* | Pinmux : Import from FreeBSD | Vijay Kumar Banerjee | 2019-08-11 | 6 | -0/+1138 |
* | Add mmap | Vijay Kumar Banerjee | 2019-07-27 | 2 | -5/+5 |
* | SLEEPQUEUE(9): Fix timeout handling | Sebastian Huber | 2019-07-05 | 1 | -2/+4 |
* | iicbus: Import from FreeBSD | Vijay Kumar Banerjee | 2019-06-29 | 7 | -0/+1970 |
* | Add riscv support | Sebastian Huber | 2019-05-23 | 1 | -0/+83 |
* | Separate libbsd and RTEMS clock ticks | Sebastian Huber | 2019-05-15 | 5 | -14/+4 |
* | Fix USB_DEBUG redefinition warnings | Sebastian Huber | 2019-05-13 | 1 | -0/+12 |
* | Add hostname related sysctls conditionally | Sebastian Huber | 2019-05-13 | 1 | -0/+5 |
| | | | | This helps to the reduce code size for USB only use cases. | ||||
* | Use static inline functions for jail and prison | Sebastian Huber | 2019-05-13 | 1 | -0/+202 |
| | | | | This helps the compiler to optimize away dead code. | ||||
* | Update due to API changes | Sebastian Huber | 2019-04-11 | 1 | -2/+2 |
* | Import FreeBSD license files. | Christian Mauderer | 2019-04-04 | 2 | -0/+49 |
* | BPF(9): Disable legacy timestamp support | Sebastian Huber | 2019-03-29 | 1 | -0/+7 |
* | BPF(9): Fix timestamps | Sebastian Huber | 2019-03-28 | 1 | -0/+1 |
* | C++ compatibility for some kernel-space headers | Sebastian Huber | 2019-02-18 | 3 | -13/+13 |
* | ZONE(9): Fix UMA_PCPU_ALLOC_SIZE | Sebastian Huber | 2019-02-12 | 1 | -6/+4 |
| | | | | | Using CACHE_LINE_SIZE for UMA_PCPU_ALLOC_SIZE was a huge memory waste since the backend memory allocator is page based. | ||||
* | Fix INVARIANTS support | Sebastian Huber | 2019-01-22 | 3 | -1/+18 |
* | Update to FreeBSD head 2018-12-20 | Sebastian Huber | 2018-12-20 | 106 | -5489/+1286 |
| | | | | | | | | | | Git mirror commit 19a6ceb89dbacf74697d493e48c388767126d418. It includes an update of wpa_supplicant to version 2.7. It includes an update of the OpenSSL baseline to version 1.1.1a. Update #3472. | ||||
* | freebsd/if_cpsw: Port. | Christian Mauderer | 2018-12-20 | 1 | -0/+21 |
* | freebsd/if_cpsw: Import. | Christian Mauderer | 2018-12-20 | 3 | -0/+3352 |
* | SLEEPQUEUE(9): Fix typo that prevent non-SMP build. | Christian Mauderer | 2018-12-19 | 1 | -1/+1 |
* | SLEEPQUEUE(9): SMP only cache line alignment | Sebastian Huber | 2018-12-14 | 1 | -0/+4 |
* | blist: Fix u_daddr_t for 32-bit targets | Sebastian Huber | 2018-11-27 | 1 | -0/+4 |
| | | | | The daddr_t is defined in <sys/types.h> by Newlib as long. | ||||
* | Update to FreeBSD head 2018-11-15 | Sebastian Huber | 2018-11-15 | 71 | -1001/+1610 |
| | | | | | | Git mirror commit a18b0830c4be01b39489a891b63d6023ada6358a. Update #3472. | ||||
* | Disable or make static kern_* functions | Sebastian Huber | 2018-11-15 | 5 | -7/+15 |
* | Update to FreeBSD head 2018-10-23 | Sebastian Huber | 2018-10-25 | 99 | -1002/+1913 |
| | | | | | | | | | | | Git mirror commit 59f44d20be3f99d181ca742e636d45fc39ec982b. This commit updates OpenSSL to version 1.1.1. This required an update of racoon which uses some internal stuff from OpenSSL and seems to be mostly unmaintained, e.g. there is update in the FreeBSD ports to cope with OpenSSL 1.1.1. Update #3472. | ||||
* | ZONE(9): Disable UMA_ZONE_NUMA | Sebastian Huber | 2018-10-23 | 3 | -2/+31 |
| | | | | There is no NUMA support in RTEMS currently. | ||||
* | saf1761_otg: Use real interrupt handler | Sebastian Huber | 2018-10-04 | 3 | -6/+53 |
| | | | | | | | The USB_BUS_SPIN_LOCK() is only used internally to the bus driver. Replace the mutex with an interrupt disable/enable section. Execute the interrupt filter in a real interrupt context and forward the interrupt handler to the interrupt server if necessary. | ||||
* | rtwn: Align mbuf to avoid realignment in rx path | Sebastian Huber | 2018-10-04 | 1 | -0/+7 |
| | | | | See ieee80211_realign(). | ||||
