systems.
Split the freebsd-to-rtems.py into separate parts to allow more than
a single build system generator.
This avoids dependencies on a particular generator tool version. On
MinGW and Cygwin hosts these tools tend to be outdated or somehow
incapable.
Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h.
Add compatibility with Newlib header files. Some FreeBSD header files
are mapped by the translation script:
o rtems/bsd/sys/_types.h
o rtems/bsd/sys/errno.h
o rtems/bsd/sys/lock.h
o rtems/bsd/sys/param.h
o rtems/bsd/sys/resource.h
o rtems/bsd/sys/time.h
o rtems/bsd/sys/timespec.h
o rtems/bsd/sys/types.h
o rtems/bsd/sys/unistd.h
It is now possible to include <sys/socket.h> directly for example.
Generate one Makefile which builds everything including tests.
The implementation uses an array of strings and variable names. The
names are weak symbolic references to the items we have seen calls
to kvm services with.
This file uses dynamic loading and is using some magic for
statically linked modules included in it. These modules may
or may not show up magically in an RTEMS executable. This will
eventually have to be investigated and resolved.
If you define DISABLE_IPV6=yes to the config.inc, then the
rtems-bsd-config.h file will be modified accordingly and
the IPV6 kernel sources will not be built. This is easier
to manage and more correct than having a patch to do the same.
