Some drivers can't easily work with buffers that are not cache aligned
and have an arbitrary length. Therefore use an aligned malloc instead.
This is basically the same as the patch for ping.
Update #4360
The TI driver has been moved to RTEMS so the driver can be removed
from libBSD.
The following files have been removed from libBSD and moved to
RTEMS.
1) ti/am335x/am335x_scm_padconf.c
2) ti/am335x/am335x_scm_padconf.h
3) ti/ti_pinmux.c
4) ti/ti_pinmux.h
Update #3784
Updates #4264
hmac_md5 is defined in dhcpcd and in wpa supplicant.
With the previous fix, it could happen that the end of the packet hasn't
been flushed. For example assume the following addresses:
ds_addr: 0x81c804A
ds_len: 0x57
In that case the data ends at 0x81c80a1. But due to the rounding the
area from 0x81c8040 to 0x81c80a0 would have been flushed.
This fix now first calculates the start and end address, aligns these
addresses and then recalculates the len that has to be flushed.
Update #4180
Update #3910.
Update the host frame interval after a device connection. Select also
the FS/LS PHY clock. It is not clear if this works on all platforms.
Update #3910.
- The files in the i386 directory have been moved to common x86 directories by FreeBSD:
- freebsd/sys/i386/include/machine/bus.h
- freebsd/sys/x86/include/machine/legacyvar.h
- freebsd/sys/x86/include/machine/specialreg.h
- Add header files in rtemsbsd directory to direct compiler to new files
- cpusets and SMP are currently not supported in libbsd for RTEMS
- Disable the ifc_cpus context variable and replace its usage,
essentially hard-coding for cpu 0
- callout_reset_on takes a cpu which is ignored by the subsequent call
to callout_reset_sbt_on in RTEMS.
- The macro is redefined to discard the cpu argument directly which
enables uses of it with cpu-dependent variables (disabled in
RETMS) without further changes, e.g. in iflib.c.
Some targets support only flushing or invalidating complete cache lines.
In this cases misaligned buffers might lead to unexpected results. This
patch adds a flag that allows drivers to signal to the bus dma driver
that it is OK to round a buffer to the next full cache line. That's for
example necessary if a driver wants to send out 14 byte via a USB DMA.
Only the driver knows whether these 14 bytes are located in an otherwise
unused cache line aligned buffer.
Update 3869
There is a bug in the #ifdef regarding FDT so this file hasn't been
compiled. If that bug is solved, the driver doesn't work for some other
reason.
With the FDT-bug the driver hasn't been used by anyone. So just remove
it again.
Update #3869.
Update #3869.
This is not a nice solution but it should work on all chips. As soon as
FreeBSD has a nice solution via the USB PHY driver, this should be
replaced.
Update #3869.
Update #3869.
Update #3869.
Update #3869.
Update #3869.
Update #3869.
Update #3869.
Some BSPs have a cache-coherent memory area, however, it should not be
used for the USB controller.
The rtems_bsd_mmcsd_attach_worker acquired the bus without releasing it.
If a MMC device has multiple hardware partitions (like eMMC which
typically has at least one boot partition) the
rtems_bsd_mmcsd_attach_worker would try to acquire the bus multiple
times. This doesn't work.
Doing it right would mean to acquire and release the bus for each
access which would have an performance impact. Beneath that it would
mean that partition switching has to be supported by the RTEMS code too.
There is currently no known use case where the access would be
necessary. Therefore this patch prefers the performance and just avoids
all further hardware partitions.
Update #3821.
- Update imported files to compile rtems-libbsd for i386 based BSPs
- Currently does not support the option "dev_nic_e1000 = on"
- Files needed to make rtems-libbsd build again for i386
Update #3798.
Update #3821.
Update #3821.
Update #3821.
Update #3821.
Update #3821.
Update #3821.
Update #3821.
Update #3821.
