* | Support sethostname() and gethostname() | Sebastian Huber | 2014-10-24 | 1 | -0/+1 |
* | ppp: Port to new stack | Sebastian Huber | 2014-10-08 | 1 | -0/+20 |
* | nexus: Use a linker set for the devices | Sebastian Huber | 2014-10-08 | 1 | -1/+0 |
* | Provide new rtems_bsdnet_rtrequest() | Sebastian Huber | 2014-10-08 | 1 | -1/+1 |
| | | | | Delete superfluous code. | ||||
* | Makefile: Remove superfluous include path | Sebastian Huber | 2014-10-08 | 1 | -1/+0 |
* | critical_enter/exit(): Use inline function | Sebastian Huber | 2014-09-30 | 1 | -1/+0 |
* | rtems_bsd_mutex: Optimize | Sebastian Huber | 2014-09-24 | 1 | -0/+1 |
* | Replace RTEMS objects with custom implementation | Sebastian Huber | 2014-09-23 | 1 | -0/+2 |
| | | | | | | | | Performance analysis revealed that the standard RTEMS objects are a major bottleneck. The object get mechanism and attribute checks at runtime have a significant overhead. Use a custom implementation for synchronization primitives. This drops also the size of the synchronization primitives considerably. | ||||
* | Disable IPsec | Sebastian Huber | 2014-09-23 | 1 | -3/+3 |
| | | | | | IPsec has a significant performance impact. Disable it for now since is only partially supported and untested. | ||||
* | Import and use subr_lock.c | Sebastian Huber | 2014-09-22 | 1 | -1/+1 |
* | Install missing header files | Sebastian Huber | 2014-09-22 | 1 | -0/+3 |
* | Makefile: Add -fno-strict-aliasing | Sebastian Huber | 2014-09-18 | 1 | -0/+1 |
* | telnetd01: New test | Sebastian Huber | 2014-09-18 | 1 | -0/+1 |
* | telnetd: Import from RTEMS sources | Sebastian Huber | 2014-09-18 | 1 | -0/+4 |
* | Add file to ensure some C++ compatibility | Sebastian Huber | 2014-09-17 | 1 | -27/+31 |
* | Install missing header files | Sebastian Huber | 2014-08-28 | 1 | -1/+4 |
* | Fix library creation | Sebastian Huber | 2014-08-28 | 1 | -0/+1 |
| | | | | | Delete library and create it from scratch to avoid problems with non-unique file names. | ||||
* | mDNS: Add basic support | Sebastian Huber | 2014-01-30 | 1 | -0/+28 |
* | DHCPCD(8): Add basic support | Sebastian Huber | 2014-01-30 | 1 | -0/+37 |
* | arphole: New test | Sebastian Huber | 2014-01-30 | 1 | -0/+1 |
* | Add an ARP packet processor | Sebastian Huber | 2014-01-30 | 1 | -0/+1 |
* | Add rtems_bsd_get_ethernet_addr() | Sebastian Huber | 2014-01-30 | 1 | -0/+1 |
* | UNIX(4): Import from FreeBSD | Sebastian Huber | 2014-01-16 | 1 | -0/+2 |
* | Fix install Makefile target | Sebastian Huber | 2013-12-20 | 1 | -17/+14 |
* | Delete rtems_bsd_initialize_with_interrupt_server | Sebastian Huber | 2013-12-20 | 1 | -1/+0 |
| | | | | Move interrupt server initialization to nexus_probe(). | ||||
* | Simplify config.inc and use new reference BSP | Sebastian Huber | 2013-12-20 | 1 | -0/+1 |
| | | | | | | | Use arm/realview_pbx_a9_qemu as the new reference BSP. This BSP offeres NULL pointer read/write protection and runs on the Qemu simulator. With this BSP it is possible to run network tests which use a virtual network based on TAP devices. | ||||
* | Always enable IPv6 | Sebastian Huber | 2013-12-20 | 1 | -13/+1 |
* | Add -Wno-format | Sebastian Huber | 2013-12-20 | 1 | -0/+1 |
* | Enable compiler warnings | Sebastian Huber | 2013-12-20 | 1 | -1/+1 |
* | Define INET6 for relevant sources | Sebastian Huber | 2013-12-16 | 1 | -3/+3 |
* | Define __DBINTERFACE_PRIVATE for relevant sources | Sebastian Huber | 2013-12-16 | 1 | -1/+5 |
* | Allow source file set specific compiler flags | Sebastian Huber | 2013-12-16 | 1 | -13/+20 |
* | Move __FreeBSD__ define to header files | Sebastian Huber | 2013-12-16 | 1 | -1/+0 |
* | Script changes | Sebastian Huber | 2013-12-16 | 1 | -72/+75 |
| | | | | | | Rename Module::addHeaderFiles() to Module::addKernelSpaceHeaderFiles() and Module::addSourceFiles() to Module::addKernelSpaceSourceFiles(). Add new Module::addSourceFiles(). | ||||
* | Add and use FreeBSDPathComposer() | Sebastian Huber | 2013-12-16 | 1 | -11/+19 |
* | Move <sys/_cpuset.h> | Sebastian Huber | 2013-12-16 | 1 | -2/+0 |
* | Add legacy MCF548X FEC interface driver | Sebastian Huber | 2013-12-16 | 1 | -0/+1 |
* | Add RTEMS legacy MII support | Sebastian Huber | 2013-12-16 | 1 | -0/+1 |
* | Add support for M68K | Sebastian Huber | 2013-12-16 | 1 | -1/+1 |
* | ftpd01: New test | Sebastian Huber | 2013-12-16 | 1 | -0/+2 |
* | Changes due to <sys/cpuset.h> from latest Newlib | Sebastian Huber | 2013-12-04 | 1 | -0/+1 |
* | ping01: New test | Sebastian Huber | 2013-11-13 | 1 | -0/+1 |
* | Add network test support | Sebastian Huber | 2013-11-13 | 1 | -6/+28 |
* | if_smc: Add Nexus device support | Sebastian Huber | 2013-11-13 | 1 | -0/+1 |
* | if_tsec: Add from FreeBSD | Sebastian Huber | 2013-11-13 | 1 | -0/+4 |
* | nexus: Add table based Nexus device initialization | Sebastian Huber | 2013-11-13 | 1 | -0/+1 |
* | Update to FreeBSD 9.2 | Sebastian Huber | 2013-11-11 | 1 | -36/+59 |
* | Reduce divergence from FreeBSD sources | Sebastian Huber | 2013-11-11 | 1 | -1/+6 |
* | Add and use <machine/rtems-bsd-user-space.h> | Sebastian Huber | 2013-11-11 | 1 | -0/+2 |
* | Rename rtems-bsd-config.h | Sebastian Huber | 2013-11-11 | 1 | -5/+5 |
| | | | | Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h. |
