* | nexus: Add ZynqMP SLCR driver | Kinsey Moore | 2021-03-10 | 1 | -0/+1 |
| | | | | | | | Add a System Level Control Register driver for the Xilinx Zynq Ultrascale+ MPSoC with basic clock control functionality for use with the Cadence GEM. This also removes the Zynq-7000 clock control weakref from compilation depending on the BSP in use. | ||||
* | ehci_pci: Add to build system | Moyano, Gabriel | 2021-03-08 | 1 | -0/+2 |
| | | | | Closes #4264 | ||||
* | zynq: Add support for SDHCI devices | Kinsey Moore | 2020-12-22 | 1 | -0/+1 |
* | Update arm64/aarch64 support | Kinsey Moore | 2020-11-13 | 1 | -0/+21 |
* | dwc_otg: Add support for nexus bus | Sebastian Huber | 2020-10-27 | 1 | -0/+2 |
| | | | | Update #3910. | ||||
* | if_stmac: Add driver for STM32H7 ethernet module | Sebastian Huber | 2020-10-27 | 1 | -0/+1 |
* | powerpc/nexus: Add legacy PCI support to PowerPC Motorola Shared BSP family | Chris Johns | 2020-10-20 | 1 | -1/+1 |
* | waf: Fix test module dependency check | Chris Johns | 2020-09-30 | 1 | -2/+2 |
* | Add moxie support | Sebastian Huber | 2020-09-29 | 1 | -1/+2 |
* | Add or1k support | Sebastian Huber | 2020-09-29 | 1 | -1/+1 |
* | waf: Implement module dependency checking in the build system | Chris Johns | 2020-09-16 | 1 | -15/+14 |
| | | | | | | | | | - Do not build a test if a dependency is not enabled. - Perform a dependency check and generate an error if an enabled module depends on a disabled module. Closes #4077 | ||||
* | build: Separate the kernel and user land include paths | Chris Johns | 2020-09-16 | 1 | -229/+301 |
| | | | | | | | | | | | | | | | | | | | | | | | - Provide support for separate user and kernel include paths in libbsd.py. - Update all added files with a suitable context to build them with. Supported contexts are `kernel` and `user`. - Kernel source use the kernel, CPU, and build header paths in this order. - User source use the user, kernel, CPU and build header paths in this order. The FreeBSD /usr/include tree has some kernel header files installed as well as user land header files. This complicates the separation as some kernel header files are not visible to user land code while other are. This is handled by appending the kernel header paths to the user header paths so user land code will include a user header with the same name as a kernel header over the kernel header but will find a kernel header if there is no matching user header file. Closes #4067 | ||||
* | mcast01: Add test program | Sebastian Huber | 2020-09-10 | 1 | -0/+1 |
* | ifmcstat: Port to RTEMS | Sebastian Huber | 2020-09-07 | 1 | -0/+3 |
* | imx: Use RTEMS GPIO driver instead of FreeBSD one | Christian Mauderer | 2020-07-29 | 1 | -1/+1 |
| | | | | Update 3869 | ||||
* | gpioregulator: Remove. | Christian Mauderer | 2020-07-29 | 1 | -1/+0 |
| | | | | | | | | | There is a bug in the #ifdef regarding FDT so this file hasn't been compiled. If that bug is solved, the driver doesn't work for some other reason. With the FDT-bug the driver hasn't been used by anyone. So just remove it again. | ||||
* | i386: Add missing files to build system | Jan Sommer | 2020-04-17 | 1 | -3/+9 |
| | | | | | | | - Update FreeBSD files in libbsd.py to required by i386 based BSPs - Some machine specific header files have moved to different directories in FreeBSD - Add missing files e1000 network driver (iflib*) | ||||
* | waf: Add path-mappings feature | Jan Sommer | 2020-04-17 | 1 | -0/+8 |
| | | | | | | - path-mappings allow to fix autogenerated include paths for some corner cases of target platforms without the need to change the build system - Currently used for i386 based bsps | ||||
* | ehci_imx: Add to build. | Christian Mauderer | 2020-04-15 | 1 | -0/+2 |
