* | NVME(4): Import from FreeBSD | Sebastian Huber | 2019-11-13 | 10 | -0/+5567 | |
| | | | | Update #3821. | |||||
* | Update to FreeBSD head 2019-09-24 | Sebastian Huber | 2019-11-13 | 447 | -10684/+20648 | |
| | | | | Git mirror commit 6b0307a0a5184339393f555d5d424190d8a8277a. | |||||
* | Add support for EARLY_COUNTER | Sebastian Huber | 2019-09-25 | 2 | -0/+7 | |
* | Remove obsolete header files | Sebastian Huber | 2019-09-24 | 1 | -205/+0 | |
* | Fix pgsigio() warnings | Sebastian Huber | 2019-09-24 | 1 | -0/+14 | |
* | Add pselect() | Sebastian Huber | 2019-09-23 | 1 | -0/+37 | |
* | PCI(4): Import missing file | Sebastian Huber | 2019-09-23 | 1 | -0/+84 | |
* | PCI(4): Disable unsupported features | Sebastian Huber | 2019-09-23 | 1 | -0/+10 | |
* | PCI(4): Add big endian support | Sebastian Huber | 2019-09-23 | 1 | -0/+8 | |
* | CONFIG_INTRHOOK(9): Call handlers after boot | Sebastian Huber | 2019-09-23 | 1 | -1/+15 | |
| | | | | | This enables adding drivers on demand which use this service after initialization. | |||||
* | C++ compatibility for <dev/pci/pcivar.h> | Sebastian Huber | 2019-09-23 | 1 | -1/+1 | |
* | C++ compatibility for kernel space <sys/sysctl.h> | Sebastian Huber | 2019-09-23 | 1 | -0/+2 | |
* | rtemsbsd: remove dead code fb.c | Vijay Kumar Banerjee | 2019-08-31 | 1 | -762/+0 | |
* | libsodium: Disable unused function | Sebastian Huber | 2019-08-27 | 1 | -0/+2 | |
* | tty.c: Disable unused functions | Sebastian Huber | 2019-08-27 | 1 | -4/+2 | |
* | pf_ioctl.c: Disable superfluous unload support | Sebastian Huber | 2019-08-27 | 1 | -0/+4 | |
* | kern_intr.c: Disable unused functions | Sebastian Huber | 2019-08-27 | 1 | -2/+0 | |
* | Remove superfluous support for preloaded modules | Sebastian Huber | 2019-08-27 | 2 | -313/+2 | |
* | SLEEPQUEUE(9): Optimize sleepq_set_timeout_sbt() | Sebastian Huber | 2019-08-26 | 1 | -2/+3 | |
| | | | | Avoid an extra ISR disable/enable in SMP configurations. | |||||
* | am335x display drivers: Import from FreeBSD | Vijay Kumar Banerjee | 2019-08-11 | 5 | -0/+1547 | |
* | fbd: Port to RTEMS | Vijay Kumar Banerjee | 2019-08-11 | 1 | -0/+4 | |
* | fbd: Import from FreeBSD | Vijay Kumar Banerjee | 2019-08-11 | 10 | -0/+3621 | |
* | TDA19988: Import from FreeBSD | Vijay Kumar Banerjee | 2019-08-11 | 12 | -0/+3362 | |
* | Pinmux : Import from FreeBSD | Vijay Kumar Banerjee | 2019-08-11 | 6 | -0/+1138 | |
* | Add mmap | Vijay Kumar Banerjee | 2019-07-27 | 2 | -5/+5 | |
* | SLEEPQUEUE(9): Fix timeout handling | Sebastian Huber | 2019-07-05 | 1 | -2/+4 | |
* | iicbus: Import from FreeBSD | Vijay Kumar Banerjee | 2019-06-29 | 7 | -0/+1970 | |
* | Add riscv support | Sebastian Huber | 2019-05-23 | 1 | -0/+83 | |
* | Separate libbsd and RTEMS clock ticks | Sebastian Huber | 2019-05-15 | 5 | -14/+4 | |
* | Fix USB_DEBUG redefinition warnings | Sebastian Huber | 2019-05-13 | 1 | -0/+12 | |
* | Add hostname related sysctls conditionally | Sebastian Huber | 2019-05-13 | 1 | -0/+5 | |
