Use arm/realview_pbx_a9_qemu as the new reference BSP. This BSP offeres
NULL pointer read/write protection and runs on the Qemu simulator. With
this BSP it is possible to run network tests which use a virtual network
based on TAP devices.
Add compatibility with Newlib header files. Some FreeBSD header files
are mapped by the translation script:
o rtems/bsd/sys/_types.h
o rtems/bsd/sys/errno.h
o rtems/bsd/sys/lock.h
o rtems/bsd/sys/param.h
o rtems/bsd/sys/resource.h
o rtems/bsd/sys/time.h
o rtems/bsd/sys/timespec.h
o rtems/bsd/sys/types.h
o rtems/bsd/sys/unistd.h
It is now possible to include <sys/socket.h> directly for example.
Generate one Makefile which builds everything including tests.
If you define DISABLE_IPV6=yes to the config.inc, then the
rtems-bsd-config.h file will be modified accordingly and
the IPV6 kernel sources will not be built. This is easier
to manage and more correct than having a patch to do the same.
This makes the settings available for use in other Makefiles.
Specifically when tests are added.
