* | Update to FreeBSD head 2017-12-01 | Sebastian Huber | 2018-09-21 | 1 | -0/+2 |
| | | | | | | Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266. Update #3472. | ||||
* | Regenerate program header files | Sebastian Huber | 2018-08-28 | 3 | -18/+18 |
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Updating STTY command for use in RTEMS shell | Kevin Kirspel | 2017-05-11 | 16 | -0/+175 |
* | Adding stty command files from FREEBSD tree | Kevin Kirspel | 2017-05-11 | 9 | -0/+1433 |
* | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-04-04 | 1 | -1/+1 |
| | | | | Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | Update to FreeBSD head 2016-12-10 | Sebastian Huber | 2017-01-10 | 1 | -5/+17 |
| | | | | Git mirror commit 80c55f08a05ab3b26a73b226ccb56adc3122a55c. | ||||
* | freebsd: Don't use new wrappers for old ports. | Christian Mauderer | 2016-08-02 | 1 | -0/+9 |
| | | | | | | Some of the commands have been adapted manually. So the wrapper currently don't necessarily work as expected. For example ifconfig calls malloc outside of the program call. | ||||
* | HOSTNAME(1): Add -m flag | Sebastian Huber | 2014-11-20 | 1 | -2/+29 |
* | HOSTNAME(1): Import from FreeBSD | Sebastian Huber | 2014-11-05 | 1 | -0/+143 |
