index
rtems-docs
4.11
5
master
RTEMS Project documentation.
devel@rtems.org
summary
refs
log
tree
commit
diff
stats
log msg
author
committer
range
path:
root
user
unfollow
Commit message (
Collapse
Author
Lines
2017-03-27
waf: Cleaner formatting to see the importing.
Chris Johns
1
-6
+7
2017-03-21
user: Fix typo.
Chris Johns
1
-1
+1
2017-03-21
user: Minor fixes to rtems-bsp-builder.
Chris Johns
1
-3
+3
2017-03-21
user: Add an example of the rtems-bsp-builder running.
Chris Johns
1
-2
+389
2017-03-20
Use a single top level version number.
Chris Johns
1
-4
+5
2017-03-15
user: Add tool commands to the user manual.
Chris Johns
7
-23
+612
2017-01-11
Update document titles for consistency
Joel Sherrill
1
-3
+3
2017-01-11
Remove references to SPARC/SIS BSP. Also clean up old ERC32 references.
Joel Sherrill
1
-1
+1
updates #2810.
2016-12-21
Update version/revision to 4.11.99
Sebastian Huber
1
-2
+2
2016-11-09
user: Fix header levels.
Chris Johns
28
-65
+88
2016-11-02
Fix spelling.
Chris Johns
1
-1
+1
2016-10-31
waf: Add an install command.
Chris Johns
1
-2
+6
2016-10-30
waf: Formatting.
Chris Johns
1
-2
+2
2016-10-29
user: Add comments about warnings we cannot remove.
Chris Johns
2
-0
+5
2016-10-29
user: Add comment to move to packages.
Chris Johns
1
-0
+3
2016-10-27
ecosys/index.rst: Fix complixity spelling
Joel Sherrill
1
-1
+1
2016-07-06
Fix the table and section numbering in the User,Hardware,Tiers section.
Chris Johns
1
-16
+16
2016-07-06
Add a Hardware section.
Chris Johns
9
-19
+224
2016-07-06
Update the glossary.
Chris Johns
1
-0
+25
2016-07-04
Add the RTEMS Kernel section back in.
Chris Johns
3
-0
+435
2016-07-04
Reorganisse the User Manual to make it easier to navigate.
Chris Johns
19
-843
+734
2016-05-20
Set SPDX License Identifier in each source file.
Chris Johns
28
-0
+56
2016-05-18
Move images to a common directory.
Amar Takhar
2
-1
+1
2016-05-02
Review changes from Chris Mayfield.
Chris Johns
3
-61
+67
2016-05-02
Corrections from Worth Burruss. Many thanks.
Chris Johns
2
-8
+7
2016-05-02
Chris Johns
9
-79
+143
2016-05-02
Fix bad formatting that somehow went into the doco.
Chris Johns
1
-47
+47
2016-05-02
Corrections from a review.
Chris Johns
3
-87
+97
2016-05-02
Corrections and improvements from Worth Burruss (thanks so much).
Chris Johns
2
-7
+38
2016-05-02
Corrections.
Chris Johns
3
-39
+65
2016-05-02
Add a basics section to Getting Started. Rearrange the content.
Chris Johns
8
-380
+563
2016-05-02
Start adding Getting Started guide's Released Version.
Chris Johns
1
-2
+267
2016-05-02
Updates from user reviews.
Chris Johns
2
-23
+28
2016-05-02
Split installation into separate files.
Chris Johns
6
-632
+646
2016-05-02
User manual, devel install and windows install.
Chris Johns
17
-56
+1612
2016-05-02
Add 'waf linkcheck' to check external references.
Amar Takhar
1
-1
+1
2016-05-02
Add PDF generation support use with --pdf
Amar Takhar
2
-6
+5
2016-05-02
Add support for spellchecking with a custom dictionary.
Amar Takhar
1
-1
+1
To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar.
2016-05-02
Rework how conf.py is handled.
Amar Takhar
2
-9
+9
Needed to switch due to increasing complexity.
