path: root/wscript (unfollow)
2016-11-03Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns1-4/+4
2016-10-31waf: Add an install command.Chris Johns1-1/+4
2016-10-30RSB: Initial additionJoel Sherrill1-0/+1
The content was manually converted from Asciidoc to Sphinx and there are some areas which remain to be done. Specifically there are some tables and embedded links which are known to remain but there are almost certainly other things to clean up.
2016-10-30waf: Add top build support.Chris Johns1-0/+34
