Git mirror commit 19a6ceb89dbacf74697d493e48c388767126d418.
It includes an update of wpa_supplicant to version 2.7.
It includes an update of the OpenSSL baseline to version 1.1.1a.
Update #3472.
Git mirror commit 59f44d20be3f99d181ca742e636d45fc39ec982b.
This commit updates OpenSSL to version 1.1.1. This required an update
of racoon which uses some internal stuff from OpenSSL and seems to be
mostly unmaintained, e.g. there is update in the FreeBSD ports to cope
with OpenSSL 1.1.1.
Update #3472.
Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9.
Update #3472.
Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266.
Update #3472.
The following files are now provided by Newlib:
* arpa/inet.h
* net/if.h
* netinet/in.h
* netinet/tcp.h
* sys/socket.h
* sys/uio.h
* sys/un.h
The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be
used directly.
Update #2833.
Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd.
Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h.
Add compatibility with Newlib header files. Some FreeBSD header files
are mapped by the translation script:
o rtems/bsd/sys/_types.h
o rtems/bsd/sys/errno.h
o rtems/bsd/sys/lock.h
o rtems/bsd/sys/param.h
o rtems/bsd/sys/resource.h
o rtems/bsd/sys/time.h
o rtems/bsd/sys/timespec.h
o rtems/bsd/sys/types.h
o rtems/bsd/sys/unistd.h
It is now possible to include <sys/socket.h> directly for example.
Generate one Makefile which builds everything including tests.
