* 2009-12-08 Sebastian Huber <sebastian.huber@embedded-brains.de>HEADmasterSebastian Huber2009-12-0813-231/+231
| | | | | | | | | | | | | | | * src/org/rtems/cdt/Activator.java, src/org/rtems/cdt/Constants.java, src/org/rtems/cdt/Storage.java, src/org/rtems/cdt/VolatilePreferenceStore.java, src/org/rtems/cdt/build/CommandLineGenerator.java, src/org/rtems/cdt/build/CygwinScannerInfoCollector.java, src/org/rtems/cdt/build/EnvironmentSupplier.java, src/org/rtems/cdt/build/RunScannerInfoProvider.java, src/org/rtems/cdt/preferences/PreferenceInitializer.java, src/org/rtems/cdt/preferences/PreferencePage.java, src/org/rtems/cdt/properties/PropertyPage.java, src/org/rtems/cdt/wizards/BasicSetup.java, src/org/rtems/cdt/wizards/FinishSetup.java: Replaced '( ' with '('.
* Update to version 1.4.0.Sebastian Huber2009-11-3010-1023/+19
* New version 1.4.0 with qualifier.Sebastian Huber2009-11-301-5/+5
| | | | | New ID. URL cosmetics.
* Added qualifier to version.Sebastian Huber2009-11-301-1/+1
* Added ":" to option descriptions.Sebastian Huber2009-11-271-7/+7
* New version 1.4.0.Sebastian Huber2009-11-271-1/+1
* Added preference and property to disable tool options derived from BSP settings.Sebastian Huber2009-11-276-7/+38
* Fixed nature filter for C++ compiler.Sebastian Huber2009-11-271-5/+21
| | | | Added "envVarBuildPath" to GCC derived tools.
* Derive GCC based tools from new super class.Sebastian Huber2009-11-262-17/+34
| | | | | Fixed option filter. Discard pipe option.
* Added GCC assembler tool.Sebastian Huber2009-11-262-42/+342
| | | | Added names for all tools.
* Removed workaround since the tool commands use now absolute paths.Sebastian Huber2009-11-261-8/+1
* Workaround for tools with a long file names under Windows and the internal ↵Sebastian Huber2009-11-261-0/+10
| | | | builder from CDT.
* Added input type for assembler.Sebastian Huber2009-07-151-0/+6
* Update for version 1.3.0.Sebastian Huber2009-03-313-2/+5
* Changed version.Sebastian Huber2009-03-312-7/+7
| | | | Changed vendor name.
* New version.Sebastian Huber2009-03-311-3/+3
| | | | Changed plug-in and vendor name.
* Changed base and BSP default paths.Sebastian Huber2009-03-301-2/+12
* Fixed NULL pointer exception.Sebastian Huber2009-03-301-9/+11
* Added project type for static libraries.Sebastian Huber2009-03-251-1/+26
* Support space characters in paths and options.Sebastian Huber2009-03-181-1/+4
* Add c++ sample template.Daron Chabot2009-03-1321-10/+1970
* Addition of Hello World template and RTEMS icons to preference page and ↵Daron Chabot2009-02-2528-46/+399
| | | | About Eclipse dialog.
* Improved error messages.Sebastian Huber2009-02-061-9/+35
* Removed.Sebastian Huber2009-02-061-19/+0
* Added problem markers.Sebastian Huber2009-02-062-8/+67
| | | | Initialize tools with default values on platform change.
* New version 1.0.1.Sebastian Huber2009-02-061-1/+1
* Prompted by addition of licensing info to RTEMS-CDT Feature.Daron Chabot2009-02-065-5/+115
* Addition of licensing and description info to RTEMS-CDT Feature.Daron Chabot2009-02-065-12/+485
* Attempted repair of initial, failed commitDaron Chabot2008-12-098-0/+690
* Initial commit to RTEMS cvs repoDaron Chabot2008-12-093-0/+43
* Replace Java 6 String.isEmpty() methods.Daron Chabot2008-12-081-2/+2
* Last commit.Sebastian Huber2008-12-041-0/+3
* Update.Sebastian Huber2008-12-041-0/+19
* Initial commit.Sebastian Huber2008-12-0424-0/+2296
* Fixed synchronization problem between the wizard and the project properties.Sebastian Huber2008-12-041-2/+28
* Added preferences for Cygwin, MinGW and MSYS paths on windows.Sebastian Huber2008-12-0414-60/+307
* Reverted previous change. You must translate the path manually for Cygwin.Sebastian Huber2008-12-033-9/+17
| | | | TODO: Fix for MinGW.
* Fixed path translation issue.Sebastian Huber2008-12-033-6/+9
* Fixed problem due to library access restrictions.Sebastian Huber2008-12-033-28/+44
* Fixes for the scanner info collectors.Sebastian Huber2008-12-033-9/+53
* Delete discovered paths after an update of the tools.Sebastian Huber2008-12-031-0/+36
* Fixed issue with copied BSP installations.Sebastian Huber2008-12-033-7/+7
* Cleanup.Sebastian Huber2008-12-028-60/+18
* Removed MinGW toolchain. The standard toolchain works well with MinGW.Sebastian Huber2008-12-021-92/+6
| | | | Fixed typo in the Cygwin toolchain.
* Removed unnecessary PATH adjustment. This cause problems under Windows ↵Sebastian Huber2008-12-021-6/+2
| | | | since 'Path' and 'PATH' are treated differently from Java.
* Updated the wizard page.Sebastian Huber2008-12-014-96/+84
* Added toolchains for Cygwin and MinGW.Sebastian Huber2008-12-012-33/+213
* Fixed problem with '-B' GCC option.Sebastian Huber2008-12-012-3/+26
| | | | Filters new option values.
* Added tool options parser.Sebastian Huber2008-12-018-99/+123
| | | | Removed obsolete properties and preferences.
* Added Makefile to obtain BSP information.Sebastian Huber2008-11-285-17/+130
| | | | | | | | TODO: o Parse make output and provide tool and tool option properties. o Use tool and tool option properties in the command line generator. o Remove obsolete version and target properties and preferences. o Remove wizard.
