* | Update to FreeBSD head 2018-12-20 | Sebastian Huber | 2018-12-20 | 1 | -16/+16 |
| | | | | | | | | | | Git mirror commit 19a6ceb89dbacf74697d493e48c388767126d418. It includes an update of wpa_supplicant to version 2.7. It includes an update of the OpenSSL baseline to version 1.1.1a. Update #3472. | ||||
* | Update to FreeBSD head 2018-11-15 | Sebastian Huber | 2018-11-15 | 1 | -56/+47 |
| | | | | | | Git mirror commit a18b0830c4be01b39489a891b63d6023ada6358a. Update #3472. | ||||
* | PING(8): Honour file descriptor maximum | Sebastian Huber | 2018-10-10 | 1 | -0/+11 |
* | Update to FreeBSD head 2017-12-01 | Sebastian Huber | 2018-09-21 | 1 | -23/+15 |
| | | | | | | Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266. Update #3472. | ||||
* | Update to FreeBSD head 2017-10-01 | Sebastian Huber | 2018-09-21 | 1 | -11/+11 |
| | | | | | | Git mirror commit b2f0376b45428f13151d229c5ae9d4d8f74acbd1. Update #3472. | ||||
* | Regenerate program header files | Sebastian Huber | 2018-08-28 | 1 | -24/+24 |
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-04-04 | 1 | -1/+1 |
| | | | | Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | Update to FreeBSD head 2017-01-09 | Sebastian Huber | 2017-01-10 | 1 | -2/+5 |
| | | | | Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab. | ||||
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 4 | -139/+305 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | freebsd: Don't use new wrappers for old ports. | Christian Mauderer | 2016-08-02 | 1 | -0/+9 |
| | | | | | | Some of the commands have been adapted manually. So the wrapper currently don't necessarily work as expected. For example ifconfig calls malloc outside of the program call. | ||||
* | Directly use <sys/time.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 1 | -1/+1 |
* | PING(8): Default to three packets | Sebastian Huber | 2014-09-24 | 1 | -1/+1 |
| | | | | | In the standard RTEMS shell it is not possible to use CTRL-C, to stop the program. So use a default with finite run-time. | ||||
* | commands: Use REQUIRE_ORDER option processing | Sebastian Huber | 2013-11-13 | 1 | -1/+1 |
* | Update to FreeBSD 9.2 | Sebastian Huber | 2013-11-11 | 1 | -33/+17 |
* | Add and use <machine/rtems-bsd-user-space.h> | Sebastian Huber | 2013-11-11 | 1 | -0/+2 |
* | PING(8): Fix initialization and cleanup | Sebastian Huber | 2013-10-31 | 1 | -0/+16 |
* | PING(8): Delete unused variable | Sebastian Huber | 2013-10-31 | 1 | -1/+0 |
* | PING(8): Add const qualifier | Sebastian Huber | 2013-10-31 | 1 | -7/+4 |
* | PING(8): Use local scope for global variables | Sebastian Huber | 2013-10-31 | 1 | -42/+42 |
* | PING(8): Use BSD program lock | Sebastian Huber | 2013-10-31 | 1 | -4/+11 |
* | PING(8): Avoid large buffers on the stack | Sebastian Huber | 2013-10-31 | 1 | -0/+10 |
* | PING(8): Fix isxdigit() usage | Sebastian Huber | 2013-10-31 | 1 | -1/+1 |
* | PING(8): Do not use signals | Sebastian Huber | 2013-10-31 | 1 | -11/+12 |
* | Move shell items to separate file | Sebastian Huber | 2013-10-31 | 1 | -14/+2 |
* | Move program control to thread structure | Sebastian Huber | 2013-10-31 | 1 | -31/+26 |
* | Simplify getopt() to getopt_r() translation | Sebastian Huber | 2013-10-31 | 1 | -18/+12 |
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -17/+2 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | Move files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -0/+1810 |
