* | Add device tree support for Altera/Intel Cyclone V | Sebastian Huber | 2018-02-06 | 4 | -39/+273 | |
| | | | | Close #3290. | |||||
* | SLEEPQUEUE(9): Update due to API changes | Sebastian Huber | 2018-02-05 | 1 | -1/+1 | |
| | | | | Update #3264. | |||||
* | ZONE(9): Avoid function call overhead | Sebastian Huber | 2018-01-19 | 1 | -1/+3 | |
* | DEVICE(9): Fix __BUS_ACCESSOR() | Sebastian Huber | 2018-01-08 | 1 | -2/+0 | |
* | openssl: Remove superfluous file | Sebastian Huber | 2018-01-08 | 1 | -137/+0 | |
* | at91_mci: Fix for 32k buffer. | Christian Mauderer | 2017-11-17 | 1 | -0/+11 | |
* | Revert "RWLOCK(9): Add reader/writer lock implementation" | Sebastian Huber | 2017-11-17 | 1 | -2/+2 | |
| | | | | | | This was accidentally committed. This reverts commit 97a98f6cd767b3a68279890488c7b451788f84f4. | |||||
* | Revert "SX(9): Implement with reader/writer lock" | Sebastian Huber | 2017-11-17 | 2 | -2/+5 | |
| | | | | | | This was accidentally committed. This reverts commit cc7a8d87e7307db738bf39ab1ca3ce1053f1c163. | |||||
* | SX(9): Implement with reader/writer lock | Sebastian Huber | 2017-11-16 | 2 | -5/+2 | |
* | RWLOCK(9): Add reader/writer lock implementation | Sebastian Huber | 2017-11-16 | 1 | -2/+2 | |
* | Fix file descriptor reference counting in accept() | Sebastian Huber | 2017-11-15 | 1 | -0/+2 | |
| | | | | Update #3132. | |||||
* | Fix warning | Sebastian Huber | 2017-11-10 | 1 | -0/+2 | |
* | tcpdump: Fix import/export | Sebastian Huber | 2017-11-10 | 167 | -0/+167 | |
* | wpa_supplicant: Use arc4random instead of getentropy. | Christian Mauderer | 2017-11-10 | 1 | -2/+3 | |
* | Update wpa_supplicant/hostapd for 2017-01 vulnerability release. | gordon | 2017-11-10 | 13 | -53/+240 | |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | hostapd: Avoid key reinstallation in FT handshake Prevent reinstallation of an already in-use group key Extend protection of GTK/IGTK reinstallation of WNM-Sleep Mode cases Fix TK configuration to the driver in EAPOL-Key 3/4 retry case Prevent installation of an all-zero TK Fix PTK rekeying to generate a new ANonce TDLS: Reject TPK-TK reconfiguration WNM: Ignore Key Data in WNM Sleep Mode Response frame if no PMF in use WNM: Ignore WNM-Sleep Mode Response if WNM-Sleep Mode has not been used WNM: Ignore WNM-Sleep Mode Response without pending request FT: Do not allow multiple Reassociation Response frames TDLS: Ignore incoming TDLS Setup Response retries Submitted by: jhb Obtained from: https://w1.fi/security/2017-01/ (against later version) Security: FreeBSD-SA-17:07 Security: CERT VU#228519 Security: CVE-2017-13077 Security: CVE-2017-13078 Security: CVE-2017-13079 Security: CVE-2017-13080 Security: CVE-2017-13081 Security: CVE-2017-13082 Security: CVE-2017-13086 Security: CVE-2017-13087 Security: CVE-2017-13088 Differential Revision: https://reviews.freebsd.org/D12693 | |||||
* | wpa: Port to new files to RTEMS. | Christian Mauderer | 2017-11-10 | 2 | -0/+4 | |
* | wpa: Import all files for KRACK patch. | Christian Mauderer | 2017-11-10 | 12 | -0/+10635 | |
* | at91_mci: Add timing to read_ivar. | Christian Mauderer | 2017-11-10 | 1 | -0/+10 | |
* | freebsd/bus: Check return value of bus_accessor. | Christian Mauderer | 2017-11-10 | 1 | -0/+23 | |
* | at91_mci: Port to RTEMS and adapt for atsam. | Christian Mauderer | 2017-11-10 | 2 | -1/+279 | |
* | at91_mci: Import from FreeBSD | Sebastian Huber | 2017-11-10 | 5 | -0/+1875 | |
* | saf1761_otg: Port to RTEMS. | Christian Mauderer | 2017-11-10 | 2 | -4/+84 | |
* | usb/saf1761: Import from FreeBSD. | Christian Mauderer | 2017-11-10 | 4 | -0/+4435 | |
