2019-08-26 | Update to FreeBSD stable/12 2019-08-26 | Sebastian Huber | 1 | -24/+5 | |
Git mirror commit 621e7bafbf6857451f23ba11b0495c7ac69aff89. | |||||
2019-06-26 | Update to FreeBSD stable/12 2019-06-26 | Sebastian Huber | 1 | -1/+0 | |
Git mirror commit aa83598855d14cdbf7aef6b05d0617e90f87ca2f. | |||||
2019-06-05 | Update to FreeBSD stable/12 2019-06-05 | Sebastian Huber | 1 | -5/+24 | |
Git mirror commit 78576620f2689e23144a1cf1bf55106cc6abe2b7. | |||||
2018-09-21 | Update to FreeBSD head 2018-09-17 | Sebastian Huber | 3 | -52/+46 | |
Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319. Update #3472. | |||||
2018-09-21 | Update to FreeBSD head 2018-06-01 | Sebastian Huber | 1 | -4/+7 | |
Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9. Update #3472. | |||||
2018-09-21 | Update to FreeBSD head 2018-04-01 | Sebastian Huber | 6 | -5/+17 | |
Git mirror commit 8dfb1ccc26d1cea7e2529303003ff61f9f1784c4. Update #3472. | |||||
2018-09-21 | Update to FreeBSD head 2018-02-01 | Sebastian Huber | 1 | -262/+223 | |
Git mirror commit d079ae0442af8fa3cfd6d7ede190d04e64a2c0d4. Update #3472. | |||||
2018-09-21 | Update to FreeBSD head 2017-12-01 | Sebastian Huber | 15 | -26/+51 | |
Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266. Update #3472. | |||||
2018-09-21 | Update to FreeBSD head 2017-10-01 | Sebastian Huber | 3 | -4/+16 | |
Git mirror commit b2f0376b45428f13151d229c5ae9d4d8f74acbd1. Update #3472. | |||||
2018-09-21 | Update to FreeBSD head 2017-08-01 | Sebastian Huber | 6 | -111/+9 | |
Git mirror commit f5002f5e5f78cae9f0269d812dc0aedb0339312c. Update #3472. | |||||
2018-09-21 | Update to FreeBSD head 2017-06-01 | Sebastian Huber | 4 | -102/+122 | |
Git mirror commit dfb26efac4ce9101dda240e94d9ab53f80a9e131. Update #3472. | |||||
2018-08-28 | Regenerate program header files | Sebastian Huber | 6 | -54/+52 | |
2017-06-08 | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 16 | -16/+16 | |
The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | |||||
2017-04-04 | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 11 | -168/+52 | |
Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | |||||
2017-03-06 | NETSTAT(1): Disable unused functions | Sebastian Huber | 1 | -0/+4 | |
2017-01-17 | userspace tools: Regenerate headers. | Christian Mauderer | 1 | -1/+1 | |
2017-01-10 | Update to FreeBSD head 2017-01-09 | Sebastian Huber | 9 | -71/+107 | |
Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab. | |||||
2017-01-10 | Update to FreeBSD head 2016-12-10 | Sebastian Huber | 3 | -7/+12 | |
Git mirror commit 80c55f08a05ab3b26a73b226ccb56adc3122a55c. | |||||
2017-01-10 | VMSTAT(8): Port to RTEMS | Sebastian Huber | 1 | -1/+65 | |
2017-01-10 | VMSTAT(8): Import from FreeBSD | Sebastian Huber | 1 | -0/+1731 | |
2017-01-10 | Enable multi-cast routing support | Sebastian Huber | 1 | -0/+2 | |
2017-01-10 | NETSTAT(1): Fix name list initialization | Sebastian Huber | 1 | -3/+3 | |
2017-01-10 | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 34 | -3340/+4110 | |
Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | |||||
2016-10-13 | Remove AppleTalk support | Sebastian Huber | 1 | -287/+0 | |
Prepare update to FreeBSD 11. | |||||
2016-08-04 | netstat: Don't init vars if they are not defined. | Christian Mauderer | 1 | -0/+2 | |
The variables are not available, if there is no INET6 defined. | |||||
2016-08-02 | freebsd: Don't use new wrappers for old ports. | Christian Mauderer | 2 | -0/+18 | |
Some of the commands have been adapted manually. So the wrapper currently don't necessarily work as expected. For example ifconfig calls malloc outside of the program call. | |||||
2016-05-30 | Directly use <sys/types.h> provided by Newlib | Sebastian Huber | 3 | -3/+3 | |
2016-05-30 | Directly use <sys/time.h> provided by Newlib | Sebastian Huber | 4 | -4/+4 | |
2015-11-18 | NETSTAT(1): Avoid use of uninitialized memory | Sebastian Huber | 4 | -1/+45 | |
2015-05-20 | Update to FreeBSD Stable/9 2015-04-08 | Sebastian Huber | 1 | -7/+7 | |
2015-02-13 | Update to FreeBSD 9.3 | Sebastian Huber | 1 | -9/+23 | |
2015-01-29 | NETSTAT(1): Disable malloc stats | Sebastian Huber | 1 | -0/+5 | |
2014-09-18 | netstat: Initialize more global variables | Sebastian Huber | 3 | -0/+15 | |
2014-09-18 | netstat: Fix invalid free() | Sebastian Huber | 1 | -4/+8 | |
2013-12-16 | BPF(4): Add support | Sebastian Huber | 1 | -0/+2 | |
2013-11-13 | commands: Use REQUIRE_ORDER option processing | Sebastian Huber | 1 | -1/+1 | |
2013-11-11 | Update to FreeBSD 9.2 | Sebastian Huber | 12 | -97/+115 | |
2013-11-11 | Reduce divergence from FreeBSD sources | Sebastian Huber | 6 | -33/+18 | |
2013-11-11 | Add and use <machine/rtems-bsd-user-space.h> | Sebastian Huber | 14 | -0/+28 | |
2013-11-04 | Update to FreeBSD 8.4 | Sebastian Huber | 6 | -194/+344 | |
2013-10-31 | NETSTAT(1): Initialize global variables | Sebastian Huber | 4 | -23/+65 | |
Use BSD program lock. | |||||
2013-10-31 | NETSTAT(1): Fix isalpha() and isdigit() usage | Sebastian Huber | 1 | -2/+2 | |
2013-10-31 | NETSTAT(1): Add const qualifier | Sebastian Huber | 2 | -378/+18 | |
2013-10-31 | NETSTAT(1): Wrap exit(), etc. | Sebastian Huber | 2 | -0/+5 | |
2013-10-31 | Move shell items to separate file | Sebastian Huber | 1 | -14/+2 | |
2013-10-31 | Move program control to thread structure | Sebastian Huber | 1 | -15/+6 | |
2013-10-31 | Simplify getopt() to getopt_r() translation | Sebastian Huber | 1 | -15/+12 | |
2013-10-10 | Update files to match FreeBSD layout | Sebastian Huber | 15 | -203/+29 | |
Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | |||||
2013-10-10 | Move files to match FreeBSD layout | Sebastian Huber | 15 | -0/+8934 | |
