* | Replace deprecated CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS with ↵ | Vijay Kumar Banerjee | 2020-03-17 | 3 | -3/+3 |
| | | | | CONFIGURE_MAXIMUM_FILE_DESCRIPTORS | ||||
* | Remove obsolete Termios configuration | Sebastian Huber | 2019-01-07 | 1 | -6/+0 |
| | | | | Update #3670. | ||||
* | Fix warnings | Sebastian Huber | 2017-10-12 | 1 | -2/+2 |
| | | | | Update #3158. | ||||
* | waf: append .exe to target names | Gedare Bloom | 2013-12-12 | 1 | -1/+1 |
* | misc: Add a commented out call to build adamain with waf | Chirayu Desai | 2013-12-12 | 1 | -0/+2 |
| | | | | | * Currently disabled as it doesn't build, even with make. Refer commit 0da2dccb01e2aa13eeab492e2f5ca012ca3a2fab | ||||
* | misc: adamain: Add support for building waf | Chirayu Desai | 2013-12-12 | 1 | -0/+14 |
| | | | | | But do not build it by default yet. Also see commit 9dd07ee6bb99bf57e7a9b5fb819dad88f2657ac4 | ||||
* | misc: applib: Add support to build with waf | Chirayu Desai | 2013-12-12 | 2 | -0/+15 |
| | | | | Add wscript for building a static library with waf | ||||
* | misc: Support building qemu_vfat with waf | Chirayu Desai | 2013-12-12 | 1 | -0/+1 |
* | misc: nanosecond_tick_wrap: Add support to build with waf | Chirayu Desai | 2013-12-12 | 2 | -0/+15 |
| | | | | Add wscript to support building with waf | ||||
* | misc: bspcmdline: Add support to build with waf | Chirayu Desai | 2013-12-12 | 2 | -0/+16 |
* | misc: add missing ".exe" suffix to target | Chirayu Desai | 2013-12-12 | 3 | -3/+3 |
* | misc: qemu_vfat: Add support to build with waf | Chirayu Desai | 2013-12-12 | 1 | -0/+18 |
| | | | | | | | * Add a wscript file, but it isn't added to misc/wscript as qemu_vfat doesn't build for all platforms even with make TODO: Invetigate more and find a proper fix | ||||
* | misc: x86_display_cpu: Add support to build with waf | Chirayu Desai | 2013-12-12 | 2 | -0/+18 |
| | | | | | Add wscript to support building with waf Build only if architecture is i386 | ||||
* | Convert misc/minimum example to Waf. | Bryan Dunsmore | 2013-12-12 | 2 | -0/+24 |
* | misc: qemu_vfat: update for new mount table values | Chirayu Desai | 2013-11-30 | 1 | -1/+1 |
| | | | | | | Refer rtems.git commit 29e92b090c8bc35745aa5c89231ce806bcb11e57 for more info Bug: https://www.rtems.org/bugzilla/show_bug.cgi?id=2155 | ||||
* | examples-v2: Remove ChangeLog files | Joel Sherrill | 2013-03-12 | 1 | -71/+0 |
* | examples-v2: Remove .cvsignore files | Joel Sherrill | 2013-03-12 | 7 | -7/+0 |
* | examples-v2 - Remove CVS Ids (scripted) | Joel Sherrill | 2012-05-15 | 20 | -64/+0 |
* | 2011-04-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-04-01 | 2 | -1/+5 |
| | | | | * Makefile: Update to account for movement of .cfg files. | ||||
* | Fix pr number. | Joel Sherrill | 2011-03-03 | 1 | -1/+1 |
* | 2011-03-03 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-03-03 | 6 | -1/+141 |
| | | | | | | | PR 1749/bsps * Makefile: Add new test program for wrapping clock tick. * nanosecond_tick_wrap/.cvsignore, nanosecond_tick_wrap/Makefile, nanosecond_tick_wrap/README, nanosecond_tick_wrap/init.c: New files. | ||||
* | 2010-05-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-05-05 | 5 | -2/+102 |
| | | | | | | * qemu_vfat/Makefile, qemu_vfat/README, qemu_vfat/init.c: Now includes a start_test example which parses arguments. * qemu_vfat/start_test.c: New file. | ||||
* | 2010-05-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-05-05 | 6 | -0/+339 |
| | | | | | * qemu_vfat/.cvsignore, qemu_vfat/Makefile, qemu_vfat/README, qemu_vfat/init.c, qemu_vfat/system.h: New files. | ||||
* | 2010-04-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-04-15 | 3 | -4/+7 |
| | | | | * x86_display_cpu/Makefile, x86_display_cpu/test.c: Clean up. | ||||
* | 2010-04-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-04-14 | 4 | -0/+67 |
| | | | | | * x86_display_cpu/.cvsignore, x86_display_cpu/Makefile, x86_display_cpu/test.c: New files. | ||||
* | 2010-04-08 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-08 | 2 | -1/+11 |
| | | | | | * Makefile: Do not build adamain automatically until there is a way to know if the Ada support was built. | ||||
* | 2009-12-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-12-10 | 7 | -1/+364 |
| | | | | | | | | * Makefile: Add adamain test. This is a strictly C version of the startup code for a GNAT Ada application. If this does not run, then Ada code has no prayer of running. * adamain/.cvsignore, adamain/Makefile, adamain/README, adamain/adacode.c, adamain/rtems_init.c: New files. | ||||
* | 2009-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-14 | 5 | -0/+72 |
| | | | | | * applib/Makefile, applib/file_1.c, applib/private.h, applib/userLib.h: New files. | ||||
* | 2009-09-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-24 | 5 | -1/+41 |
| | | | | | | | * Makefile: Add example for extracting values from RTEMS Application Makefile infrastructure. * extract_example/.cvsignore, extract_example/Makefile, extract_example/README: New files. | ||||
* | 2009-08-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-07 | 6 | -1/+127 |
| | | | | | | | * Makefile: Add new program to demonstrate use of BSP command line arguments. * bspcmdline/.cvsignore, bspcmdline/Makefile, bspcmdline/README, bspcmdline/test.c: New files. | ||||
* | 2009-08-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-06 | 2 | -2/+4 |
| | | | | * minimum/test.c: Remove warning. | ||||
* | 2009-08-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-06 | 1 | -0/+4 |
| | | | | * ChangeLog: New file. | ||||
* | Initial import of reorganized examples.initialbase | Joel Sherrill | 2009-08-06 | 4 | -0/+149 |
