* | tools/boot-image.rst: Master Boot Record is MBR not MRB | Joel Sherrill | 2021-04-05 | 1 | -1/+1 |
* | user/bsps: Add STM32H7 SDMMC driver | Christian Mauderer | 2021-04-01 | 1 | -0/+26 |
| | | | | Update #4372 | ||||
* | User/BSPs/Beagle: Add JTAG debugger section | Christian Mauderer | 2021-03-30 | 1 | -2/+65 |
* | start: provide more version guidance for gsoc | Gedare Bloom | 2021-03-25 | 2 | -2/+6 |
* | start: Console output example updates | Ida Delphine | 2021-03-25 | 5 | -150/+159 |
* | app: Update command to configure app | Ida Delphine | 2021-03-25 | 1 | -4/+4 |
* | bsp-build: Update manual bsp build command | Ida Delphine | 2021-03-25 | 1 | -5/+5 |
* | tools: Update command to install toolsuite | Ida Delphine | 2021-03-25 | 1 | -5/+5 |
* | sourses: Update source download command | Ida Delphine | 2021-03-25 | 1 | -2/+2 |
* | prefixes: Update installation prefix | Ida Delphine | 2021-03-25 | 1 | -4/+4 |
* | user/bsps: Mention fixed console baud rate for zynq | Jan Sommer | 2021-03-16 | 1 | -0/+12 |
* | user: Update ZynqMP QEMU BSP name | Kinsey Moore | 2021-03-05 | 1 | -5/+6 |
| | | | | | | The ZynqMP QEMU BSPs have had _qemu added to their names to better identify them as QEMU BSPs similar to other BSPs which are meant to run exclusively on QEMU and not hardware. | ||||
* | STM32H7 doc update | Robin Mueller | 2021-02-18 | 1 | -1/+17 |
* | user: remove old build system cmd | G S Niteesh Babu | 2021-02-03 | 1 | -2/+2 |
* | user: add guidance on version numbers to GSoC guide. | Gedare Bloom | 2021-02-01 | 1 | -0/+6 |
* | user: Update aarch64/xilinx-zynqmp Qemu command | Kinsey Moore | 2021-01-14 | 1 | -1/+1 |
| | | | | | | The Xilinx ZynqMP BSP has been updated to use the second UART in the memory map as the primary UART since this is how both the hardware and Qemu use them. | ||||
* | user: Mention use of LLVM | Sebastian Huber | 2021-01-04 | 1 | -0/+4 |
* | user/bsp/imxrt: Information for custom FDT | Christian Mauderer | 2020-12-14 | 1 | -8/+38 |
| | | | | Update #4180 | ||||
* | user: Add aarch64/xilinx-zynqmp | Kinsey Moore | 2020-12-11 | 2 | -0/+36 |
* | user: Add A53 Qemu run instructions | Kinsey Moore | 2020-12-11 | 1 | -0/+8 |
* | aarch64: Update interrupt details | Kinsey Moore | 2020-12-11 | 1 | -2/+3 |
* | user/bsps: Fix list in bsps-arm | Christian Mauderer | 2020-11-20 | 1 | -2/+2 |
| | | | | Seems that some filenames haven't been added correctly. | ||||
* | user/bsps: Add imxrt | Christian Mauderer | 2020-11-20 | 2 | -0/+174 |
| | | | | Update #4180 | ||||
* | user: Add arm/stm32h7 | Sebastian Huber | 2020-10-27 | 3 | -0/+66 |
| | | | | Close #3910. | ||||
* | user: Rename files to match the chapter index | Sebastian Huber | 2020-10-27 | 2 | -0/+0 |
* | user/beagle: Add debug hardware mod | Chris Johns | 2020-10-19 | 1 | -0/+61 |
* | user: Fix RTEMS release URLs | Sebastian Huber | 2020-10-06 | 1 | -6/+6 |
* | Add AArch64 documentation | Kinsey Moore | 2020-10-05 | 2 | -1/+27 |
* | user: Add migration hints from old build system | Sebastian Huber | 2020-09-25 | 1 | -2/+96 |
| | | | | Update #3818. | ||||
* | i386: tweak grammar and style | Gedare Bloom | 2020-09-21 | 1 | -7/+4 |
* | pc386 BSP: add runtime options for debugging and move few lines around for ↵ | Karel Gardas | 2020-09-21 | 1 | -5/+27 |
| | | | | better context. | ||||
* | pc386 BSP: add a note about default baud rate for console over UART/COM. | Karel Gardas | 2020-09-21 | 1 | -0/+4 |
* | user: Document BSP new build system | Sebastian Huber | 2020-09-13 | 7 | -154/+367 |
* | user/pc386 BSP: add documentation. | Karel Gardas | 2020-09-09 | 1 | -1/+395 |
| | | | | | The content is compiled from TBR pc386 wiki page, BSP's README files and from the actual BSP code. | ||||
* | user: Add xilinx-zynq BSP details | Chris Johns | 2020-09-08 | 1 | -2/+112 |
* | user: Mention file descriptor changes | Sebastian Huber | 2020-09-02 | 1 | -0/+19 |
* | user: Change the BSP build set path | Chris Johns | 2020-09-01 | 1 | -4/+4 |
| | | | | Updates #4048 | ||||
* | user: Fix format | Sebastian Huber | 2020-08-13 | 1 | -1/+1 |
* | user: Add the RSB sb-track command | Chris Johns | 2020-08-12 | 1 | -0/+81 |
| | | | | Updates #4036 | ||||
* | user, README: Add Python script host set up information | Chris Johns | 2020-08-12 | 2 | -10/+149 |
| | | | | | | | | | - Add Python3 and venv to the README - Add a section on how to set up a host if the python command is not available. Update #4037 | ||||
* | user, eclipse: Remove RSB sb-bootstrap command | Chris Johns | 2020-08-12 | 2 | -6/+6 |
| | | | | Update #4046 | ||||
* | user: Remove RSB sb-builder command | Chris Johns | 2020-08-11 | 2 | -75/+14 |
| | | | | Updates #4045 | ||||
* | user: Add shell environment migration aid | Sebastian Huber | 2020-08-10 | 1 | -0/+27 |
* | user: Mention replacements for removed APIs | Sebastian Huber | 2020-07-15 | 1 | -0/+51 |
* | user: Add v5 to v6 migration help | Sebastian Huber | 2020-07-14 | 2 | -0/+21 |
* | Reflect removal of the epiphany target | Sebastian Huber | 2020-07-05 | 2 | -12/+0 |
| | | | | Update #3941. | ||||
* | user: Document arm/realview-pbx-a9 BSP | Sebastian Huber | 2020-07-02 | 1 | -2/+14 |
* | user/rsb: Update the configuration documentation | Chris Johns | 2020-04-28 | 1 | -39/+13 |
| | | | | Closes #3945 | ||||
* | user/tester: Remove command line help as output | Chris Johns | 2020-04-28 | 1 | -31/+2 |
| | | | | Closes #3381 | ||||
* | user: Update the RSB BSP quick start to say where the tests are installed | Chris Johns | 2020-04-28 | 1 | -1/+3 |
| | | | | Closes #3956 |