| | | | | | | | Import the files for the SAF1761 USB controller from FreeBSD commit: 642b174daddbd0efd9bb5f242c43f4ab4db6869f Tue Apr 4 04:01:02 2017 | |||||
* | wpa_supplicant: Fix getopt. | Christian Mauderer | 2017-11-10 | 1 | -0/+11 | |
* | wpa_supplicant: Include rtems-bsd-program.h. | Christian Mauderer | 2017-11-10 | 2 | -0/+10 | |
* | wpa_supplicant: Add lock. | Christian Mauderer | 2017-11-10 | 1 | -1/+5 | |
* | wpa_supplicant: Move forking command into own file. | Christian Mauderer | 2017-11-10 | 1 | -65/+0 | |
| | | | | | The malloc wrapper must not be disabled. Therefore the command that uses malloc without a wrapper has to live in another file. | |||||
* | Add wpa_supplicant_fork command. | Sichen Zhao | 2017-11-10 | 1 | -0/+65 | |
| | | | | Add fork command for wpa supplicant to start a new task. | |||||
* | Port wpa supplicant to RTEMS. | Sichen Zhao | 2017-11-10 | 3 | -1/+34 | |
| | | | | Add wpa_supplicant lib support and shell command support in RTEMS. | |||||
* | Import wpa from FreeBSD | Sichen Zhao | 2017-11-10 | 225 | -0/+127499 | |
* | Fix build for non-FDT platforms | Sebastian Huber | 2017-11-10 | 1 | -0/+5 | |
* | Import BBB sd driver files from FreeBSD. | Sichen Zhao | 2017-11-10 | 10 | -0/+5100 | |
* | Disable HHOOK(9) support for sockets | Sebastian Huber | 2017-11-10 | 1 | -0/+10 | |
| | | | | | Support was only partly disabled leading to NULL pointer accesses. Disable it completely. | |||||
* | Fix reference counting for file descriptors | Sebastian Huber | 2017-11-10 | 5 | -1/+29 | |
* | ffec: Fix comment | Sebastian Huber | 2017-10-26 | 1 | -4/+4 | |
| | | | | Update #3090. | |||||
* | ffec: Add checksum offload | Sebastian Huber | 2017-10-25 | 2 | -3/+53 | |
* | ffec: Add interrupt coalescing support | Sebastian Huber | 2017-10-25 | 2 | -0/+186 | |
| | | | | | | Code is an adapted from the TSEC (if_tsec) network interface driver. Update #3090. | |||||
* | ffec: Increase buffer descriptor count to 512 | Sebastian Huber | 2017-10-25 | 1 | -2/+2 | |
* | ffec: Defragment transmit mbuf only if necessary | Sebastian Huber | 2017-10-25 | 1 | -104/+139 | |
| | | | | | | | | | Use structure similar to TSEC (if_tsec) driver. The use of bus_dmamap_sync() differs these network interface drivers. This should not be the case. Update #3090. | |||||
* | ffec: Fix NULL pointer access | Sebastian Huber | 2017-10-25 | 1 | -0/+3 | |
* | ffec: Use RACC[SHIFT16] | Sebastian Huber | 2017-10-25 | 1 | -16/+35 | |
| | | | | | | | | | This avoids the move of entire receive frames to meet the alignment requirements of the IP header and so on. Add FECFLAG_RACC feature flag for this similar to the Linux driver. Update #3090. | |||||
* | Add rtems_bsd_set_if_input() | Sebastian Huber | 2017-10-23 | 2 | -0/+30 | |
* | powerpc: Fix warnings | Sebastian Huber | 2017-10-20 | 1 | -0/+9 | |
* | Import CRC32 support from FreeBSD | Sebastian Huber | 2017-10-20 | 1 | -0/+770 | |
* | blist: Import from FreeBSD | Sebastian Huber | 2017-10-20 | 2 | -0/+1201 | |
* | Fix INVARIANTS support | Sebastian Huber | 2017-10-20 | 6 | -0/+17 | |
* | ZONE(9): Use recursive lock for the UMA drain | Sebastian Huber | 2017-10-20 | 1 | -1/+1 | |
* | ZONE(9): Reduce BUCKET_MAX to 128 | Sebastian Huber | 2017-10-20 | 1 | -1/+7 | |
| | | | | Reduces the worst-case per-processor caches. | |||||
* | ZONE(9): Fix uma_zone_set_max() | Sebastian Huber | 2017-10-20 | 1 | -0/+9 | |
| | | | | Account for items provided for per-processor caches. | |||||
* | DEVICE(9): Avoid NULL pointer access | Sebastian Huber | 2017-10-20 | 1 | -0/+3 | |
