Update #4475
Updates #4475
- Refactor the libio interface
- Move syscalls into an rtemsbsd location
- Provide a root directory mount point
Update #4475
- Object files cannot config init and resided in libbsd.a
Update #4475
Update #4475
- Provides the thread's proc pointer and with that access to creds
Update #4475
Update #4475
- Add the ability to check if an interface is up
Added a new test for the TTCP command. Modified default-network-init.h
to conditionally build the shell with TTCP. Modified libbsd.py to build
the new TTCP test.
Updated ttcp.c to build clean for RTEMS 6 and the machines it
originally built for. Also fixed ttcp.c to close network
sockets after completion. Defined a shell command for TTCP in
rtems-bsd-shell-ttcp.c. Added TTCP to the list of RTEMS network
commands in netcmds-config.h. Added declaration of the TTCP shell
command to rtems-bsd-commands.h. Modified libbsd.py to make waf
build TTCP and its shell command.
Update #4372
Update #4372
Add a System Level Control Register driver for the Xilinx Zynq
Ultrascale+ MPSoC with basic clock control functionality for use with
the Cadence GEM. This also removes the Zynq-7000 clock control weakref
from compilation depending on the BSP in use.
Closes #4264
Update #3910.
Update #3910.
- Do not build a test if a dependency is not enabled.
- Perform a dependency check and generate an error if an enabled module
depends on a disabled module.
Closes #4077
- Provide support for separate user and kernel include paths in
libbsd.py.
- Update all added files with a suitable context to build them
with. Supported contexts are `kernel` and `user`.
- Kernel source use the kernel, CPU, and build header paths in
this order.
- User source use the user, kernel, CPU and build header paths
in this order. The FreeBSD /usr/include tree has some kernel
header files installed as well as user land header files. This
complicates the separation as some kernel header files are not
visible to user land code while other are. This is handled by
appending the kernel header paths to the user header paths so
user land code will include a user header with the same name as
a kernel header over the kernel header but will find a kernel
header if there is no matching user header file.
Closes #4067
Update 3869
There is a bug in the #ifdef regarding FDT so this file hasn't been
compiled. If that bug is solved, the driver doesn't work for some other
reason.
With the FDT-bug the driver hasn't been used by anyone. So just remove
it again.
- Update FreeBSD files in libbsd.py to required by i386 based BSPs
- Some machine specific header files have moved to different directories
in FreeBSD
- Add missing files e1000 network driver (iflib*)
- path-mappings allow to fix autogenerated include paths for some corner
cases of target platforms without the need to change the build system
- Currently used for i386 based bsps
Update #3869.
Update #3869.
- Add support for a 'test-if-library'
- Use rtems_waf's 'test_application()' fragment in the check_cc
call
Closes #3948
Git mirror commit 0d1c391321b34b3025cf0e72f2231d836ff76da8.
Close #3798.
Update #3821.
Update #3821.
Update #3821.
Update #3821.
Update #3821.
Git mirror commit 7e8d1444023128d34fb9aa4e4515928a4f794d1b.
