* | Update to FreeBSD 8.4 | Sebastian Huber | 2013-11-04 | 1 | -11/+66 |
* | Fix errno conflict | Sebastian Huber | 2013-10-31 | 1 | -16/+4 |
| | | | | | | | | | | | | Newlib defines errno as #define errno (*__errno()) In case this is expanded in a function parameter, e.g. void f(int errno) { ... } then we have a function pointer parameter instead of the integer scalar. | ||||
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -8/+8 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | Move files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -0/+687 |
