* | Added rtems_bsd_thread0_ucred as a single global ucred. | Jennifer Averett | 2012-05-01 | 3 | -0/+24 |
* | Added a define of 0 for bootverbose. | Jennifer Averett | 2012-05-01 | 1 | -0/+5 |
* | Added globals for hints and hintmode. | Jennifer Averett | 2012-05-01 | 1 | -0/+4 |
* | Added back in kqueue_schedtask() and kqueue_wakeup() | Jennifer Averett | 2012-04-26 | 1 | -2/+4 |
* | Remove proc0 creation | Sebastian Huber | 2012-04-26 | 5 | -61/+218 |
* | Remove rusage dependencies | Christian Mauderer | 2012-04-26 | 3 | -1/+12 |
* | Added in uma_find_refcnt() and vtoslab() | Jennifer Averett | 2012-04-19 | 2 | -3/+5 |
| | | | | | The vtoslab returns NULL for now which will cause a fault when the code runs. | ||||
* | Merged rtems-bsd-uma.c back into uma_core.c | Jennifer Averett | 2012-04-19 | 1 | -0/+3439 |
| | | | | The majority of this file was the same as the freebsd file uma_core.c. | ||||
* | Add missing files | Sebastian Huber | 2012-04-19 | 2 | -0/+2154 |
* | Hide unused section | Sebastian Huber | 2012-04-19 | 1 | -0/+4 |
| | | | | | Since "cold" is defined to 0 this code disappears if optimization is enabled. | ||||
* | Merged the rtems version of resource back to kern_resource and added method ↵ | Jennifer Averett | 2012-04-18 | 1 | -0/+14 |
| | | | | to resolve linker errors. | ||||
* | Commented out calls to pin and unpin. | Jennifer Averett | 2012-04-18 | 1 | -0/+4 |
* | Hide device sysctl and resource functions | Sebastian Huber | 2012-04-18 | 1 | -11/+82 |
* | Remove superfluous include, format | Sebastian Huber | 2012-04-18 | 1 | -8/+3 |
* | Move __bswap64() | Sebastian Huber | 2012-04-18 | 1 | -16/+0 |
| | | | | | Add copyright notice of FreeBSD "sys/powerpc/include/endian.h". Change license to BSD. | ||||
* | Moved uio_yield implementation into bsd file. | Jennifer Averett | 2012-04-18 | 1 | -3/+10 |
* | Add generic implementation of __bswap64 | Joel Sherrill | 2012-04-18 | 1 | -0/+16 |
* | Moved rtems-bsd-cyclecount.c to cpu.h | Jennifer Averett | 2012-04-18 | 1 | -1/+0 |
* | Hide most error number definitions | Sebastian Huber | 2012-04-18 | 1 | -0/+2 |
* | Add parts of the UCRED(9) implementation | Sebastian Huber | 2012-04-18 | 2 | -2/+10 |
* | Added chgsbsize() method. | Jennifer Averett | 2012-04-17 | 1 | -0/+1385 |
* | Added back in a couple of methods. | Jennifer Averett | 2012-04-17 | 1 | -2/+2 |
* | Commented out unused methods to resolve linker errors. | Jennifer Averett | 2012-04-17 | 1 | -0/+8 |
* | Add missing header file | Sebastian Huber | 2012-04-17 | 1 | -0/+43 |
* | Add PCI and PCIB interface files | Sebastian Huber | 2012-04-17 | 4 | -1/+655 |
* | Use MIPS in_cksum.c for SPARC | Sebastian Huber | 2012-04-17 | 1 | -0/+5 |
* | Added method to help resolve linker issue. | Jennifer Averett | 2012-04-17 | 1 | -1/+1 |
* | Added methods to resolve linker errors. | Jennifer Averett | 2012-04-17 | 1 | -0/+1866 |
* | Added variables from kern_environment to remove linker errors. | Jennifer Averett | 2012-04-17 | 1 | -0/+585 |
* | Addded resource_XXX methods to resolve linker issues. | Jennifer Averett | 2012-04-16 | 1 | -0/+389 |
* | Added thread0 variable to resolve linker error. | Jennifer Averett | 2012-04-16 | 1 | -0/+2 |
* | Add libkern/fls.c for fls() - Find last bit set | Joel Sherrill | 2012-04-16 | 1 | -0/+50 |
* | Implemented a version of rmlock using rwlock. | Jennifer Averett | 2012-04-16 | 3 | -0/+1067 |
* | Added in knote_enqueue. | Jennifer Averett | 2012-04-06 | 1 | -0/+4 |
* | Added in a header file and some defines to resolve linker errors. | Jennifer Averett | 2012-04-05 | 2 | -2/+67 |
* | Comment out unused methods that were generating linker errors. | Jennifer Averett | 2012-04-05 | 1 | -0/+3 |
* | Added uipc_XXx methods. | Jennifer Averett | 2012-04-05 | 1 | -0/+300 |
* | Added pci_XXX methods. | Jennifer Averett | 2012-04-05 | 2 | -0/+4240 |
* | Added tcp_hc_XXX methods. | Jennifer Averett | 2012-04-05 | 1 | -0/+693 |
* | Added rmon_XXX methods. | Jennifer Averett | 2012-04-05 | 1 | -0/+973 |
* | Added sbuf_XXX methods. | Jennifer Averett | 2012-04-05 | 1 | -0/+594 |
* | Added knlist_XXX and knote_XXX methods. | Jennifer Averett | 2012-04-05 | 1 | -0/+2194 |
* | Added ratecheck methods as part of RealTek Nic integration. | Jennifer Averett | 2012-04-05 | 1 | -0/+1512 |
* | Add _ALIGN macro based on one in libmisc/shell/fts.c | Joel Sherrill | 2012-04-04 | 1 | -0/+12 |
* | Enable copyinuio | Joel Sherrill | 2012-04-04 | 1 | -0/+3 |
* | kern_subr.c - Enable uiomove for rtems | Joel Sherrill | 2012-04-04 | 1 | -0/+3 |
* | Added cr_XXX methods to resolve linker errors with RealTek Nic. | Jennifer Averett | 2012-04-04 | 1 | -0/+2217 |
* | Add methods to reaolve linker issues. | Jennifer Averett | 2012-04-02 | 1 | -0/+67 |
* | Add globals to resolve linker conflicts. | Jennifer Averett | 2012-04-02 | 1 | -0/+405 |
* | Add freebsd/machine/elf.h as empty. Improve message for empty file. | Joel Sherrill | 2012-03-30 | 1 | -0/+1 |
