Git mirror commit a18b0830c4be01b39489a891b63d6023ada6358a.
Update #3472.
Git mirror commit 8dfb1ccc26d1cea7e2529303003ff61f9f1784c4.
Update #3472.
Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266.
Update #3472.
Git mirror commit dfb26efac4ce9101dda240e94d9ab53f80a9e131.
Update #3472.
The following files are now provided by Newlib:
* arpa/inet.h
* net/if.h
* netinet/in.h
* netinet/tcp.h
* sys/socket.h
* sys/uio.h
* sys/un.h
The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be
used directly.
Update #2833.
Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f.
FIXME: This reverts the following change in FreeBSD.
commit 76a39ff8dc5e1f7bc8a065115ec3837761ed0600
Author: ae <ae@FreeBSD.org>
Date: Wed Jul 27 08:26:34 2016 +0000
Due to dropped mbuf in netisr queue route(8) can fall into infinity
loop of reading the rtsock's feed. When it used by some scripts,
this leads to growing number of not finished route(8) instances and
thus growing number of rtsock consumers. Add SIGALRM handler to
prevent this.
Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab.
Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd.
Prepare update to FreeBSD 11.
Some of the commands have been adapted manually. So the wrapper
currently don't necessarily work as expected. For example ifconfig calls
malloc outside of the program call.
This avoids dependencies on a particular generator tool version. On
MinGW and Cygwin hosts these tools tend to be outdated or somehow
incapable.
There is no point in aiming for long term FreeBSD compatibility here.
The issues must be fixed upstream and then move back to the RTEMS port.
Add compatibility with Newlib header files. Some FreeBSD header files
are mapped by the translation script:
o rtems/bsd/sys/_types.h
o rtems/bsd/sys/errno.h
o rtems/bsd/sys/lock.h
o rtems/bsd/sys/param.h
o rtems/bsd/sys/resource.h
o rtems/bsd/sys/time.h
o rtems/bsd/sys/timespec.h
o rtems/bsd/sys/types.h
o rtems/bsd/sys/unistd.h
It is now possible to include <sys/socket.h> directly for example.
Generate one Makefile which builds everything including tests.
