path: root/freebsd/usr.bin/netstat/unix.c (follow)
* Update due to Newlib 2017-06-07 changesSebastian Huber2017-06-081-1/+1
| | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833.
* Update to FreeBSD head 2017-04-04Sebastian Huber2017-04-041-1/+1
| | | | Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f.
* Update to FreeBSD head 2017-01-09Sebastian Huber2017-01-101-1/+1
| | | | Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab.
* Update to FreeBSD head 2016-08-23Sebastian Huber2017-01-101-26/+69
| | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd.
* Update to FreeBSD 9.2Sebastian Huber2013-11-111-9/+21
* Reduce divergence from FreeBSD sourcesSebastian Huber2013-11-111-5/+3
* Add and use <machine/rtems-bsd-user-space.h>Sebastian Huber2013-11-111-0/+2
* Update files to match FreeBSD layoutSebastian Huber2013-10-101-10/+2
| | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests.
* Move files to match FreeBSD layoutSebastian Huber2013-10-101-0/+302
