2020-03-30 | user: Use consistent Hello World spelling | Sebastian Huber | 4 | -5/+5 | |
2020-03-30 | user: Provide a user friendly configuration | Sebastian Huber | 1 | -4/+4 | |
2020-03-20 | gdbarmsim: Remove all references to this deleted BSP family | Joel Sherrill | 3 | -10/+0 | |
Updates #3611. | |||||
2020-03-20 | user/hosts/posix.rst: Add CentOS 8 information | Joel Sherrill | 1 | -2/+18 | |
2020-03-19 | user/raspberrypi: Fix typo | G S Niteesh Babu | 1 | -1/+1 | |
enable-uart should be enable_uart in config.txt | |||||
2020-03-13 | user: Add a migration chapter | Chris Johns | 3 | -0/+115 | |
This is a start with the hope we collect useful pieces to aid porting. Please add to this. Closes #3895 | |||||
2020-03-13 | user: Update Quick Start Guide reference. | Chris Johns | 1 | -1/+1 | |
2020-03-13 | user: Add anchors to some BSPs. | Chris Johns | 2 | -0/+15 | |
2020-03-13 | user: Update Quick Start Guide | Chris Johns | 12 | -210/+821 | |
- Add support for release source archives - Add building the BSP using the RSB - Add building packages using the RSB - Add an application Closes #2998 | |||||
2020-02-18 | user/tools: Add RTEMS TFTP Proxy command documentation | Chris Johns | 4 | -1/+170 | |
2020-02-15 | doc/raspberrypi: Added instructions for raspberrypi | G S Niteesh | 1 | -1/+110 | |
Added instructions to run examples on raspberrypi. | |||||
2020-02-10 | user/testing: Add coverage analysis instructions | Vijay Kumar Banerjee | 2 | -0/+69 | |
2020-01-07 | Updated docs to use the standalone SIS simulator, instead of GDB inbuilt SIS ↵ | G S Niteesh | 2 | -16/+132 | |
for the erc32 BSP. | |||||
2019-12-20 | bsp/xen: Add information on Xen/ARM BSP | Jeff Kubascik | 2 | -0/+80 | |
Add a README for the new xen bsp. | |||||
2019-12-19 | user: Mention xilinx-zynqmp BSP | Sebastian Huber | 2 | -0/+9 | |
Close #3682. | |||||
2019-12-12 | user/hosts/posix.rst: Update Ubuntu instructions. | Joel Sherrill | 1 | -2/+3 | |
Note that the ticket has instructions for what to do if the error message "Error :: You must put some 'source' URIs in your sources.list" is reported. As this occurred on an Ubuntu version that was not LTS, it is not being added. If this error occurs in the future on a LTS release, then add this information. closes #3416. | |||||
2019-12-12 | user/hardware/tiers.rst: Merge info from Wiki. | Joel Sherrill | 1 | -5/+28 | |
Tiers had a write up on the Wiki which was similar but different. Merged content from the Wiki which allows the Wiki page to be deleted. closes #3831. | |||||
2019-11-29 | user: Add frdme310arty BSP varient | Pragnesh Patel | 1 | -0/+8 | |
Signed-off-by: Pragnesh Patel <pragnesh.patel@sifive.com> Update #3785. | |||||
2019-11-22 | user: Add hints for macOS Catalina | Sebastian Huber | 1 | -10/+21 | |
Use macOS throughout. Order release hints so that the latest macOS release comes first. | |||||
2019-10-30 | user: Document patch review process | Sebastian Huber | 1 | -3/+108 | |
2019-10-30 | user: Update contributing section | Sebastian Huber | 1 | -22/+19 | |
2019-10-30 | Move contributing content from eng to user | Sebastian Huber | 1 | -0/+146 | |
2019-10-13 | user/rsb: Update 3rd party package build and add packaging details. | Chris Johns | 6 | -327/+592 | |
2019-09-26 | bsps/beagle: update i2c section | Vijay Kumar Banerjee | 1 | -3/+3 | |
2019-09-05 | FreeBSDL: Add command to improve waf's performance with Python3. | Chris Johns | 1 | -2/+11 | |
