* | buildset: Add minimal and everything config. | Christian Mauderer | 2018-05-03 | 1 | -1/+0 |
| | | | | | | | | | | | | This adds two new buildset configurations: One that leaves out as much features as possible and one that enables all features. For the default configuration WiFi support is now disabled. To disable IPv6 for the minimal configuration, all -DINET6 are eliminated in libbsd.py. They are now replaced by a #ifdef that checks for RTEMS_BSD_MODULE_NETINET6 instead. Close #3351. | ||||
* | Remove strtoimax() and strtoumax() | Sebastian Huber | 2017-08-22 | 2 | -308/+0 |
| | | | | This is now provided by Newlib. | ||||
* | Remove unused inet_* weak references | Sebastian Huber | 2017-06-22 | 1 | -0/+2 |
| | | | | This change requires a Newlib from 2017-06-12 or later. | ||||
* | Remove unused inet_* weak references | Sebastian Huber | 2017-06-16 | 11 | -0/+22 |
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 73 | -75/+75 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-04-04 | 67 | -102/+144 |
| | | | | Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | freebsd/wlanstats: Import from FreeBSD. | Christian Mauderer | 2017-01-17 | 2 | -0/+336 |
* | lib80211/regdomain: Port to RTEMS. | Christian Mauderer | 2017-01-17 | 1 | -0/+19 |
* | lib80211/regdomain: Import from FreeBSD. | Christian Mauderer | 2017-01-17 | 1 | -9/+0 |
* | ifconfig/wlan, expat, lib80211: Port to RTEMS. | Christian Mauderer | 2017-01-17 | 1 | -0/+9 |
* | ifconfig/wlan, expat, lib80211: Import from FreeBSD. | Christian Mauderer | 2017-01-17 | 4 | -0/+1096 |
* | Update to FreeBSD head 2017-01-09 | Sebastian Huber | 2017-01-10 | 6 | -86/+69 |
| | | | | Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab. | ||||
* | Update to FreeBSD head 2016-12-10 | Sebastian Huber | 2017-01-10 | 9 | -27/+87 |
| | | | | Git mirror commit 80c55f08a05ab3b26a73b226ccb56adc3122a55c. | ||||
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 152 | -2551/+2571 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | Port getdomainname() to RTEMS | Sebastian Huber | 2016-09-07 | 1 | -0/+4 |
* | Import getdomainname() | Sebastian Huber | 2016-09-07 | 1 | -0/+57 |
* | freebsd: Add constant ipv6 addresses from vars.c. | Christian Mauderer | 2016-08-04 | 1 | -0/+2 |
| | | | | This is necessary for a configuration without IPv6. | ||||
* | freebsd: Don't use new wrappers for old ports. | Christian Mauderer | 2016-08-02 | 1 | -0/+9 |
| | | | | | | Some of the commands have been adapted manually. So the wrapper currently don't necessarily work as expected. For example ifconfig calls malloc outside of the program call. | ||||
* | reentrant.h: There is no main thread in RTEMS | Sebastian Huber | 2016-06-15 | 1 | -0/+4 |
* | XDR(3): Port to RTEMS | Sebastian Huber | 2016-06-10 | 4 | -6/+8 |
* | XDR(3): Import from FreeBSD | Sebastian Huber | 2016-06-10 | 8 | -0/+3017 |
* | RPC(3): Port to RTEMS | Sebastian Huber | 2016-06-10 | 2 | -1/+6 |
* | RPC(3): Import from FreeBSD | Sebastian Huber | 2016-06-10 | 57 | -0/+19078 |
* | Directly use <sys/_types.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 3 | -4/+4 |
* | Directly use <sys/types.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 76 | -76/+76 |
* | Directly use <sys/time.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 7 | -7/+7 |
* | Add sbin/sysctl | Chris Johns | 2016-05-06 | 2 | -0/+308 |
* | NSDISPATCH(3): Add proper nsparser.h | Sebastian Huber | 2015-10-19 | 1 | -102/+16 |
| | | | | | Update nsparser.h to fit with the files introduced via e35a65e99512000ab0107c4fc64f89aa84f7de38. | ||||
* | Provide the missing cdecl for _nsdispatch. | Chris Johns | 2015-06-16 | 1 | -0/+3 |
* | Regenerate with FreeBSD lex, yacc, and rpcgen tools. | Chris Johns | 2015-05-27 | 5 | -3705/+1513 |
| | | | | | | | | | | | | | Use the FreeBSD lex, yacc and rpcgen tools to generate the various sources used in LibBSD. The change also removes an RTEMS specific change added when using other hosts operating systems to generate the files. LibBSD should use FreeBSD version of the tools to generate the source because the FreeBSD kernel is developed using them. The change is supported by the waf build which disables generating the files unless enabled. I am not sure the effect with the Makefile build support. | ||||
* | Update to FreeBSD Stable/9 2015-04-08 | Sebastian Huber | 2015-05-20 | 33 | -201/+885 |
* | Add generated files | Sebastian Huber | 2015-04-08 | 6 | -0/+8049 |
| | | | | | | This avoids dependencies on a particular generator tool version. On MinGW and Cygwin hosts these tools tend to be outdated or somehow incapable. | ||||
* | Update to FreeBSD 9.3 | Sebastian Huber | 2015-02-13 | 2 | -30/+82 |
* | LIBMEMSTAT(3): Disable malloc sysctls | Sebastian Huber | 2015-01-29 | 1 | -0/+2 |
* | NSDISPATCH(3): Add rtems_nss_register_module() | Sebastian Huber | 2014-11-04 | 1 | -6/+52 |
* | Support sethostname() and gethostname() | Sebastian Huber | 2014-10-24 | 1 | -0/+57 |
* | Changes due to <sys/cpuset.h> from latest Newlib | Sebastian Huber | 2013-12-04 | 1 | -1/+1 |
* | NSDISPATCH(3): Fix for small-data area | Sebastian Huber | 2013-12-04 | 1 | -2/+2 |
* | DISPATCH(3): Assume static linking | Sebastian Huber | 2013-12-04 | 1 | -0/+4 |
* | Update to FreeBSD 9.2 | Sebastian Huber | 2013-11-11 | 21 | -218/+347 |
* | Reduce divergence from FreeBSD sources | Sebastian Huber | 2013-11-11 | 10 | -44/+21 |
* | Move content to <machine/rtems-bsd-user-space.h> | Sebastian Huber | 2013-11-11 | 1 | -7/+0 |
* | Add and use <machine/rtems-bsd-user-space.h> | Sebastian Huber | 2013-11-11 | 109 | -0/+218 |
* | Update to FreeBSD 8.4 | Sebastian Huber | 2013-11-04 | 9 | -46/+140 |
* | lib/libc/net/ip6opt.c: Add from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+593 |
* | lib/libc/net/rthdr.c: Add from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+450 |
* | Revert superfluous changes | Sebastian Huber | 2013-10-31 | 75 | -153/+5 |
* | Use unmodified FreeBSD versions for port_*.h | Sebastian Huber | 2013-10-31 | 3 | -1/+57 |
* | Add MAC support functions | Sebastian Huber | 2013-10-31 | 1 | -0/+449 |
| | | | | WARNING: They are not thread-safe! This is a known FreeBSD issue. | ||||
* | Move program control to thread structure | Sebastian Huber | 2013-10-31 | 1 | -0/+12 |
