |
| | | | | | Delete heavily modified SDHCI(4) support. It must be re-imported from a later FreeBSD version on demand. | ||||
* | Remove AppleTalk support | Sebastian Huber | 2016-10-13 | 1 | -19/+0 |
| | | | | Prepare update to FreeBSD 11. | ||||
* | usb01: Simplify test program | Sebastian Huber | 2016-09-28 | 1 | -1/+1 |
* | Split rtemsbsd/rtems/rtems-program.c | Sebastian Huber | 2016-09-28 | 1 | -0/+1 |
| | | | | This improves garbage collection by the linker. | ||||
* | Split rtems-bsd-kernel-program.c | Sebastian Huber | 2016-09-28 | 1 | -0/+1 |
| | | | | Separate kernel and user space parts. | ||||
* | Build rtems-bsd-shell-pfctl.c | Sebastian Huber | 2016-09-28 | 1 | -0/+1 |
* | Split rtems-bsd-shell-netcmds.c | Sebastian Huber | 2016-09-28 | 1 | -1/+6 |
* | Port getdomainname() to RTEMS | Sebastian Huber | 2016-09-07 | 1 | -0/+1 |
* | pf: Add configuration via rc.conf. | Christian Mauderer | 2016-08-08 | 1 | -0/+1 |
* | freebsd: Add constant ipv6 addresses from vars.c. | Christian Mauderer | 2016-08-04 | 1 | -0/+1 |
| | | | | This is necessary for a configuration without IPv6. |
