* | ffec: Add checksum offload | Sebastian Huber | 2017-10-25 | 2 | -3/+53 | |
| | | | | Update #3090. | |||||
* | ffec: Add interrupt coalescing support | Sebastian Huber | 2017-10-25 | 2 | -0/+186 | |
| | | | | | | Code is an adapted from the TSEC (if_tsec) network interface driver. Update #3090. | |||||
* | ffec: Increase buffer descriptor count to 512 | Sebastian Huber | 2017-10-25 | 1 | -2/+2 | |
* | ffec: Defragment transmit mbuf only if necessary | Sebastian Huber | 2017-10-25 | 1 | -104/+139 | |
| | | | | | | | | | Use structure similar to TSEC (if_tsec) driver. The use of bus_dmamap_sync() differs these network interface drivers. This should not be the case. Update #3090. | |||||
* | ffec: Fix NULL pointer access | Sebastian Huber | 2017-10-25 | 1 | -0/+3 | |
* | ffec: Use RACC[SHIFT16] | Sebastian Huber | 2017-10-25 | 1 | -16/+35 | |
| | | | | | | | | | This avoids the move of entire receive frames to meet the alignment requirements of the IP header and so on. Add FECFLAG_RACC feature flag for this similar to the Linux driver. Update #3090. | |||||
* | Add rtems_bsd_set_if_input() | Sebastian Huber | 2017-10-23 | 2 | -0/+30 | |
* | powerpc: Fix warnings | Sebastian Huber | 2017-10-20 | 1 | -0/+9 | |
* | Import CRC32 support from FreeBSD | Sebastian Huber | 2017-10-20 | 1 | -0/+770 | |
* | blist: Import from FreeBSD | Sebastian Huber | 2017-10-20 | 2 | -0/+1201 | |
* | Fix INVARIANTS support | Sebastian Huber | 2017-10-20 | 6 | -0/+17 | |
* | ZONE(9): Use recursive lock for the UMA drain | Sebastian Huber | 2017-10-20 | 1 | -1/+1 | |
* | ZONE(9): Reduce BUCKET_MAX to 128 | Sebastian Huber | 2017-10-20 | 1 | -1/+7 | |
| | | | | Reduces the worst-case per-processor caches. | |||||
* | ZONE(9): Fix uma_zone_set_max() | Sebastian Huber | 2017-10-20 | 1 | -0/+9 | |
| | | | | Account for items provided for per-processor caches. | |||||
* | DEVICE(9): Avoid NULL pointer access | Sebastian Huber | 2017-10-20 | 1 | -0/+3 | |
* | SLEEPQUEUE(9): Update due to API changes | Sebastian Huber | 2017-10-17 | 1 | -1/+1 | |
| | | | | | Update #3117. Update #3182. | |||||
* | BPF(9): Remove RTEMS-specifics | Sebastian Huber | 2017-10-12 | 1 | -7/+0 | |
* | tcpdump: Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-10-11 | 421 | -29677/+44341 | |
| | | | | | | Update tcpdump from Git mirror commit 99a648a912e81e29d9c4c159cbbe263462f2d719 to 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | |||||
* | Update libpcap to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-10-09 | 46 | -9231/+13996 | |
| | | | | | | Update libpcap from Git mirror commit 99a648a912e81e29d9c4c159cbbe263462f2d719 to 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | |||||
* | ffec: Add wmb() to descriptor updates | Sebastian Huber | 2017-09-27 | 1 | -0/+2 | |
* | ffec: Support up to three interrupt requests | Sebastian Huber | 2017-09-27 | 1 | -18/+34 | |
* | ffec: Avoid AXI bus issues due to a MAC reset | Sebastian Huber | 2017-09-27 | 1 | -1/+8 | |
* | ffec: Add FECFLAG_AVB variant flag | Sebastian Huber | 2017-09-27 | 2 | -7/+17 | |
