Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266.
Update #3472.
Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd.
Performance analysis revealed that the standard RTEMS objects are a
major bottleneck. The object get mechanism and attribute checks at
runtime have a significant overhead. Use a custom implementation for
synchronization primitives. This drops also the size of the
synchronization primitives considerably.
Add compatibility with Newlib header files. Some FreeBSD header files
are mapped by the translation script:
o rtems/bsd/sys/_types.h
o rtems/bsd/sys/errno.h
o rtems/bsd/sys/lock.h
o rtems/bsd/sys/param.h
o rtems/bsd/sys/resource.h
o rtems/bsd/sys/time.h
o rtems/bsd/sys/timespec.h
o rtems/bsd/sys/types.h
o rtems/bsd/sys/unistd.h
It is now possible to include <sys/socket.h> directly for example.
Generate one Makefile which builds everything including tests.