| | | | | This helps to the reduce code size for USB only use cases. | |||||
* | Use static inline functions for jail and prison | Sebastian Huber | 2019-05-13 | 1 | -0/+202 | |
| | | | | This helps the compiler to optimize away dead code. | |||||
* | Update due to API changes | Sebastian Huber | 2019-04-11 | 1 | -2/+2 | |
* | Import FreeBSD license files. | Christian Mauderer | 2019-04-04 | 2 | -0/+49 | |
* | BPF(9): Disable legacy timestamp support | Sebastian Huber | 2019-03-29 | 1 | -0/+7 | |
* | BPF(9): Fix timestamps | Sebastian Huber | 2019-03-28 | 1 | -0/+1 | |
* | C++ compatibility for some kernel-space headers | Sebastian Huber | 2019-02-18 | 3 | -13/+13 | |
* | ZONE(9): Fix UMA_PCPU_ALLOC_SIZE | Sebastian Huber | 2019-02-12 | 1 | -6/+4 | |
| | | | | | Using CACHE_LINE_SIZE for UMA_PCPU_ALLOC_SIZE was a huge memory waste since the backend memory allocator is page based. | |||||
* | Fix INVARIANTS support | Sebastian Huber | 2019-01-22 | 3 | -1/+18 | |
* | Update to FreeBSD head 2018-12-20 | Sebastian Huber | 2018-12-20 | 106 | -5489/+1286 | |
| | | | | | | | | | | Git mirror commit 19a6ceb89dbacf74697d493e48c388767126d418. It includes an update of wpa_supplicant to version 2.7. It includes an update of the OpenSSL baseline to version 1.1.1a. Update #3472. | |||||
* | freebsd/if_cpsw: Port. | Christian Mauderer | 2018-12-20 | 1 | -0/+21 | |
* | freebsd/if_cpsw: Import. | Christian Mauderer | 2018-12-20 | 3 | -0/+3352 | |
* | SLEEPQUEUE(9): Fix typo that prevent non-SMP build. | Christian Mauderer | 2018-12-19 | 1 | -1/+1 | |
* | SLEEPQUEUE(9): SMP only cache line alignment | Sebastian Huber | 2018-12-14 | 1 | -0/+4 | |
* | blist: Fix u_daddr_t for 32-bit targets | Sebastian Huber | 2018-11-27 | 1 | -0/+4 | |
| | | | | The daddr_t is defined in <sys/types.h> by Newlib as long. | |||||
* | Update to FreeBSD head 2018-11-15 | Sebastian Huber | 2018-11-15 | 71 | -1001/+1610 | |
| | | | | | | Git mirror commit a18b0830c4be01b39489a891b63d6023ada6358a. Update #3472. | |||||
* | Disable or make static kern_* functions | Sebastian Huber | 2018-11-15 | 5 | -7/+15 | |
* | Update to FreeBSD head 2018-10-23 | Sebastian Huber | 2018-10-25 | 99 | -1002/+1913 | |
| | | | | | | | | | | | Git mirror commit 59f44d20be3f99d181ca742e636d45fc39ec982b. This commit updates OpenSSL to version 1.1.1. This required an update of racoon which uses some internal stuff from OpenSSL and seems to be mostly unmaintained, e.g. there is update in the FreeBSD ports to cope with OpenSSL 1.1.1. Update #3472. | |||||
* | ZONE(9): Disable UMA_ZONE_NUMA | Sebastian Huber | 2018-10-23 | 3 | -2/+31 | |
| | | | | There is no NUMA support in RTEMS currently. | |||||
* | saf1761_otg: Use real interrupt handler | Sebastian Huber | 2018-10-04 | 3 | -6/+53 | |
| | | | | | | | The USB_BUS_SPIN_LOCK() is only used internally to the bus driver. Replace the mutex with an interrupt disable/enable section. Execute the interrupt filter in a real interrupt context and forward the interrupt handler to the interrupt server if necessary. |