| | | | | | | | | | | | | | | | This flag is analogous to the Linux driver FEC_QUIRK_HAS_AVB. It indicates an FEC with support for Audio Video Bridging (AVB). This indicator is used for various other parts in the Linux driver (drivers/net/ethernet/freescale/fec_main.c). Use it to customize the receive/transmit buffer alignment. The receive buffer alignment increased to 64-bytes on the i.MX 6SoloX and i.MX 7Dual. There are no hard alignment restrictions for transmit buffers on these chips. Fix the ffec_softc::fectype type to provide enough storage for the feature flags. | |||||
* | ffec: Increase descriptor ring alignment | Sebastian Huber | 2017-09-27 | 1 | -1/+1 | |
| | | | | For optimal performance a 64-byte alignment is recommended. | |||||
* | ffec: Use explicit cache synchronization | Sebastian Huber | 2017-09-27 | 1 | -0/+7 | |
* | ffec: Support more rgmii variants | Sebastian Huber | 2017-09-27 | 1 | -0/+4 | |
* | ffec: Port to RTEMS | Sebastian Huber | 2017-09-27 | 1 | -0/+4 | |
* | ffec: Import from FreeBSD | Sebastian Huber | 2017-09-27 | 2 | -0/+2098 | |
* | Support reference counting for file descriptors | Sebastian Huber | 2017-09-15 | 4 | -25/+39 | |
| | | | | Close #3132. | |||||
* | Include missing <string.h> and <limits.h> | Sebastian Huber | 2017-08-25 | 1 | -0/+3 | |
| | | | | | | | Fix warnings. Update #2132. Update #2133. | |||||
* | openssl: Workaround for ARM-specific files | Sebastian Huber | 2017-08-23 | 2 | -0/+4 | |
| | | | | Update #3110. | |||||
* | Remove strtoimax() and strtoumax() | Sebastian Huber | 2017-08-22 | 2 | -308/+0 | |
| | | | | This is now provided by Newlib. | |||||
* | Import openssl from FreeBSD. | Sichen Zhao | 2017-08-20 | 906 | -0/+364148 | |
* | KQUEUE(2): Add missing file handler | Sebastian Huber | 2017-07-28 | 1 | -1/+4 | |
* | PIPE(2): Add missing file handler | Sebastian Huber | 2017-07-28 | 1 | -6/+78 | |
* | SOCKET(2): Add missing file handler | Sebastian Huber | 2017-07-28 | 1 | -1/+64 | |
* | ohci: Fix for BSP_USB_OTG_TRANSCEIVER_I2C_ADDR | Sebastian Huber | 2017-07-18 | 1 | -0/+5 | |
* | dev/rtwn: Import new files from FreeBSD. | Christian Mauderer | 2017-07-17 | 18 | -0/+2258 | |
* | Port am335x usb driver to RTEMS. | Sichen Zhao | 2017-07-13 | 2 | -0/+21 | |
| | | | | | | Add FDT and umass support for am335x USB driver. Now RTEMS can mount and open USB disk. | |||||
* | Import am335x usb driver file from FreeBSD. | Sichen Zhao | 2017-07-13 | 15 | -0/+7444 | |
* | libkern.h: Add ffsll() | Sebastian Huber | 2017-07-10 | 1 | -3/+3 | |
* | libkern.h: Avoid conflict with <strings.h> | Sebastian Huber | 2017-07-10 | 1 | -2/+13 | |
* | Remove unused inet_* weak references | Sebastian Huber | 2017-06-22 | 1 | -0/+2 | |
| | | | | This change requires a Newlib from 2017-06-12 or later. | |||||
* | Remove unused inet_* weak references | Sebastian Huber | 2017-06-16 | 12 | -178/+22 | |
* | Use <sys/lock.h> provided by Newlib | Sebastian Huber | 2017-06-08 | 335 | -337/+337 | |
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 674 | -4059/+738 | |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | |||||
* | Redirect FREEBSD's kern_yield to RTEMS sched_yield | Kevin Kirspel | 2017-05-19 | 1 | -1/+2 | |
* | Add bitcount inlinesfor RTEMS. These are found in FREEBSDs types.h | Kevin Kirspel | 2017-05-19 | 1 | -0/+3 | |
* | Modify FREEBSD EVDEV driver for use in RTEMS | Kevin Kirspel | 2017-05-19 | 1 | -0/+4 | |
* | Modify FREEBSD USB keyboard drivers for use in RTEMS | Kevin Kirspel | 2017-05-19 | 1 | -0/+2 | |
