path: root/dhcpcd (follow)
* Directly use <sys/time.h> provided by NewlibSebastian Huber2016-05-301-1/+1
* DHCPCD(8): Add MASTER_ONLY optionSebastian Huber2014-01-301-1/+38
* DHCPCD(8): Disable script supportSebastian Huber2014-01-301-0/+11
* DHCPCD(8): Add getopt_long_r() supportSebastian Huber2014-01-302-0/+8
* DHCPCD(8): Add RTEMS program supportSebastian Huber2014-01-301-0/+18
* DHCPCD(8): Use select() instead of pselect()Sebastian Huber2014-01-301-1/+11
* DHCPCD(8): Add config.hSebastian Huber2014-01-301-0/+32
* DHCPCD(8): Add namespace headerSebastian Huber2014-01-301-0/+170
* DHCPCD(8): Add automatically generated filesSebastian Huber2014-01-302-0/+260
* DHCPCD(8): ImportSebastian Huber2014-01-3099-0/+27922
Import DHCPCD(8) from: http://roy.marples.name/projects/dhcpcd/ The upstream sources can be obtained via: fossil clone http://roy.marples.name/projects/dhcpcd The imported version is 2014-01-29 19:46:44 [6b209507bb].
