2018-05-08 | dhcpcd: Add hooks | Sebastian Huber | 1 | -5/+1 | |
2014-01-30 | DHCPCD(8): Disable script support | Sebastian Huber | 1 | -0/+11 | |
2014-01-30 | DHCPCD(8): Import | Sebastian Huber | 1 | -9/+14 | |
Import DHCPCD(8) from: http://roy.marples.name/projects/dhcpcd/ The upstream sources can be obtained via: fossil clone http://roy.marples.name/projects/dhcpcd The imported version is 2014-01-29 19:46:44 [6b209507bb]. | |||||
2013-10-10 | Update files to match FreeBSD layout | Sebastian Huber | 1 | -12/+9 | |
Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | |||||
2013-10-10 | Move files to match FreeBSD layout | Sebastian Huber | 1 | -0/+0 | |
2012-03-08 | Move rtems/freebsd to freebsd and contrib to freebsd/contrib | Joel Sherrill | 1 | -0/+0 | |
