path: root/wscript (follow)
* waf: Add networking to the manual built.Chris Johns2016-11-151-7/+8
* Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns2016-11-031-4/+4
* waf: Add an install command.Chris Johns2016-10-311-1/+4
* RSB: Initial additionJoel Sherrill2016-10-301-0/+1
| | | | | | | | The content was manually converted from Asciidoc to Sphinx and there are some areas which remain to be done. Specifically there are some tables and embedded links which are known to remain but there are almost certainly other things to clean up.
* waf: Add top build support.Chris Johns2016-10-301-0/+34
