* | buildset: Add minimal and everything config. | Christian Mauderer | 2018-05-03 | 1 | -0/+2 |
| | | | | | | | | | | | | This adds two new buildset configurations: One that leaves out as much features as possible and one that enables all features. For the default configuration WiFi support is now disabled. To disable IPv6 for the minimal configuration, all -DINET6 are eliminated in libbsd.py. They are now replaced by a #ifdef that checks for RTEMS_BSD_MODULE_NETINET6 instead. Close #3351. | ||||
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-04-04 | 1 | -1/+1 |
| | | | | Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 1 | -392/+323 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | freebsd: Don't use new wrappers for old ports. | Christian Mauderer | 2016-08-02 | 1 | -0/+9 |
| | | | | | | Some of the commands have been adapted manually. So the wrapper currently don't necessarily work as expected. For example ifconfig calls malloc outside of the program call. | ||||
* | Directly use <sys/time.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 1 | -1/+1 |
* | Update to FreeBSD Stable/9 2015-04-08 | Sebastian Huber | 2015-05-20 | 1 | -2/+8 |
* | commands: Use REQUIRE_ORDER option processing | Sebastian Huber | 2013-11-13 | 1 | -1/+1 |
* | Update to FreeBSD 9.2 | Sebastian Huber | 2013-11-11 | 1 | -92/+92 |
* | Add and use <machine/rtems-bsd-user-space.h> | Sebastian Huber | 2013-11-11 | 1 | -0/+2 |
* | PING6(8): Fix resource leaks | Sebastian Huber | 2013-10-31 | 1 | -2/+24 |
* | PING6(8): Add RTEMS support | Sebastian Huber | 2013-10-31 | 1 | -11/+47 |
* | PING6(8): Delete unused variable | Sebastian Huber | 2013-10-31 | 1 | -1/+0 |
* | PING6(8): Fix isxdigit() usage | Sebastian Huber | 2013-10-31 | 1 | -1/+1 |
* | PING6(8): Delete unused variable | Sebastian Huber | 2013-10-31 | 1 | -2/+1 |
* | PING6(8): Add const qualifier | Sebastian Huber | 2013-10-31 | 1 | -4/+4 |
* | PING6(8): Use local scope for functions | Sebastian Huber | 2013-10-31 | 1 | -33/+34 |
* | PING6(8): Use local scope for global variables | Sebastian Huber | 2013-10-31 | 1 | -37/+37 |
* | Simplify getopt() to getopt_r() translation | Sebastian Huber | 2013-10-31 | 1 | -14/+14 |
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -7/+2 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | Move files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -0/+2837 |
