2016-12-23 | PIPE(2): Port to RTEMS | Kevin Kirspel | 1 | -0/+2 | |
2016-11-29 | Add a RTEMS Debugger TCP remote transport. | Chris Johns | 1 | -0/+8 | |
The patch also adds support to libbsd's build system making source conditional on a configure check. The debugger support is not available on all architectures and this feature lets us test if is avaliable. | |||||
2016-11-09 | SDHCI(4): Delete | Sebastian Huber | 1 | -2/+0 | |
Delete heavily modified SDHCI(4) support. It must be re-imported from a later FreeBSD version on demand. | |||||
2016-10-13 | Remove AppleTalk support | Sebastian Huber | 1 | -19/+0 | |
Prepare update to FreeBSD 11. | |||||
2016-09-28 | usb01: Simplify test program | Sebastian Huber | 1 | -1/+1 | |
2016-09-28 | Split rtemsbsd/rtems/rtems-program.c | Sebastian Huber | 1 | -0/+1 | |
This improves garbage collection by the linker. | |||||
2016-09-28 | Split rtems-bsd-kernel-program.c | Sebastian Huber | 1 | -0/+1 | |
Separate kernel and user space parts. | |||||
2016-09-28 | Build rtems-bsd-shell-pfctl.c | Sebastian Huber | 1 | -0/+1 | |
2016-09-28 | Split rtems-bsd-shell-netcmds.c | Sebastian Huber | 1 | -1/+6 | |
2016-09-07 | Port getdomainname() to RTEMS | Sebastian Huber | 1 | -0/+1 | |
2016-08-08 | pf: Add configuration via rc.conf. | Christian Mauderer | 1 | -0/+1 | |
2016-08-04 | freebsd: Add constant ipv6 addresses from vars.c. | Christian Mauderer | 1 | -0/+1 | |
This is necessary for a configuration without IPv6. | |||||
2016-08-03 | testsuite/pf02: Add interactive pf test. | Christian Mauderer | 1 | -0/+1 | |
2016-08-02 | pfctl: build files. | Christian Mauderer | 1 | -0/+17 | |
2016-08-02 | testsuite/syscalls01: Split out program01 part. | Christian Mauderer | 1 | -0/+1 | |
This allows to use normal functions for sockets and similar while allowing to test the upcoming rtems_bsd_program_opan/close/... for the program part. | |||||
2016-08-01 | testsuite/pf01: Add test that links PF. | Christian Mauderer | 1 | -0/+1 | |
2016-08-01 | testsuite/cdev01: Add test for cdev functions. | Christian Mauderer | 1 | -0/+1 | |
2016-08-01 | kern_conf.c: Adapt for RTEMS. | Christian Mauderer | 1 | -1/+1 | |
2016-08-01 | rtemsbsd/devfs: Add. | Christian Mauderer | 1 | -0/+1 | |
2016-07-01 | Add telnetd as service to rc.conf. | Chris Johns | 1 | -0/+2 | |
2016-06-30 | Add RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE. | Chris Johns | 1 | -0/+1 | |
The domain allocator page abd mbuf size can be configured by the user using RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE. | |||||
2016-06-30 | Add rtems_get_route to fetch a specific route from the routing tables. | Chris Johns | 1 | -0/+1 | |
2016-06-28 | Add ftpd as a service. Add rtems-bsd-config.h for app libbsd set up. | Chris Johns | 1 | -0/+2 | |
2016-06-27 | Add a services base test. | Chris Johns | 1 | -58/+59 | |
2016-06-10 | nfsclient: Port to LibBSD | Sebastian Huber | 1 | -0/+5 | |
2016-06-10 | XDR(3): Port to RTEMS | Sebastian Huber | 1 | -0/+8 | |
2016-06-10 | RPC(3): Port to RTEMS | Sebastian Huber | 1 | -11/+84 | |
2016-06-10 | ftpfs: Import from RTEMS | Sebastian Huber | 1 | -0/+2 | |
RTEMS Git commit 251c94d3d3d27e0039f01b718e5c2eb06f39fdf7. | |||||
2016-05-18 | Add support for rc.conf(5) initialisation. | Chris Johns | 1 | -0/+3 | |
Provide user support for rc.conf(5) so a user can create a suitable /etc/rc.conf file to initialise libbsd. This patch by default adds basic networking support: cloned_interfaces ifconfig_'interface' defaultrouter hostname Refer to FreeBSD documentation for examples. Users can make a single call to have /etc/rc.conf processed, or pass a file name to a specific configuration file or a text string with line feeds can be passed to the scripting version of the interface. The rc.conf support is implemented in terms of directive handlers that are called based on a regular expression. The design allows new handlers to be added as needed. Line concatenation is still to be implemented. | |||||
2016-05-06 | Add namespace support for kvm | Sebastian Huber | 1 | -1/+1 | |
2016-05-06 | Rename files for kernel namespace script | Sebastian Huber | 1 | -38/+38 | |
This makes it easier to create the kernel namespace header. | |||||
2016-05-06 | subr_prf.c: Port to RTEMS | Sebastian Huber | 1 | -2/+4 | |
2016-05-06 | Add sbin/sysctl | Chris Johns | 1 | -0/+3 | |
2016-05-04 | Add RealTek Gig PHY. | Chris Johns | 1 | -0/+3 | |
2016-04-27 | libbsd: Remove sys/select.h and sys/_sigset.h. | Chris Johns | 1 | -2/+0 | |
2016-04-26 | Add root bus support functions | Sebastian Huber | 1 | -0/+1 | |
2016-04-26 | Initialize interrupt server early | Sebastian Huber | 1 | -0/+1 | |
This enables its use before the Nexus device exists. | |||||
2016-04-18 | Add RTEMS version support, update all python to 2 and 3. | Chris Johns | 1 | -1/+7 | |
Add support to force the RTEMS version. This remove the need for using the --rtems-version command line option if the automatic detection fails. Update all python code to support python 2 and 3. Update rtems_waf to the latest version to support the RTEMS version, check environment variables and to display the CC version. Sort all tests. I think the unsorted list is dependent on the version of python and so would result in repo noise as if it regenerted. | |||||
2015-11-17 | Use RTEMS provided <sys/priority.h> | Sebastian Huber | 1 | -1/+0 | |
2015-11-17 | Use RTEMS provided <sys/ttycom.h> | Sebastian Huber | 1 | -1/+0 | |
2015-11-17 | Use RTEMS provided <sys/sockio.h> | Sebastian Huber | 1 | -1/+0 | |
2015-11-17 | Use RTEMS provided <sys/mman.h> | Sebastian Huber | 1 | -2/+0 | |
2015-11-17 | Use RTEMS provided <sys/endian.h> | Sebastian Huber | 1 | -1/+0 | |
2015-11-12 | dwc_otg: Port to RTEMS | Sebastian Huber | 1 | -0/+4 | |
2015-09-29 | BUS_SPACE(9): Use FreeBSD files for i386 arch | Sebastian Huber | 1 | -0/+2 | |
2015-09-29 | Avoid pci_cfgreg.h rename | Sebastian Huber | 1 | -8/+2 | |
2015-09-25 | builder.py: addTargetSourceCPUDependentSourceFiles | Sebastian Huber | 1 | -25/+12 | |
Avoid and delete this function. | |||||
2015-09-25 | Avoid pci_bus.c file rename | Sebastian Huber | 1 | -8/+1 | |
2015-09-01 | Delete superfluous pci_cfgreg.h files | Sebastian Huber | 1 | -2/+1 | |
2015-09-01 | Delete superfluous legacyvar.h files | Sebastian Huber | 1 | -8/+0 | |