2019-08-22 | Update docs for log mode change and JSON reporting | Kinsey Moore | 1 | -8/+21 | |
The option --report-mode has been changed to --log-mode to reduce ambiguity and --report-format has been added along with --report-path for machine readable test reporting. | |||||
2019-08-20 | Add steps to test Newlib patch. | Vaibhav Gupta | 1 | -6/+35 | |
Update the checksum to be used for the Newlib patches. Earlier it was msd5, but it is depreciated for security reasons. Now RSB accepts sha512. | |||||
2019-08-15 | user/hosts/posix.rst: Improve Ubuntu python 2 devel package instructions | Joel Sherrill | 1 | -3/+9 | |
2019-08-15 | hosts/posix.rst: Fix typo of sudu to sudo | Joel Sherrill | 1 | -1/+1 | |
Closes #3754. | |||||
2019-08-15 | hosts/windows.rst: Add warning for spaces in PATH | Joel Sherrill | 1 | -0/+16 | |
2019-08-15 | user/rsb/deployment.rst: Fix typo. | Joel Sherrill | 1 | -1/+1 | |
2019-08-15 | user/index: Add myself to the list of copyrights | Vijay Kumar Banerjee | 1 | -0/+1 | |
2019-08-14 | user: Update bug reporting section | Sebastian Huber | 1 | -10/+24 | |
Include information from https://devel.rtems.org/wiki/NewTicket | |||||
2019-08-11 | user/exe: Add link reference in device-tree | Vijay Kumar Banerjee | 2 | -1/+3 | |
2019-08-08 | user/bsps: Fix typo in beagle | Vijay Kumar Banerjee | 1 | -2/+2 | |
2019-08-08 | user: Improve bug report section | Sebastian Huber | 4 | -11/+183 | |
The new content is based on the wiki page: https://devel.rtems.org/wiki/Developer/Bug_Reporting The goal is to remove the wiki page and direct the "New ticket" page to this user manual section. Some content of the wiki page should move to the "Contributing" sections since it is not directly related to bug reporting, e.g. managing existing bugs. | |||||
2019-08-07 | user/exe: Add Device Tree section | Vijay Kumar Banerjee | 3 | -19/+95 | |
2019-08-06 | user: Move support sections to top level | Sebastian Huber | 7 | -120/+156 | |
This is a preparation step to move the bug reporting procedure from the wiki to the user manual and to add a contributing section. | |||||
2019-07-27 | user/bsps : Fix formatting and typo in arm/beagle | Vijay Kumar Banerjee | 1 | -18/+37 | |
2019-07-20 | user/bsps : Add documentation for Beagle | Vijay Kumar Banerjee | 1 | -2/+89 | |
2019-07-12 | user: Split the ARM BSPs source into separate files. | Chris Johns | 20 | -382/+458 | |
2019-06-12 | user: Add the boot image tool command. | Chris Johns | 2 | -0/+446 | |
2019-05-27 | user: Document boot image generation | Sebastian Huber | 1 | -1/+12 | |
Update #3727. | |||||
2019-03-18 | user: Add basic lpc24xx description | Sebastian Huber | 1 | -3/+72 | |
Update #3724. Update #3725. | |||||
2019-03-06 | user/test: Update with the latest test configuration format. | Chris Johns | 1 | -14/+96 | |
2019-03-01 | User: Change output block to type none. | Chris Johns | 27 | -117/+119 | |
2019-02-28 | user: Remove nit-picky warnings. | Chris Johns | 34 | -313/+541 | |
2019-02-28 | Add unicode support for commonly used characters like copyright. | Chris Johns | 1 | -8/+10 | |
- This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals. | |||||
2019-02-28 | Update User Documentation for Host setup for Linux | Vaibhav Gupta | 2 | -0/+7 | |
Mention the requirement of 'pax' package for building BSP if RTEMS is configured with '--enable-tests' option, else build fails. | |||||
2019-02-20 | user: Add a Dynamic Loader section. | Chris Johns | 8 | -3/+881 | |
