* | Update to FreeBSD stable/12 2019-06-05 | Sebastian Huber | 2019-06-05 | 1 | -1/+9 |
| | | | | Git mirror commit 78576620f2689e23144a1cf1bf55106cc6abe2b7. | ||||
* | Update to FreeBSD head 2018-02-01 | Sebastian Huber | 2018-09-21 | 1 | -1/+1 |
| | | | | | | Git mirror commit d079ae0442af8fa3cfd6d7ede190d04e64a2c0d4. Update #3472. | ||||
* | Update to FreeBSD head 2017-12-01 | Sebastian Huber | 2018-09-21 | 2 | -0/+4 |
| | | | | | | Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266. Update #3472. | ||||
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 1 | -139/+154 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | Enable the Cadence cgem device syctls. | Chris Johns | 2016-06-27 | 1 | -2/+0 |
* | Revert "Enable the Cadence cgem device syctls." | Chris Johns | 2016-06-27 | 1 | -7/+9 |
| | | | | | | This reverts commit 9362e7649bde3d31b6f464f3184fe527b4dcb1d2. Committed white space changes. | ||||
* | Enable the Cadence cgem device syctls. | Chris Johns | 2016-06-27 | 1 | -9/+7 |
* | Revert "if_cgem: Enable hardware checksum assist" | Chris Johns | 2015-06-22 | 1 | -5/+0 |
| | | | | | | | This reverts commit dec6b678bba05624335c87b73dc160b54d845cbd. This default for TXCSUM and RXCSUM should be used and a user should turn on TXCSUM and RXCSUM. | ||||
* | Revert "Return the default TX and RX hardware checksum for the Cadence ↵ | Chris Johns | 2015-06-22 | 1 | -7/+12 |
| | | | | | | | | | driver to off." This reverts commit 54fb9f01f86286ecea3093f6f524afec86d6313f. This change adds white space changes. A better solution is to revert the original change. | ||||
* | Return the default TX and RX hardware checksum for the Cadence driver to off. | Chris Johns | 2015-06-19 | 1 | -12/+7 |
| | | | | | | The hardware support does not seem to work with qemu. The support can be enabled with ifconfig or via ioctl on real hardware to get the performance boost. | ||||
* | if_cgem: Use rtems_bsd_get_mac_address() | Sebastian Huber | 2015-01-21 | 1 | -0/+8 |
* | if_cgem: Enable hardware checksum assist | Sebastian Huber | 2015-01-21 | 1 | -0/+5 |
* | if_cgem: Use explicit cache operations | Sebastian Huber | 2015-01-21 | 1 | -0/+72 |
* | if_cgem: Add volatile to rx/tx desc rings | Sebastian Huber | 2015-01-21 | 1 | -4/+4 |
* | if_cgem: Silence warning | Sebastian Huber | 2015-01-21 | 1 | -0/+3 |
* | if_cgem: Add nexus device support | Sebastian Huber | 2015-01-21 | 1 | -0/+6 |
* | if_cgem: Disable device sysctls | Sebastian Huber | 2015-01-21 | 1 | -0/+2 |
* | if_cgem: Workaround for missing FDT support | Sebastian Huber | 2015-01-21 | 1 | -0/+8 |
* | if_cgem: Workaround for if_inc_counter() | Sebastian Huber | 2015-01-21 | 1 | -0/+32 |
* | if_cgem: Import from FreeBSD | Sebastian Huber | 2015-01-21 | 2 | -0/+2210 |
