* | NVME(4): Add NVME_GET_NAMESPACE IO control | Sebastian Huber | 2019-11-13 | 2 | -0/+8 |
| | | | | Update #3821. | ||||
* | NVME(4): Enable per-CPU IO queues | Sebastian Huber | 2019-11-13 | 1 | -0/+7 |
* | NVME(4): Add support for SGL | Sebastian Huber | 2019-11-13 | 4 | -0/+118 |
* | NVME(4): Add SGL descriptor | Sebastian Huber | 2019-11-13 | 1 | -0/+24 |
* | NVME(4): Optimize data transfer | Sebastian Huber | 2019-11-13 | 2 | -0/+56 |
* | NVME(4): Big endian support | Sebastian Huber | 2019-11-13 | 1 | -5/+5 |
* | NVME(4): Port to RTEMS | Sebastian Huber | 2019-11-13 | 6 | -0/+30 |
* | NVME(4): Import from FreeBSD | Sebastian Huber | 2019-11-13 | 10 | -0/+5570 |
* | Add support for EARLY_COUNTER | Sebastian Huber | 2019-09-25 | 2 | -0/+7 |
* | Remove obsolete header files | Sebastian Huber | 2019-09-25 | 1 | -205/+0 |
* | Fix pgsigio() warnings | Sebastian Huber | 2019-09-25 | 1 | -0/+14 |
* | Update to FreeBSD stable/12 2019-09-23 | Sebastian Huber | 2019-09-23 | 299 | -2216/+5579 |
| | | | | Git mirror commit 7e8d1444023128d34fb9aa4e4515928a4f794d1b. | ||||
* | Add pselect() | Sebastian Huber | 2019-09-23 | 1 | -0/+37 |
* | PCI(4): Import missing file | Sebastian Huber | 2019-09-23 | 1 | -0/+84 |
* | PCI(4): Disable unsupported features | Sebastian Huber | 2019-09-23 | 1 | -0/+10 |
* | PCI(4): Add big endian support | Sebastian Huber | 2019-09-23 | 1 | -0/+8 |
* | CONFIG_INTRHOOK(9): Call handlers after boot | Sebastian Huber | 2019-09-23 | 1 | -1/+15 |
| | | | | | This enables adding drivers on demand which use this service after initialization. | ||||
* | C++ compatibility for <dev/pci/pcivar.h> | Sebastian Huber | 2019-09-23 | 1 | -1/+1 |
* | C++ compatibility for kernel space <sys/sysctl.h> | Sebastian Huber | 2019-09-23 | 1 | -0/+2 |
* | libsodium: Disable unused function | Sebastian Huber | 2019-08-27 | 1 | -0/+2 |
* | tty.c: Disable unused functions | Sebastian Huber | 2019-08-27 | 1 | -4/+2 |
* | pf_ioctl.c: Disable superfluous unload support | Sebastian Huber | 2019-08-27 | 1 | -0/+4 |
* | kern_intr.c: Disable unused functions | Sebastian Huber | 2019-08-27 | 1 | -3/+1 |
* | Remove superfluous support for preloaded modules | Sebastian Huber | 2019-08-27 | 2 | -313/+2 |
* | Update to FreeBSD stable/12 2019-08-26 | Sebastian Huber | 2019-08-26 | 49 | -206/+1035 |
| | | | | Git mirror commit 621e7bafbf6857451f23ba11b0495c7ac69aff89. | ||||
* | SLEEPQUEUE(9): Optimize sleepq_set_timeout_sbt() | Sebastian Huber | 2019-08-26 | 1 | -2/+3 |
| | | | | Avoid an extra ISR disable/enable in SMP configurations. | ||||
* | Update to FreeBSD stable/12 2019-07-09 | Sebastian Huber | 2019-07-09 | 32 | -690/+700 |
| | | | | Git mirror commit 3427c3416aa3c0f25124070959cca78024b94d85. | ||||
* | SLEEPQUEUE(9): Fix timeout handling | Sebastian Huber | 2019-07-05 | 1 | -2/+4 |
* | Import missing header file | Sebastian Huber | 2019-06-28 | 1 | -0/+48 |
* | Update to FreeBSD stable/12 2019-06-26 | Sebastian Huber | 2019-06-26 | 17 | -126/+278 |
| | | | | Git mirror commit aa83598855d14cdbf7aef6b05d0617e90f87ca2f. | ||||
* | Update to FreeBSD stable/12 2019-06-05 | Sebastian Huber | 2019-06-05 | 361 | -7501/+34490 |
| | | | | Git mirror commit 78576620f2689e23144a1cf1bf55106cc6abe2b7. | ||||
* | Add riscv support | Sebastian Huber | 2019-05-23 | 1 | -0/+83 |
* | Separate libbsd and RTEMS clock ticks | Sebastian Huber | 2019-05-15 | 5 | -14/+4 |
* | Fix USB_DEBUG redefinition warnings | Sebastian Huber | 2019-05-15 | 1 | -0/+12 |
* | Add hostname related sysctls conditionally | Sebastian Huber | 2019-05-13 | 1 | -0/+5 |
| | | | | This helps to the reduce code size for USB only use cases. | ||||
* | Use static inline functions for jail and prison | Sebastian Huber | 2019-05-13 | 1 | -0/+202 |
| | | | | This helps the compiler to optimize away dead code. | ||||
* | IFCONFIG(8): Fix write to const string | Sebastian Huber | 2019-05-13 | 1 | -0/+6 |
* | Update due to API changes | Sebastian Huber | 2019-04-11 | 1 | -2/+2 |
* | BPF(9): Disable legacy timestamp support | Sebastian Huber | 2019-03-29 | 1 | -0/+7 |
* | BPF(9): Fix timestamps | Sebastian Huber | 2019-03-28 | 1 | -0/+1 |
* | Update to FreeBSD stable/12 2019-03-27 | Sebastian Huber | 2019-03-28 | 28 | -69/+748 |
| | | | | Git mirror commit 43a38f188ca2e936ec78104c30ea3e24d9c1606b. | ||||
* | openssl/apps: Add missing newline | Sebastian Huber | 2019-03-28 | 52 | -0/+52 |
| | | | | This is necessary to get a reversible import from FreeBSD. | ||||
* | bin/openssl: Port to RTEMS. | Christian Mauderer | 2019-03-28 | 107 | -0/+1152 |
* | bin/openssl: Import from FreeBSD. | Christian Mauderer | 2019-03-28 | 58 | -0/+43004 |
* | Update to FreeBSD stable/12 2019-03-11 | Sebastian Huber | 2019-03-11 | 163 | -3744/+5478 |
| | | | | Git mirror commit 735fe7a0a5f9c265040e2e6654a01b081d6354f1. | ||||
* | tcpdump: Move static variables to special section | Sebastian Huber | 2019-03-11 | 6 | -0/+39 |
| | | | | This fixes some issues if tcpdump is invoked a second time. | ||||
* | tcpdump: Remove superfluous static variable | Sebastian Huber | 2019-03-11 | 1 | -3/+1 |
* | tcpdump: Use stack variables | Sebastian Huber | 2019-03-11 | 1 | -2/+2 |
* | tcpdump: Constify | Sebastian Huber | 2019-03-11 | 4 | -13/+13 |
* | C++ compatibility for some kernel-space headers | Sebastian Huber | 2019-02-18 | 3 | -13/+13 |
