* | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-04-04 | 512 | -31231/+24243 |
| | | | | Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | Fix SOCK_CLOEXEC with socket() and socketpair() | Sebastian Huber | 2017-03-14 | 1 | -4/+0 |
| | | | | | Remove SOCK_CLOEXEC flag to get a valid socket type, e.g. to avoid a EPROTOTYPE in case of socket(..., SOCK_DGRAM | SOCK_CLOEXEC, ...). | ||||
* | if_tsec: Enable FDT support | Sebastian Huber | 2017-03-08 | 1 | -2/+0 |
* | FDT(4): Port to RTEMS | Sebastian Huber | 2017-03-08 | 3 | -0/+21 |
* | FDT(4): Import from FreeBSD | Sebastian Huber | 2017-03-08 | 16 | -0/+5048 |
* | Provide strtoq() and strtouq() | Sebastian Huber | 2017-03-06 | 1 | -0/+19 |
* | NETSTAT(1): Disable unused functions | Sebastian Huber | 2017-03-06 | 1 | -0/+4 |
* | Disable unused pfil_try_rlock() | Sebastian Huber | 2017-03-06 | 1 | -0/+2 |
* | Provide sbuf_hexdump() | Sebastian Huber | 2017-03-06 | 1 | -1/+1 |
* | Avoid kern_unsetenv() | Sebastian Huber | 2017-03-06 | 1 | -0/+4 |
* | SLEEPQUEUE(9): Fix absolute timeouts | Sebastian Huber | 2017-02-28 | 1 | -5/+24 |
| | | | | | | | | The FreeBSD kernel timeouts are always based on the uptime. Thus, we have to use the relative watchdog. C_ABSOLUTE just means that the timeout value is already an uptime value. https://lists.freebsd.org/pipermail/freebsd-hackers/2017-February/050572.html | ||||
* | SYSCTL(8): Fix command line option processing | Sebastian Huber | 2017-02-14 | 1 | -0/+9 |
* | Port LPC32XX Ethernet and USB OHCI to RTEMS | Kevin Kirspel | 2017-02-14 | 4 | -2/+189 |
* | Adding LPC32XX ethernet driver support | Kevin Kirspel | 2017-02-14 | 5 | -0/+2307 |
* | Add ordered Nexus devices | Kevin Kirspel | 2017-02-14 | 1 | -1/+5 |
| | | | | | Add support for ordering the initialization of Nexus devices. This can be used to make sure a device is initialized before a dependant device. | ||||
* | SLEEPQUEUE(9): Add wmesg to thread wait info | Sebastian Huber | 2017-01-31 | 2 | -2/+5 |
* | rtems-bsd-mutex: Use thread queue name | Sebastian Huber | 2017-01-31 | 2 | -0/+4 |
* | userspace tools: Regenerate headers. | Christian Mauderer | 2017-01-17 | 20 | -30/+29 |
* | freebsd/wlanstats: Port to FreeBSD. | Christian Mauderer | 2017-01-17 | 6 | -0/+94 |
* | freebsd/wlanstats: Import from FreeBSD. | Christian Mauderer | 2017-01-17 | 5 | -0/+1719 |
* | rtwn: Port to RTEMS | Christian Mauderer | 2017-01-17 | 1 | -0/+3 |
* | rtwn: Import from FreeBSD. | Christian Mauderer | 2017-01-17 | 148 | -0/+26962 |
* | lib80211/regdomain: Port to RTEMS. | Christian Mauderer | 2017-01-17 | 1 | -0/+19 |
* | lib80211/regdomain: Import from FreeBSD. | Christian Mauderer | 2017-01-17 | 1 | -9/+0 |
* | ifconfig/wlan, expat, lib80211: Port to RTEMS. | Christian Mauderer | 2017-01-17 | 6 | -2/+57 |
* | ifconfig/wlan, expat, lib80211: Import from FreeBSD. | Christian Mauderer | 2017-01-17 | 22 | -154/+15124 |
* | Port USB and USB WLAN. | Christian Mauderer | 2017-01-17 | 1 | -0/+3 |
* | Import USB and USB WLAN from FreeBSD. | Christian Mauderer | 2017-01-17 | 52 | -0/+53856 |
* | firmware: Port to RTEMS. | Christian Mauderer | 2017-01-17 | 1 | -1/+11 |
* | firmware: Import from FreeBSD. | Christian Mauderer | 2017-01-17 | 2 | -0/+592 |
* | Import IEEE 802.11 from FreeBSD. | Christian Mauderer | 2017-01-17 | 64 | -4179/+11199 |
* | Use thread name support | Sebastian Huber | 2017-01-13 | 2 | -1/+6 |
| | | | | Update #2858. | ||||
* | ROUTE(8): Disable routing socket timeout support | Sebastian Huber | 2017-01-11 | 2 | -1/+12 |
| | | | | | | | | | | | | | | FIXME: This reverts the following change in FreeBSD. commit 76a39ff8dc5e1f7bc8a065115ec3837761ed0600 Author: ae <ae@FreeBSD.org> Date: Wed Jul 27 08:26:34 2016 +0000 Due to dropped mbuf in netisr queue route(8) can fall into infinity loop of reading the rtsock's feed. When it used by some scripts, this leads to growing number of not finished route(8) instances and thus growing number of rtsock consumers. Add SIGALRM handler to prevent this. | ||||
* | pf: Some fixes after the update | Sebastian Huber | 2017-01-10 | 3 | -0/+5 |
* | Remove obsolete PF files | Sebastian Huber | 2017-01-10 | 17 | -27112/+0 |
* | ARP(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 4 | -1/+75 |
* | ARP(8): Import from FreeBSD | Sebastian Huber | 2017-01-10 | 1 | -0/+884 |
* | Update to FreeBSD head 2017-01-09 | Sebastian Huber | 2017-01-10 | 95 | -2716/+3900 |
| | | | | Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab. | ||||
* | Update to FreeBSD head 2016-12-10 | Sebastian Huber | 2017-01-10 | 223 | -2992/+3784 |
| | | | | Git mirror commit 80c55f08a05ab3b26a73b226ccb56adc3122a55c. | ||||
* | VMSTAT(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 1 | -1/+65 |
* | VMSTAT(8): Import from FreeBSD | Sebastian Huber | 2017-01-10 | 1 | -0/+1731 |
* | if_dwc: Invalidate read buffer again | Sebastian Huber | 2017-01-10 | 1 | -0/+3 |
| | | | | | This may prevent problems in case a cache line prefetch added some lines to the cache during a DMA transfer. | ||||
* | if_dwc: Use explicit cache operations | Sebastian Huber | 2017-01-10 | 2 | -0/+80 |
* | if_dwc: Reduce DMA descriptor count | Sebastian Huber | 2017-01-10 | 1 | -0/+8 |
* | if_dwc: Use rtems_bsd_get_mac_address() | Sebastian Huber | 2017-01-10 | 1 | -0/+11 |
* | if_dwc: Add nexus device support | Sebastian Huber | 2017-01-10 | 1 | -0/+4 |
* | if_dwc: Fix a possible interrupt starvation | Sebastian Huber | 2017-01-10 | 2 | -17/+13 |
* | if_dwc: Avoid mbuf use after free | Sebastian Huber | 2017-01-10 | 1 | -13/+25 |
* | if_dwc: Checksum offload | Sebastian Huber | 2017-01-10 | 2 | -5/+62 |
* | if_dwc: Avoid tx defrag if possible | Sebastian Huber | 2017-01-10 | 2 | -55/+89 |
| | | | | Drop packets in case of resource shortage. |
