Git mirror commit 8dfb1ccc26d1cea7e2529303003ff61f9f1784c4.
Update #3472.
Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266.
Update #3472.
The following files are now provided by Newlib:
* arpa/inet.h
* net/if.h
* netinet/in.h
* netinet/tcp.h
* sys/socket.h
* sys/uio.h
* sys/un.h
The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be
used directly.
Update #2833.
Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f.
Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd.
Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h.
Add compatibility with Newlib header files. Some FreeBSD header files
are mapped by the translation script:
o rtems/bsd/sys/_types.h
o rtems/bsd/sys/errno.h
o rtems/bsd/sys/lock.h
o rtems/bsd/sys/param.h
o rtems/bsd/sys/resource.h
o rtems/bsd/sys/time.h
o rtems/bsd/sys/timespec.h
o rtems/bsd/sys/types.h
o rtems/bsd/sys/unistd.h
It is now possible to include <sys/socket.h> directly for example.
Generate one Makefile which builds everything including tests.
