Close #3670.
The initial conversion was done by Christopher Kerl as part of GCI 2013.
Finally merged as part of GCI 2018.
This is part of the Livermore pthread examples from
https://computing.llnl.gov/tutorials/pthreads/
Closes #2087.
Closes #3531.
Closes #3158.
Update #3158.
Fixes commit 579cc3c468c0dc923e37474e38c778bc2d085382
Traceback (most recent call last):
File "/home/cdesai/bin/.waf-1.7.13-8c328f55ac27cdb03b8c949f189bbac3/waflib/Scripting.py", line 97, in waf_entry_point
run_commands()
File "/home/cdesai/bin/.waf-1.7.13-8c328f55ac27cdb03b8c949f189bbac3/waflib/Scripting.py", line 153, in run_commands
ctx=run_command(cmd_name)
File "/home/cdesai/bin/.waf-1.7.13-8c328f55ac27cdb03b8c949f189bbac3/waflib/Scripting.py", line 146, in run_command
ctx.execute()
File "/home/cdesai/bin/.waf-1.7.13-8c328f55ac27cdb03b8c949f189bbac3/waflib/Scripting.py", line 351, in execute
return execute_method(self)
File "/home/cdesai/bin/.waf-1.7.13-8c328f55ac27cdb03b8c949f189bbac3/waflib/Build.py", line 106, in execute
self.execute_build()
File "/home/cdesai/bin/.waf-1.7.13-8c328f55ac27cdb03b8c949f189bbac3/waflib/Build.py", line 109, in execute_build
self.recurse([self.run_dir])
File "/home/cdesai/bin/.waf-1.7.13-8c328f55ac27cdb03b8c949f189bbac3/waflib/Context.py", line 128, in recurse
user_function(self)
File "/home/cdesai/rtems/examples-v2/wscript", line 45, in build
bld.recurse('posix_api')
user_function(self)
File "/home/cdesai/rtems/examples-v2/posix_api/wscript", line 9, in build
if rtems.check_posix():
TypeError: check_posix() takes exactly 1 argument (0 given)
Add wscript(s) for building with waf
* Makefile: Update to account for movement of .cfg files.
* psx_example_1/.cvsignore, psx_example_2/.cvsignore,
psx_example_3/.cvsignore, psx_sched_report/.cvsignore: New files.
* ChangeLog, Makefile, psx_example_1/Makefile, psx_example_1/test1.c,
psx_example_2/Makefile, psx_example_2/test2.c,
psx_example_3/Makefile, psx_example_3/test3.c,
psx_sched_report/Makefile, psx_sched_report/README,
psx_sched_report/test.c: New files.
