* | IFCONFIG(8): Fix write to const string | Sebastian Huber | 2019-05-13 | 1 | -0/+6 |
* | Update to FreeBSD head 2018-11-15 | Sebastian Huber | 2018-11-15 | 1 | -0/+8 |
| | | | | | | Git mirror commit a18b0830c4be01b39489a891b63d6023ada6358a. Update #3472. | ||||
* | Update to FreeBSD head 2018-10-23 | Sebastian Huber | 2018-10-25 | 1 | -0/+12 |
| | | | | | | | | | | | Git mirror commit 59f44d20be3f99d181ca742e636d45fc39ec982b. This commit updates OpenSSL to version 1.1.1. This required an update of racoon which uses some internal stuff from OpenSSL and seems to be mostly unmaintained, e.g. there is update in the FreeBSD ports to cope with OpenSSL 1.1.1. Update #3472. | ||||
* | Fix typo (RTEMS_BSD_MODULE_NET80211) | Sebastian Huber | 2018-10-02 | 1 | -1/+1 |
* | Update to FreeBSD head 2018-09-17 | Sebastian Huber | 2018-09-21 | 2 | -8/+14 |
| | | | | | | Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319. Update #3472. | ||||
* | Update to FreeBSD head 2018-06-01 | Sebastian Huber | 2018-09-21 | 9 | -79/+23 |
| | | | | | | Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9. Update #3472. | ||||
* | Update to FreeBSD head 2018-04-01 | Sebastian Huber | 2018-09-21 | 3 | -70/+98 |
| | | | | | | Git mirror commit 8dfb1ccc26d1cea7e2529303003ff61f9f1784c4. Update #3472. | ||||
* | Update to FreeBSD head 2018-02-01 | Sebastian Huber | 2018-09-21 | 1 | -24/+37 |
| | | | | | | Git mirror commit d079ae0442af8fa3cfd6d7ede190d04e64a2c0d4. Update #3472. | ||||
* | Update to FreeBSD head 2017-12-01 | Sebastian Huber | 2018-09-21 | 16 | -12/+46 |
| | | | | | | Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266. Update #3472. | ||||
* | Update to FreeBSD head 2017-10-01 | Sebastian Huber | 2018-09-21 | 2 | -2/+10 |
| | | | | | | Git mirror commit b2f0376b45428f13151d229c5ae9d4d8f74acbd1. Update #3472. | ||||
* | Update to FreeBSD head 2017-06-01 | Sebastian Huber | 2018-09-21 | 8 | -47/+82 |
| | | | | | | Git mirror commit dfb26efac4ce9101dda240e94d9ab53f80a9e131. Update #3472. | ||||
* | Regenerate program header files | Sebastian Huber | 2018-08-28 | 17 | -92/+92 |
* | buildset: Add minimal and everything config. | Christian Mauderer | 2018-05-03 | 1 | -0/+5 |
| | | | | | | | | | | | | This adds two new buildset configurations: One that leaves out as much features as possible and one that enables all features. For the default configuration WiFi support is now disabled. To disable IPv6 for the minimal configuration, all -DINET6 are eliminated in libbsd.py. They are now replaced by a #ifdef that checks for RTEMS_BSD_MODULE_NETINET6 instead. Close #3351. | ||||
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 17 | -17/+17 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-04-04 | 7 | -20/+92 |
| | | | | Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | userspace tools: Regenerate headers. | Christian Mauderer | 2017-01-17 | 15 | -22/+22 |
* | ifconfig/wlan, expat, lib80211: Port to RTEMS. | Christian Mauderer | 2017-01-17 | 5 | -2/+48 |
* | ifconfig/wlan, expat, lib80211: Import from FreeBSD. | Christian Mauderer | 2017-01-17 | 2 | -272/+547 |
* | Update to FreeBSD head 2016-12-10 | Sebastian Huber | 2017-01-10 | 3 | -9/+20 |
| | | | | Git mirror commit 80c55f08a05ab3b26a73b226ccb56adc3122a55c. | ||||
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 37 | -463/+2202 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | Remove AppleTalk support | Sebastian Huber | 2016-10-13 | 2 | -193/+0 |
| | | | | Prepare update to FreeBSD 11. | ||||
* | freebsd: Don't use new wrappers for old ports. | Christian Mauderer | 2016-08-02 | 3 | -0/+27 |
| | | | | | | Some of the commands have been adapted manually. So the wrapper currently don't necessarily work as expected. For example ifconfig calls malloc outside of the program call. | ||||
* | Directly use <sys/types.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 6 | -6/+6 |
* | Directly use <sys/time.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 3 | -3/+3 |
* | Update to FreeBSD Stable/9 2015-04-08 | Sebastian Huber | 2015-05-20 | 2 | -3/+5 |
* | Update to FreeBSD 9.3 | Sebastian Huber | 2015-02-13 | 2 | -4/+4 |
* | IFCONFIG(8): Default to AF_INET for RTEMS | Sebastian Huber | 2014-09-24 | 1 | -0/+4 |
| | | | | Avoid errors due to optional AF_LOCAL. | ||||
* | commands: Use REQUIRE_ORDER option processing | Sebastian Huber | 2013-11-13 | 1 | -0/+4 |
* | Update to FreeBSD 9.2 | Sebastian Huber | 2013-11-11 | 8 | -108/+95 |
* | Reduce divergence from FreeBSD sources | Sebastian Huber | 2013-11-11 | 1 | -2/+1 |
* | Add and use <machine/rtems-bsd-user-space.h> | Sebastian Huber | 2013-11-11 | 17 | -0/+34 |
* | Update to FreeBSD 8.4 | Sebastian Huber | 2013-11-04 | 5 | -7/+92 |
* | IFCONFIG(8): Avoid write to const string | Sebastian Huber | 2013-10-31 | 1 | -4/+14 |
* | IFCONFIG(8): Wrap exit() | Sebastian Huber | 2013-10-31 | 2 | -0/+6 |
* | IFCONFIG(8): Fix some resource leaks | Sebastian Huber | 2013-10-31 | 5 | -4/+54 |
* | IFCONFIG(8): Initialize global variables in ctors | Sebastian Huber | 2013-10-31 | 18 | -10/+180 |
* | IFCONFIG(8): Fix isdigit() and isprint() usage | Sebastian Huber | 2013-10-31 | 3 | -4/+4 |
* | IFCONFIG(8): Add const qualifier | Sebastian Huber | 2013-10-31 | 5 | -61/+61 |
* | IFCONFIG(8): Avoid JAIL(3) | Sebastian Huber | 2013-10-31 | 1 | -7/+4 |
* | IFCONFIG(8): Workaround for struct option confict | Sebastian Huber | 2013-10-31 | 5 | -43/+2 |
* | Move shell items to separate file | Sebastian Huber | 2013-10-31 | 1 | -14/+2 |
* | Move program control to thread structure | Sebastian Huber | 2013-10-31 | 1 | -23/+15 |
* | Simplify getopt() to getopt_r() translation | Sebastian Huber | 2013-10-31 | 1 | -15/+12 |
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 20 | -137/+21 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | Move files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 20 | -0/+11372 |
