2019-06-29 | iicbus: port to RTEMS | Vijay Kumar Banerjee | 1 | -0/+13 | |
2019-04-02 | Remove pcap_version.h | Vijay Kumar Banerjee | 1 | -4/+0 | |
2018-11-15 | Update to FreeBSD head 2018-11-15 | Sebastian Huber | 1 | -2/+2 | |
Git mirror commit a18b0830c4be01b39489a891b63d6023ada6358a. Update #3472. | |||||
2018-10-25 | Update to FreeBSD head 2018-10-23 | Sebastian Huber | 1 | -0/+2 | |
Git mirror commit 59f44d20be3f99d181ca742e636d45fc39ec982b. This commit updates OpenSSL to version 1.1.1. This required an update of racoon which uses some internal stuff from OpenSSL and seems to be mostly unmaintained, e.g. there is update in the FreeBSD ports to cope with OpenSSL 1.1.1. Update #3472. | |||||
2018-09-21 | Update to FreeBSD head 2018-09-17 | Sebastian Huber | 1 | -2/+12 | |
Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319. Update #3472. | |||||
2018-08-28 | Regenerate program header files | Sebastian Huber | 1 | -0/+17 | |
2018-08-28 | Update yacc and lex generated files | Sebastian Huber | 1 | -17/+47 | |
Use the FreeBSD 11.1 yacc and lex tools to generate the files. Update #3472. | |||||
2017-11-10 | Port BBB sd driver files to RTEMS. | Sichen Zhao | 1 | -0/+26 | |
So BBB can mount and read eMMC and SD card. | |||||
2017-10-09 | Update libpcap to FreeBSD head 2017-04-04 | Sebastian Huber | 1 | -0/+22 | |
Update libpcap from Git mirror commit 99a648a912e81e29d9c4c159cbbe263462f2d719 to 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | |||||
2017-08-02 | Port rtl8188eu driver to RTEMS. | Sichen Zhao | 1 | -0/+6 | |
Now USB dongle rtl8188eu can work as wlan client device. It can scan wifi, connect unencrypted wifi. | |||||
2017-04-04 | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 1 | -0/+10 | |
Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | |||||
2017-03-08 | FDT(4): Port to RTEMS | Sebastian Huber | 1 | -0/+20 | |
2017-01-17 | wlan/run: Add firmware. | Christian Mauderer | 1 | -0/+6 | |
2017-01-17 | rtwn: Port to RTEMS | Christian Mauderer | 1 | -4/+4 | |
2017-01-17 | lib80211/regdomain: Port to RTEMS. | Christian Mauderer | 1 | -0/+8 | |
2017-01-17 | firmware-gen.py: Add script to generate firmware c files. | Christian Mauderer | 1 | -0/+6 | |
2017-01-10 | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 1 | -0/+40 | |
Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | |||||
2015-03-26 | mmc: Import MMC/SDCard support from libusb | Sebastian Huber | 1 | -47/+12 | |
2014-01-30 | Add Makefile.todo | Sebastian Huber | 1 | -0/+141 | |
