* | freebsd-to-rtems.py - Only copy if new version of file is different | Joel Sherrill | 2012-03-08 | 1 | -6/+28 |
* | All RTEMS files should now be under RTEMS | Joel Sherrill | 2012-03-08 | 1 | -53/+56 |
| | | | | - Also add "Makefile only" mode to freebsd-to-rtems.py | ||||
* | More comments. Attempt to support forward/revert selection from command line | Joel Sherrill | 2012-03-08 | 1 | -86/+106 |
* | Remove leading rtems/ directory from paths under rtemsbsd | Joel Sherrill | 2012-03-08 | 1 | -2/+4 |
* | freebsd-to-rtems.py Enhancements | Joel Sherrill | 2012-03-08 | 1 | -12/+73 |
| | | | | | | | | + dry-run mode + early-exit mode + more verbose output + usage message improved + FreeBSD and RTEMS Directory error checking | ||||
* | Generate without rtems/ on includes | Joel Sherrill | 2012-03-08 | 1 | -27/+89 |
* | Modifications to separate RTEMS BSD files from FreeBSD files | Joel Sherrill | 2012-03-07 | 1 | -75/+82 |
* | Initial version. | Sebastian Huber | 2012-03-07 | 1 | -0/+1565 |
