path: root/freebsd/sys/v850 (follow)
* Update to FreeBSD head 2017-12-01Sebastian Huber2018-09-211-0/+2
| | | | | | Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266. Update #3472.
* Update due to Newlib 2017-06-07 changesSebastian Huber2017-06-081-1/+1
| | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833.
* Update to FreeBSD head 2016-08-23Sebastian Huber2017-01-101-1/+1
| | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd.
* Delete superfluous pci_cfgreg.h filesSebastian Huber2015-09-011-60/+0
* Delete superfluous legacyvar.h filesSebastian Huber2015-09-011-63/+0
* Delete superfluous pci_bus.c filesSebastian Huber2015-09-011-736/+0
* Delete superfluous legacy.c filesSebastian Huber2015-09-011-373/+0
* Update to FreeBSD 9.2Sebastian Huber2013-11-114-77/+102
* Reduce divergence from FreeBSD sourcesSebastian Huber2013-11-112-10/+0
* Rename rtems-bsd-config.hSebastian Huber2013-11-113-3/+3
| | | | Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h.
* Update to FreeBSD 8.4Sebastian Huber2013-11-043-18/+54
* Update files to match FreeBSD layoutSebastian Huber2013-10-106-0/+1517
Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests.
