* | CONFIG_INTRHOOK(9): Port to RTEMS | Sebastian Huber | 2018-09-25 | 1 | -0/+282 |
Some device drivers (e.g. MMC) need a complex intialization with working callouts. Remove the dummy CONFIG_INTRHOOK() implementation and replace it with the real one from FreeBSD. Make sure TIMEOUT(9) services work at this point. Update #3525. |
