* | Update due to API changes | Sebastian Huber | 2019-04-11 | 1 | -2/+2 |
* | Fix INVARIANTS support | Sebastian Huber | 2019-01-22 | 1 | -0/+12 |
* | Update to FreeBSD head 2018-12-20 | Sebastian Huber | 2018-12-20 | 2 | -44/+40 |
| | | | | | | | | | | Git mirror commit 19a6ceb89dbacf74697d493e48c388767126d418. It includes an update of wpa_supplicant to version 2.7. It includes an update of the OpenSSL baseline to version 1.1.1a. Update #3472. | ||||
* | Update to FreeBSD head 2018-11-15 | Sebastian Huber | 2018-11-15 | 3 | -110/+187 |
| | | | | | | Git mirror commit a18b0830c4be01b39489a891b63d6023ada6358a. Update #3472. | ||||
* | Update to FreeBSD head 2018-10-23 | Sebastian Huber | 2018-10-25 | 1 | -14/+56 |
| | | | | | | | | | | | Git mirror commit 59f44d20be3f99d181ca742e636d45fc39ec982b. This commit updates OpenSSL to version 1.1.1. This required an update of racoon which uses some internal stuff from OpenSSL and seems to be mostly unmaintained, e.g. there is update in the FreeBSD ports to cope with OpenSSL 1.1.1. Update #3472. | ||||
* | ZONE(9): Disable UMA_ZONE_NUMA | Sebastian Huber | 2018-10-23 | 3 | -2/+31 |
| | | | | There is no NUMA support in RTEMS currently. | ||||
* | Update to FreeBSD head 2018-09-17 | Sebastian Huber | 2018-09-21 | 4 | -85/+326 |
| | | | | | | Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319. Update #3472. | ||||
* | Update to FreeBSD head 2018-06-01 | Sebastian Huber | 2018-09-21 | 3 | -18/+35 |
| | | | | | | Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9. Update #3472. | ||||
* | Update to FreeBSD head 2018-04-01 | Sebastian Huber | 2018-09-21 | 5 | -120/+194 |
| | | | | | | Git mirror commit 8dfb1ccc26d1cea7e2529303003ff61f9f1784c4. Update #3472. | ||||
* | Update to FreeBSD head 2018-02-01 | Sebastian Huber | 2018-09-21 | 5 | -194/+528 |
| | | | | | | Git mirror commit d079ae0442af8fa3cfd6d7ede190d04e64a2c0d4. Update #3472. | ||||
* | Update to FreeBSD head 2017-12-01 | Sebastian Huber | 2018-09-21 | 7 | -28/+109 |
| | | | | | | Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266. Update #3472. | ||||
* | Update to FreeBSD head 2017-10-01 | Sebastian Huber | 2018-09-21 | 3 | -8/+15 |
| | | | | | | Git mirror commit b2f0376b45428f13151d229c5ae9d4d8f74acbd1. Update #3472. | ||||
* | Update to FreeBSD head 2017-08-01 | Sebastian Huber | 2018-09-21 | 2 | -135/+65 |
| | | | | | | Git mirror commit f5002f5e5f78cae9f0269d812dc0aedb0339312c. Update #3472. | ||||
* | Update to FreeBSD head 2017-06-01 | Sebastian Huber | 2018-09-21 | 1 | -0/+3 |
| | | | | | | Git mirror commit dfb26efac4ce9101dda240e94d9ab53f80a9e131. Update #3472. | ||||
* | Fix sporadic test failures via uma_timeout() | Sebastian Huber | 2018-07-26 | 2 | -0/+15 |
* | ZONE(9): Avoid function call overhead | Sebastian Huber | 2018-01-19 | 1 | -1/+3 |
* | Fix INVARIANTS support | Sebastian Huber | 2017-10-20 | 1 | -0/+4 |
* | ZONE(9): Use recursive lock for the UMA drain | Sebastian Huber | 2017-10-20 | 1 | -1/+1 |
* | ZONE(9): Reduce BUCKET_MAX to 128 | Sebastian Huber | 2017-10-20 | 1 | -1/+7 |
| | | | | Reduces the worst-case per-processor caches. | ||||
* | ZONE(9): Fix uma_zone_set_max() | Sebastian Huber | 2017-10-20 | 1 | -0/+9 |
| | | | | Account for items provided for per-processor caches. | ||||
* | Use <sys/lock.h> provided by Newlib | Sebastian Huber | 2017-06-08 | 2 | -2/+2 |
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 3 | -3/+3 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-04-04 | 5 | -24/+30 |
| | | | | Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | Update to FreeBSD head 2017-01-09 | Sebastian Huber | 2017-01-10 | 1 | -1/+1 |
| | | | | Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab. | ||||
* | Update to FreeBSD head 2016-12-10 | Sebastian Huber | 2017-01-10 | 1 | -12/+4 |
| | | | | Git mirror commit 80c55f08a05ab3b26a73b226ccb56adc3122a55c. | ||||
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 7 | -1281/+1589 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | Directly use <sys/types.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 2 | -2/+2 |
* | ZONE(9): Fix mp_maxid definition | Sebastian Huber | 2016-05-06 | 1 | -1/+1 |
* | ZONE(9): Fix slab flag handling | Sebastian Huber | 2015-09-11 | 2 | -2/+12 |
| | | | | Disable unused slab flags. | ||||
* | ZONE(9): Disable unused field | Sebastian Huber | 2015-09-11 | 1 | -0/+4 |
* | ZONE(9): Define SMP if RTEMS_SMP is defined | Sebastian Huber | 2015-09-11 | 1 | -0/+1 |
* | Add INVARIANTS support | Sebastian Huber | 2015-05-20 | 1 | -0/+315 |
* | Update to FreeBSD Stable/9 2015-04-08 | Sebastian Huber | 2015-05-20 | 1 | -2/+0 |
* | ZONE(9): Disable uma_prealloc() | Sebastian Huber | 2015-05-15 | 1 | -1/+1 |
* | ZONE(9): Enable per-processor cache for SMP | Sebastian Huber | 2015-03-06 | 1 | -0/+12 |
| | | | | | This prevents a potential deadlock via the Giant lock and is a performance benefit. | ||||
* | Update to FreeBSD 9.3 | Sebastian Huber | 2015-02-13 | 3 | -6/+10 |
* | ZONE(9): Enable UMA sysctls | Sebastian Huber | 2015-01-29 | 1 | -4/+2 |
* | ZONE(9): Use page allocator | Sebastian Huber | 2015-01-29 | 2 | -49/+6 |
* | UMA(9): Disable unused uma_large_malloc() | Sebastian Huber | 2014-09-30 | 1 | -2/+2 |
* | Update to FreeBSD 9.2 | Sebastian Huber | 2013-11-11 | 5 | -98/+107 |
* | Reduce divergence from FreeBSD sources | Sebastian Huber | 2013-11-11 | 2 | -15/+15 |
* | Rename rtems-bsd-config.h | Sebastian Huber | 2013-11-11 | 1 | -1/+1 |
| | | | | Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h. | ||||
* | Update to FreeBSD 8.4 | Sebastian Huber | 2013-11-04 | 4 | -28/+25 |
* | ZONE(9): Add and use red-black tree chunk alloc | Sebastian Huber | 2013-10-31 | 2 | -21/+50 |
* | Move TIMEOUT(9) and ZONE(9) initialization | Sebastian Huber | 2013-10-31 | 2 | -13/+150 |
| | | | | Delete most of virtual memory support. | ||||
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 3 | -37/+36 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | Move files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 5 | -0/+4733 |