* | regulator: Add to build. | Christian Mauderer | 2020-04-14 | 1 | -0/+30 |
| | | | | Update #3869. | ||||
* | imx6_ccm: Add and build module. | Christian Mauderer | 2020-04-14 | 1 | -0/+23 |
* | waf: Change the test configure check for libdebugger to it's lib | Chris Johns | 2020-03-05 | 1 | -2/+2 |
| | | | | | | | | | - Add support for a 'test-if-library' - Use rtems_waf's 'test_application()' fragment in the check_cc call Closes #3948 | ||||
* | Update to FreeBSD stable/12 2020-02-10 | Sebastian Huber | 2020-02-18 | 1 | -4/+4 |
| | | | | Git mirror commit 0d1c391321b34b3025cf0e72f2231d836ff76da8. | ||||
* | SOCKATMARK(3): Import from FreeBSD | Sebastian Huber | 2019-12-19 | 1 | -0/+1 |
| | | | | Close #3798. | ||||
* | NVMECONTROL(8): Port to RTEMS | Sebastian Huber | 2019-11-13 | 1 | -0/+1 |
| | | | | Update #3821. | ||||
* | NVMECONTROL(8): Add to build | Sebastian Huber | 2019-11-13 | 1 | -0/+31 |
* | NVD(4): Add RTEMS-specific NVMe disk driver | Sebastian Huber | 2019-11-13 | 1 | -0/+6 |
* | NVME(4): Install header files | Sebastian Huber | 2019-11-13 | 1 | -0/+1 |
* | NVME(4): Add build module | Sebastian Huber | 2019-11-13 | 1 | -0/+30 |
* | Remove obsolete header files | Sebastian Huber | 2019-09-25 | 1 | -1/+0 |
* | Fix pgsigio() warnings | Sebastian Huber | 2019-09-25 | 1 | -1/+0 |
* | Update to FreeBSD stable/12 2019-09-23 | Sebastian Huber | 2019-09-23 | 1 | -0/+2 |
| | | | | Git mirror commit 7e8d1444023128d34fb9aa4e4515928a4f794d1b. | ||||
* | PCI(4): Import missing file | Sebastian Huber | 2019-09-23 | 1 | -1/+2 |
* | PCI(4): Install header files | Sebastian Huber | 2019-09-23 | 1 | -0/+1 |
* | Add <sys/disk.h> to build module | Sebastian Huber | 2019-09-23 | 1 | -0/+1 |
* | Remove superfluous support for preloaded modules | Sebastian Huber | 2019-08-27 | 1 | -1/+0 |
* | Import missing header file | Sebastian Huber | 2019-06-28 | 1 | -0/+1 |
* | Update to FreeBSD stable/12 2019-06-05 | Sebastian Huber | 2019-06-05 | 1 | -4/+15 |
| | | | | Git mirror commit 78576620f2689e23144a1cf1bf55106cc6abe2b7. | ||||
* | Add riscv support | Sebastian Huber | 2019-05-23 | 1 | -1/+1 |
* | Update to FreeBSD stable/12 2019-03-27 | Sebastian Huber | 2019-03-28 | 1 | -0/+3 |
| | | | | Git mirror commit 43a38f188ca2e936ec78104c30ea3e24d9c1606b. | ||||
* | build: Add RTEMS test library | Sebastian Huber | 2019-03-28 | 1 | -2/+2 |
| | | | | Update #3199. | ||||
* | bin/openssl: Port to RTEMS. | Christian Mauderer | 2019-03-28 | 1 | -0/+92 |
* | Build C++ kernel-space compatibility file | Sebastian Huber | 2019-02-18 | 1 | -0/+1 |
* | mghttpd: Remove | Sebastian Huber | 2019-02-12 | 1 | -19/+0 |
| | | | | The mghttpd is already provided by RTEMS. | ||||
* | Update to FreeBSD stable/12 2019-02-11 | Sebastian Huber | 2019-02-12 | 1 | -0/+1 |
| | | | | Git mirror commit 606b591dae1023a71ff020faf99789059eb6591f. | ||||
* | Update to FreeBSD stable/12 2019-01-16 | Sebastian Huber | 2019-01-21 | 1 | -3/+1 |
| | | | | | | Git mirror commit 4ff7d8141f665693dd8b17090d410604888f1e9a. Update #3472. | ||||
* | freebsd/if_cpsw: Port. | Christian Mauderer | 2018-12-20 | 1 | -0/+3 |
* | Update to FreeBSD head 2018-11-15 | Sebastian Huber | 2018-11-15 | 1 | -1/+2 |
| | | | | | | Git mirror commit a18b0830c4be01b39489a891b63d6023ada6358a. Update #3472. | ||||
* | openssl01: New test | Sebastian Huber | 2018-10-25 | 1 | -0/+1 |
* | Update to FreeBSD head 2018-10-23 | Sebastian Huber | 2018-10-25 | 1 | -876/+838 |
| | | | | | | | | | | | Git mirror commit 59f44d20be3f99d181ca742e636d45fc39ec982b. This commit updates OpenSSL to version 1.1.1. This required an update of racoon which uses some internal stuff from OpenSSL and seems to be mostly unmaintained, e.g. there is update in the FreeBSD ports to cope with OpenSSL 1.1.1. Update #3472. |
