* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-04-04 | 1 | -1/+1 |
| | | | | Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | NETSTAT(1): Disable unused functions | Sebastian Huber | 2017-03-06 | 1 | -0/+4 |
* | NETSTAT(1): Fix name list initialization | Sebastian Huber | 2017-01-10 | 1 | -3/+3 |
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 1 | -313/+371 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | freebsd: Don't use new wrappers for old ports. | Christian Mauderer | 2016-08-02 | 1 | -0/+9 |
| | | | | | | Some of the commands have been adapted manually. So the wrapper currently don't necessarily work as expected. For example ifconfig calls malloc outside of the program call. | ||||
* | NETSTAT(1): Avoid use of uninitialized memory | Sebastian Huber | 2015-11-18 | 1 | -0/+3 |
* | Update to FreeBSD 9.3 | Sebastian Huber | 2015-02-13 | 1 | -9/+23 |
* | netstat: Initialize more global variables | Sebastian Huber | 2014-09-18 | 1 | -0/+3 |
* | commands: Use REQUIRE_ORDER option processing | Sebastian Huber | 2013-11-13 | 1 | -1/+1 |
* | Update to FreeBSD 9.2 | Sebastian Huber | 2013-11-11 | 1 | -12/+14 |
* | Reduce divergence from FreeBSD sources | Sebastian Huber | 2013-11-11 | 1 | -7/+0 |
* | Add and use <machine/rtems-bsd-user-space.h> | Sebastian Huber | 2013-11-11 | 1 | -0/+2 |
* | Update to FreeBSD 8.4 | Sebastian Huber | 2013-11-04 | 1 | -4/+31 |
* | NETSTAT(1): Initialize global variables | Sebastian Huber | 2013-10-31 | 1 | -3/+44 |
| | | | | Use BSD program lock. | ||||
* | NETSTAT(1): Fix isalpha() and isdigit() usage | Sebastian Huber | 2013-10-31 | 1 | -2/+2 |
* | NETSTAT(1): Add const qualifier | Sebastian Huber | 2013-10-31 | 1 | -376/+16 |
* | NETSTAT(1): Wrap exit(), etc. | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
* | Move shell items to separate file | Sebastian Huber | 2013-10-31 | 1 | -14/+2 |
* | Move program control to thread structure | Sebastian Huber | 2013-10-31 | 1 | -15/+6 |
* | Simplify getopt() to getopt_r() translation | Sebastian Huber | 2013-10-31 | 1 | -15/+12 |
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -5/+1 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | Move files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -0/+1229 |
