Git mirror commit 7e8d1444023128d34fb9aa4e4515928a4f794d1b.
Git mirror commit 3427c3416aa3c0f25124070959cca78024b94d85.
Git mirror commit 78576620f2689e23144a1cf1bf55106cc6abe2b7.
Git mirror commit 7005c2e76a6bfb359bf2f1acb8382c0b7a01f4be.
Git mirror commit 4ff7d8141f665693dd8b17090d410604888f1e9a.
Update #3472.
Git mirror commit a18b0830c4be01b39489a891b63d6023ada6358a.
Update #3472.
Git mirror commit 59f44d20be3f99d181ca742e636d45fc39ec982b.
This commit updates OpenSSL to version 1.1.1. This required an update
of racoon which uses some internal stuff from OpenSSL and seems to be
mostly unmaintained, e.g. there is update in the FreeBSD ports to cope
with OpenSSL 1.1.1.
Update #3472.
Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319.
Update #3472.
Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9.
Update #3472.
Git mirror commit 8dfb1ccc26d1cea7e2529303003ff61f9f1784c4.
Update #3472.
Git mirror commit d079ae0442af8fa3cfd6d7ede190d04e64a2c0d4.
Update #3472.
Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266.
Update #3472.
Git mirror commit b2f0376b45428f13151d229c5ae9d4d8f74acbd1.
Update #3472.
Git mirror commit f5002f5e5f78cae9f0269d812dc0aedb0339312c.
Update #3472.
Git mirror commit dfb26efac4ce9101dda240e94d9ab53f80a9e131.
Update #3472.
Use the FreeBSD 11.1 yacc and lex tools to generate the files.
Update #3472.
Update #3472.
Note that this replaces the libipsec from FreeBSD with the one provided
by ipsec-tools.
This adds two new buildset configurations: One that leaves out as much
features as possible and one that enables all features. For the default
configuration WiFi support is now disabled.
To disable IPv6 for the minimal configuration, all -DINET6 are
eliminated in libbsd.py. They are now replaced by a #ifdef that checks
for RTEMS_BSD_MODULE_NETINET6 instead.
Close #3351.
This is now provided by Newlib.
This change requires a Newlib from 2017-06-12 or later.
The following files are now provided by Newlib:
* arpa/inet.h
* net/if.h
* netinet/in.h
* netinet/tcp.h
* sys/socket.h
* sys/uio.h
* sys/un.h
The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be
used directly.
Update #2833.
Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f.
Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab.
Git mirror commit 80c55f08a05ab3b26a73b226ccb56adc3122a55c.
Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd.
This is necessary for a configuration without IPv6.
Some of the commands have been adapted manually. So the wrapper
currently don't necessarily work as expected. For example ifconfig calls
malloc outside of the program call.
Update nsparser.h to fit with the files introduced via
e35a65e99512000ab0107c4fc64f89aa84f7de38.
Use the FreeBSD lex, yacc and rpcgen tools to generate the various
sources used in LibBSD. The change also removes an RTEMS specific change
added when using other hosts operating systems to generate the files.
LibBSD should use FreeBSD version of the tools to generate the source
because the FreeBSD kernel is developed using them.
The change is supported by the waf build which disables generating
the files unless enabled. I am not sure the effect with the Makefile
build support.
This avoids dependencies on a particular generator tool version. On
MinGW and Cygwin hosts these tools tend to be outdated or somehow
incapable.
