2017-10-23 | Add rtems_bsd_set_if_input() | Sebastian Huber | 1 | -0/+1 | |
2017-10-23 | Linux update to 4.11-rc5 | Sebastian Huber | 1 | -8/+24 | |
Linux baseline a71c9a1c779f2499fb2afc0553e543f18aff6edf (4.11-rc5). | |||||
2017-10-23 | Import DPAA driver snapshot | Sebastian Huber | 1 | -0/+44 | |
Imported from Freescale Linux repository git://git.freescale.com/ppc/upstream/linux.git commit 2774c204cd8bfc56a200ff4dcdfc9cdf5b6fc161. Linux compatibility layer is partly from FreeBSD. | |||||
2017-10-20 | Import CRC32 support from FreeBSD | Sebastian Huber | 1 | -0/+1 | |
2017-10-20 | blist: Import from FreeBSD | Sebastian Huber | 1 | -0/+2 | |
2017-10-20 | scripts: Generalize names | Sebastian Huber | 1 | -8/+8 | |
2017-10-11 | tcpdump: Update to FreeBSD head 2017-04-04 | Sebastian Huber | 1 | -48/+40 | |
Update tcpdump from Git mirror commit 99a648a912e81e29d9c4c159cbbe263462f2d719 to 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | |||||
2017-10-09 | Update libpcap to FreeBSD head 2017-04-04 | Sebastian Huber | 1 | -0/+7 | |
Update libpcap from Git mirror commit 99a648a912e81e29d9c4c159cbbe263462f2d719 to 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | |||||
2017-09-27 | ffec: Port to RTEMS | Sebastian Huber | 1 | -0/+2 | |
2017-09-22 | if_atsam: Allow fixed MII settings. | Christian Mauderer | 1 | -0/+1 | |
2017-09-22 | if-atsam: Port to rtems-libbsd. | Christian Mauderer | 1 | -0/+1 | |
2017-08-22 | Remove strtoimax() and strtoumax() | Sebastian Huber | 1 | -2/+0 | |
This is now provided by Newlib. | |||||
2017-08-20 | Port openssl to RTEMS. | Sichen Zhao | 1 | -0/+952 | |
2017-08-02 | Port rtl8188eu driver to RTEMS. | Sichen Zhao | 1 | -0/+1 | |
Now USB dongle rtl8188eu can work as wlan client device. It can scan wifi, connect unencrypted wifi. | |||||
2017-07-17 | dev/rtwn: Import new files from FreeBSD. | Christian Mauderer | 1 | -5/+23 | |
2017-07-13 | Port am335x usb driver to RTEMS. | Sichen Zhao | 1 | -0/+34 | |
Add FDT and umass support for am335x USB driver. Now RTEMS can mount and open USB disk. | |||||
2017-06-08 | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 1 | -12/+0 | |
The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | |||||
2017-05-19 | Update scripts to include support for input devices - USB Keyboard, USB ↵ | Kevin Kirspel | 1 | -21/+58 | |
mouse, touch, and EVDEV | |||||
2017-05-12 | Updating scripts for USB Serial Drivers | Kevin Kirspel | 1 | -1/+5 | |
2017-05-11 | Updating scripts for FREEBSD TTY support | Kevin Kirspel | 1 | -11/+66 | |
2017-04-04 | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 1 | -10/+20 | |
Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | |||||
2017-03-08 | if_tsec: Enable FDT support | Sebastian Huber | 1 | -0/+1 | |
2017-03-08 | FDT(4): Port to RTEMS | Sebastian Huber | 1 | -0/+41 | |
2017-02-28 | Add poll() and select() support for Termios | Sebastian Huber | 1 | -1/+2 | |
2017-02-14 | Port LPC32XX Ethernet and USB OHCI to RTEMS | Kevin Kirspel | 1 | -0/+6 | |
2017-01-17 | freebsd/wlanstats: Port to FreeBSD. | Christian Mauderer | 1 | -0/+23 | |
2017-01-17 | wlan/run: Add firmware. | Christian Mauderer | 1 | -0/+6 | |
2017-01-17 | rtwn: Port to RTEMS | Christian Mauderer | 1 | -0/+172 | |
2017-01-17 | lib80211/regdomain: Port to RTEMS. | Christian Mauderer | 1 | -0/+11 | |
2017-01-17 | ifconfig/wlan, expat, lib80211: Port to RTEMS. | Christian Mauderer | 1 | -0/+45 | |
2017-01-17 | Port USB and USB WLAN. | Christian Mauderer | 1 | -4/+35 | |
2017-01-17 | firmware: Port to RTEMS. | Christian Mauderer | 1 | -0/+2 | |
2017-01-17 | Port IEEE 802.11. | Christian Mauderer | 1 | -2/+5 | |
2017-01-13 | Use thread name support | Sebastian Huber | 1 | -1/+0 | |
Update #2858. | |||||
2017-01-10 | ARP(8): Port to RTEMS | Sebastian Huber | 1 | -0/+2 | |
2017-01-10 | Update to FreeBSD head 2017-01-09 | Sebastian Huber | 1 | -0/+1 | |
Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab. | |||||
2017-01-10 | VMSTAT(8): Port to RTEMS | Sebastian Huber | 1 | -0/+2 | |
2017-01-10 | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 1 | -116/+203 | |
Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | |||||
2016-12-23 | PIPE(2): Port to RTEMS | Kevin Kirspel | 1 | -0/+2 | |
2016-11-29 | Add a RTEMS Debugger TCP remote transport. | Chris Johns | 1 | -0/+8 | |
The patch also adds support to libbsd's build system making source conditional on a configure check. The debugger support is not available on all architectures and this feature lets us test if is avaliable. | |||||
2016-11-09 | SDHCI(4): Delete | Sebastian Huber | 1 | -2/+0 | |
Delete heavily modified SDHCI(4) support. It must be re-imported from a later FreeBSD version on demand. | |||||
2016-10-13 | Remove AppleTalk support | Sebastian Huber | 1 | -19/+0 | |
Prepare update to FreeBSD 11. | |||||
2016-09-28 | usb01: Simplify test program | Sebastian Huber | 1 | -1/+1 | |
2016-09-28 | Split rtemsbsd/rtems/rtems-program.c | Sebastian Huber | 1 | -0/+1 | |
This improves garbage collection by the linker. | |||||
2016-09-28 | Split rtems-bsd-kernel-program.c | Sebastian Huber | 1 | -0/+1 | |
Separate kernel and user space parts. | |||||
2016-09-28 | Build rtems-bsd-shell-pfctl.c | Sebastian Huber | 1 | -0/+1 | |
2016-09-28 | Split rtems-bsd-shell-netcmds.c | Sebastian Huber | 1 | -1/+6 | |
2016-09-07 | Port getdomainname() to RTEMS | Sebastian Huber | 1 | -0/+1 | |
2016-08-08 | pf: Add configuration via rc.conf. | Christian Mauderer | 1 | -0/+1 | |
2016-08-04 | freebsd: Add constant ipv6 addresses from vars.c. | Christian Mauderer | 1 | -0/+1 | |
This is necessary for a configuration without IPv6. |
