* | Replace build date with Git hash and commit date | Sebastian Huber | 2019-01-09 | 1 | -3/+36 |
| | | | | The usage of a build date prevents reproducible builds. | ||||
* | Initial start of converting the Word outline to Rest | Joel Sherrill | 2018-12-17 | 1 | -0/+1 |
| | | | | | Thanks to Scott Zemerick <scott.zemerick@tmctechnologies.com> for the analysis and ideas that led to this. | ||||
* | waf: Add support to build PlantUML and Ditaa images. | Chris Johns | 2018-11-03 | 1 | -0/+6 |
* | Change RTEMS version to 5 | Sebastian Huber | 2017-11-09 | 1 | -1/+1 |
| | | | | Update #3220. | ||||
* | New version of POSIX Compliance Guide | Joel Sherrill | 2017-10-12 | 1 | -0/+1 |
| | | | | | | | This is a replacement of the POSIX 1003.1 Compliance Guide. It will be generated from a .csv file. Updates #3177. | ||||
* | waf: Fix linkcheck and spell commands. | Chris Johns | 2017-03-27 | 1 | -0/+8 |
| | | | | | | Clean up and remove code that is not needed. Fix sphinx-build quoting to work on Windows. | ||||
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 1 | -2/+3 |
* | waf: Correct the branch version number. | Chris Johns | 2017-01-13 | 1 | -1/+1 |
* | coverpage: Update the coverpage to have the table collapse. | Chris Johns | 2017-01-12 | 1 | -4/+4 |
| | | | | Add each doc's conf.py as a dependence to catalogue.xml. | ||||
* | html: Embed the catalogue XML in JS. | Chris Johns | 2017-01-11 | 1 | -3/+24 |
| | | | | | The is to work around a security issue with Chrome on Windows. This patches let the cover page load on Chrome and Edge on Windows 10. | ||||
* | html: Add support for an HTML cover page for releases. | Chris Johns | 2017-01-11 | 1 | -1/+11 |
* | waf: Add a title to the XML Catalogue. | Chris Johns | 2017-01-10 | 1 | -8/+11 |
* | waf: Improved XML Catalogue generator. | Chris Johns | 2017-01-10 | 1 | -5/+6 |
* | waf: Create an XML Catalogue. | Chris Johns | 2017-01-09 | 1 | -0/+6 |
* | waf: Add networking to the manual built. | Chris Johns | 2016-11-15 | 1 | -7/+8 |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 1 | -4/+4 |
* | waf: Add an install command. | Chris Johns | 2016-10-31 | 1 | -1/+4 |
* | RSB: Initial addition | Joel Sherrill | 2016-10-30 | 1 | -0/+1 |
| | | | | | | | | The content was manually converted from Asciidoc to Sphinx and there are some areas which remain to be done. Specifically there are some tables and embedded links which are known to remain but there are almost certainly other things to clean up. | ||||
* | waf: Add top build support. | Chris Johns | 2016-10-30 | 1 | -0/+34 |