* | fsl_sdhci.c: Fix missing include error | Sebastian Huber | 2018-09-28 | 1 | -0/+4 |
| | | | | Update #3525. | ||||
* | fsl_sdhci.c: Fix missing include error | Sebastian Huber | 2018-09-27 | 1 | -0/+4 |
* | fsl_sdhci.c: Import from FreeBSD | Sebastian Huber | 2018-09-25 | 1 | -0/+1015 |
* | imx/imx_gpio.c: Port to RTEMS | Sebastian Huber | 2018-09-25 | 1 | -1/+4 |
* | imx/imx_gpio.c: Import from FreeBSD | Sebastian Huber | 2018-09-25 | 1 | -0/+910 |
* | CONFIG_INTRHOOK(9): Port to RTEMS | Sebastian Huber | 2018-09-25 | 3 | -2/+296 |
| | | | | | | | | | Some device drivers (e.g. MMC) need a complex intialization with working callouts. Remove the dummy CONFIG_INTRHOOK() implementation and replace it with the real one from FreeBSD. Make sure TIMEOUT(9) services work at this point. Update #3525. | ||||
* | ck: Use relaxed memory order if possible | Sebastian Huber | 2018-09-21 | 1 | -10/+25 |
| | | | | | | | In uniprocessor configurations we can use a relaxed memory order and compiler memory barriers should be sufficient. Update #3472. | ||||
* | ck: No hardware barriers in uniprocessor configs | Sebastian Huber | 2018-09-21 | 3 | -4/+21 |
* | Update to FreeBSD head 2018-09-17 | Sebastian Huber | 2018-09-21 | 323 | -8299/+12076 |
| | | | | | | Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319. Update #3472. | ||||
* | ck: Define CK_MD_PPC32_LWSYNC if available | Sebastian Huber | 2018-09-21 | 1 | -0/+4 |
| | | | | | | This is option has a huge performance impact. Update #3472. | ||||
* | ck: Use atomic built-ins | Sebastian Huber | 2018-09-21 | 1 | -10/+13 |
* | Update to FreeBSD head 2018-06-01 | Sebastian Huber | 2018-09-21 | 265 | -6034/+15112 |
| | | | | | | Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9. Update #3472. | ||||
* | Update to FreeBSD head 2018-04-01 | Sebastian Huber | 2018-09-21 | 182 | -2659/+5483 |
| | | | | | | Git mirror commit 8dfb1ccc26d1cea7e2529303003ff61f9f1784c4. Update #3472. | ||||
* | Update to FreeBSD head 2018-02-01 | Sebastian Huber | 2018-09-21 | 165 | -3843/+2612 |
| | | | | | | Git mirror commit d079ae0442af8fa3cfd6d7ede190d04e64a2c0d4. Update #3472. | ||||
* | Update to FreeBSD head 2017-12-01 | Sebastian Huber | 2018-09-21 | 849 | -1610/+3980 |
| | | | | | | Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266. Update #3472. | ||||
* | Update to FreeBSD head 2017-10-01 | Sebastian Huber | 2018-09-21 | 146 | -1332/+2440 |
| | | | | | | Git mirror commit b2f0376b45428f13151d229c5ae9d4d8f74acbd1. Update #3472. | ||||
* | Update to FreeBSD head 2017-08-01 | Sebastian Huber | 2018-09-21 | 137 | -2794/+6075 |
| | | | | | | Git mirror commit f5002f5e5f78cae9f0269d812dc0aedb0339312c. Update #3472. | ||||
* | Update to FreeBSD head 2017-06-01 | Sebastian Huber | 2018-09-21 | 146 | -1400/+2118 |
| | | | | | | Git mirror commit dfb26efac4ce9101dda240e94d9ab53f80a9e131. Update #3472. | ||||
* | Optimize callout handline via static timer wheel | Sebastian Huber | 2018-09-17 | 1 | -1/+17 |
| | | | | | | | The number of callouts is a compile-time constant in libbsd. Use this in struct callout_cpu and avoid dynamic allocation of tables. This signficantly reduces the count of load instructions in the callout handling. | ||||
* | Remove struct callout::c_cpu | Sebastian Huber | 2018-09-17 | 2 | -1/+25 |
| | | | | | This is an optimization of the callout handling. In libbsd all callouts are handled by the one and only timer server. | ||||
* | IPFW(4): Remove FreeBSD import | Sebastian Huber | 2018-08-24 | 36 | -30326/+0 |
| | | | | | | | | This firewall was not ported to RTEMS and is just dead code which may make trouble during FreeBSD baseline updates. It also increased the compile-time of the library for nothing. Update #3472. | ||||
* | Fix alignment of getsockaddr_sockaddr | Sebastian Huber | 2018-08-24 | 1 | -1/+1 |
