Git mirror commit 59f44d20be3f99d181ca742e636d45fc39ec982b.
This commit updates OpenSSL to version 1.1.1. This required an update
of racoon which uses some internal stuff from OpenSSL and seems to be
mostly unmaintained, e.g. there is update in the FreeBSD ports to cope
with OpenSSL 1.1.1.
Update #3472.
Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9.
Update #3472.
Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266.
Update #3472.
Git mirror commit f5002f5e5f78cae9f0269d812dc0aedb0339312c.
Update #3472.
Git mirror commit dfb26efac4ce9101dda240e94d9ab53f80a9e131.
Update #3472.
Update #3090.
Update #3090.
Code is an adapted from the TSEC (if_tsec) network interface driver.
Update #3090.
Update #3090.
Use structure similar to TSEC (if_tsec) driver.
The use of bus_dmamap_sync() differs these network interface drivers.
This should not be the case.
Update #3090.
Update #3090.
This avoids the move of entire receive frames to meet the alignment
requirements of the IP header and so on.
Add FECFLAG_RACC feature flag for this similar to the Linux driver.
Update #3090.
This flag is analogous to the Linux driver FEC_QUIRK_HAS_AVB. It
indicates an FEC with support for Audio Video Bridging (AVB). This
indicator is used for various other parts in the Linux driver
(drivers/net/ethernet/freescale/fec_main.c).
Use it to customize the receive/transmit buffer alignment. The receive
buffer alignment increased to 64-bytes on the i.MX 6SoloX and i.MX
7Dual. There are no hard alignment restrictions for transmit buffers on
these chips.
Fix the ffec_softc::fectype type to provide enough storage for the
feature flags.
For optimal performance a 64-byte alignment is recommended.
