- Update imported files to compile rtems-libbsd for i386 based BSPs
- Mostly commenting out parts which create compile or link errors in
RTEMS, but aren't needed
- The files in the i386 directory have been moved to common x86 directories by FreeBSD:
- freebsd/sys/x86/x86/legacy.c
- freebsd/sys/x86/include/machine/legacyvar.h
- freebsd/sys/x86/include/machine/specialreg.h
- Add header files in rtemsbsd directory to direct compiler to new files
Git mirror commit 735fe7a0a5f9c265040e2e6654a01b081d6354f1.
Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319.
Update #3472.
Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9.
Update #3472.
Git mirror commit 8dfb1ccc26d1cea7e2529303003ff61f9f1784c4.
Update #3472.
Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266.
Update #3472.
Git mirror commit b2f0376b45428f13151d229c5ae9d4d8f74acbd1.
Update #3472.
Git mirror commit dfb26efac4ce9101dda240e94d9ab53f80a9e131.
Update #3472.
The following files are now provided by Newlib:
* arpa/inet.h
* net/if.h
* netinet/in.h
* netinet/tcp.h
* sys/socket.h
* sys/uio.h
* sys/un.h
The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be
used directly.
Update #2833.
Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f.
Git mirror commit 80c55f08a05ab3b26a73b226ccb56adc3122a55c.
Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd.
Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h.
Add compatibility with Newlib header files. Some FreeBSD header files
are mapped by the translation script:
o rtems/bsd/sys/_types.h
o rtems/bsd/sys/errno.h
o rtems/bsd/sys/lock.h
o rtems/bsd/sys/param.h
o rtems/bsd/sys/resource.h
o rtems/bsd/sys/time.h
o rtems/bsd/sys/timespec.h
o rtems/bsd/sys/types.h
o rtems/bsd/sys/unistd.h
It is now possible to include <sys/socket.h> directly for example.
Generate one Makefile which builds everything including tests.
