* | NVME(4): Big endian support | Sebastian Huber | 2019-11-13 | 1 | -5/+5 |
| | | | | Update #3821. | ||||
* | NVME(4): Port to RTEMS | Sebastian Huber | 2019-11-13 | 8 | -0/+63 |
* | NVME(4): Import from FreeBSD | Sebastian Huber | 2019-11-13 | 10 | -0/+5567 |
* | Update to FreeBSD head 2019-09-24 | Sebastian Huber | 2019-11-13 | 886 | -17799/+38652 |
| | | | | Git mirror commit 6b0307a0a5184339393f555d5d424190d8a8277a. | ||||
* | Add support for EARLY_COUNTER | Sebastian Huber | 2019-09-25 | 2 | -0/+7 |
* | Remove obsolete header files | Sebastian Huber | 2019-09-24 | 1 | -205/+0 |
* | Fix pgsigio() warnings | Sebastian Huber | 2019-09-24 | 1 | -0/+14 |
* | Add pselect() | Sebastian Huber | 2019-09-23 | 1 | -0/+37 |
* | PCI(4): Import missing file | Sebastian Huber | 2019-09-23 | 1 | -0/+84 |
* | PCI(4): Disable unsupported features | Sebastian Huber | 2019-09-23 | 1 | -0/+10 |
* | PCI(4): Add big endian support | Sebastian Huber | 2019-09-23 | 1 | -0/+8 |
* | CONFIG_INTRHOOK(9): Call handlers after boot | Sebastian Huber | 2019-09-23 | 1 | -1/+15 |
| | | | | | This enables adding drivers on demand which use this service after initialization. | ||||
* | C++ compatibility for <dev/pci/pcivar.h> | Sebastian Huber | 2019-09-23 | 1 | -1/+1 |
* | C++ compatibility for kernel space <sys/sysctl.h> | Sebastian Huber | 2019-09-23 | 1 | -0/+2 |
* | rtemsbsd: remove dead code fb.c | Vijay Kumar Banerjee | 2019-08-31 | 1 | -762/+0 |
* | libsodium: Disable unused function | Sebastian Huber | 2019-08-27 | 1 | -0/+2 |
* | tty.c: Disable unused functions | Sebastian Huber | 2019-08-27 | 1 | -4/+2 |
* | pf_ioctl.c: Disable superfluous unload support | Sebastian Huber | 2019-08-27 | 1 | -0/+4 |
* | kern_intr.c: Disable unused functions | Sebastian Huber | 2019-08-27 | 1 | -2/+0 |
* | Remove superfluous support for preloaded modules | Sebastian Huber | 2019-08-27 | 2 | -313/+2 |
* | SLEEPQUEUE(9): Optimize sleepq_set_timeout_sbt() | Sebastian Huber | 2019-08-26 | 1 | -2/+3 |
| | | | | Avoid an extra ISR disable/enable in SMP configurations. | ||||
* | am335x display drivers: Import from FreeBSD | Vijay Kumar Banerjee | 2019-08-11 | 5 | -0/+1547 |
* | fbd: Port to RTEMS | Vijay Kumar Banerjee | 2019-08-11 | 1 | -0/+4 |
* | fbd: Import from FreeBSD | Vijay Kumar Banerjee | 2019-08-11 | 10 | -0/+3621 |
* | TDA19988: Import from FreeBSD | Vijay Kumar Banerjee | 2019-08-11 | 12 | -0/+3362 |
* | Pinmux : Import from FreeBSD | Vijay Kumar Banerjee | 2019-08-11 | 6 | -0/+1138 |
* | Add mmap | Vijay Kumar Banerjee | 2019-07-27 | 2 | -5/+5 |
* | SLEEPQUEUE(9): Fix timeout handling | Sebastian Huber | 2019-07-05 | 1 | -2/+4 |
* | i2c tool : port to RTEMS | Vijay Kumar Banerjee | 2019-06-29 | 1 | -0/+35 |
* | i2c tool : Import from FreeBSD | Vijay Kumar Banerjee | 2019-06-29 | 1 | -0/+733 |
* | iicbus: Import from FreeBSD | Vijay Kumar Banerjee | 2019-06-29 | 7 | -0/+1970 |
* | Add riscv support | Sebastian Huber | 2019-05-23 | 1 | -0/+83 |
* | Separate libbsd and RTEMS clock ticks | Sebastian Huber | 2019-05-15 | 5 | -14/+4 |
* | Fix USB_DEBUG redefinition warnings | Sebastian Huber | 2019-05-13 | 1 | -0/+12 |
* | Add hostname related sysctls conditionally | Sebastian Huber | 2019-05-13 | 1 | -0/+5 |
| | | | | This helps to the reduce code size for USB only use cases. | ||||
* | Use static inline functions for jail and prison | Sebastian Huber | 2019-05-13 | 1 | -0/+202 |
| | | | | This helps the compiler to optimize away dead code. | ||||
* | IFCONFIG(8): Fix write to const string | Sebastian Huber | 2019-05-13 | 1 | -0/+6 |
* | Update due to API changes | Sebastian Huber | 2019-04-11 | 1 | -2/+2 |
* | Import FreeBSD license files. | Christian Mauderer | 2019-04-04 | 9 | -0/+404 |
* | Remove pcap_version.h | Vijay Kumar Banerjee | 2019-04-02 | 1 | -13/+0 |
* | BPF(9): Disable legacy timestamp support | Sebastian Huber | 2019-03-29 | 1 | -0/+7 |
* | BPF(9): Fix timestamps | Sebastian Huber | 2019-03-28 | 1 | -0/+1 |
* | openssl/apps: Add missing newline | Sebastian Huber | 2019-03-28 | 52 | -0/+52 |
| | | | | This is necessary to get a reversible import from FreeBSD. | ||||
* | bin/openssl: Port to RTEMS. | Christian Mauderer | 2019-03-27 | 108 | -475/+1152 |
* | bin/openssl: Import from FreeBSD. | Christian Mauderer | 2019-03-26 | 59 | -0/+43322 |
* | tcpdump: Move static variables to special section | Sebastian Huber | 2019-03-11 | 6 | -0/+39 |
| | | | | This fixes some issues if tcpdump is invoked a second time. | ||||
* | tcpdump: Remove superfluous static variable | Sebastian Huber | 2019-03-11 | 1 | -3/+1 |
* | tcpdump: Use stack variables | Sebastian Huber | 2019-03-11 | 1 | -2/+2 |
* | tcpdump: Constify | Sebastian Huber | 2019-03-11 | 4 | -13/+13 |
* | C++ compatibility for some kernel-space headers | Sebastian Huber | 2019-02-18 | 3 | -13/+13 |
